- Anyone have these headlights??
- 92-96 prelude seats....
- '95 GSR I/H/E running VERY rich... HELP!
- What seats match 91 Integra bolt pattern?
- Centerforce Clutch?
- fixing finish on my set of fat fives?
- Abs code
- Just got HKS cat back
- CF Door Handles
- Help with wiring..
- 2000 type-r's how many made in PY
- What tire to replace stock (worn out) is best
- Abs!!!!!!!
- ground wire
- tsudo fireball
- Just got a 2nd gen!!!!!
- should i change timing belt early?
- Power Window Problem
- parking brake
- window "stuck"...
- which clutch...
- 94 LS Burning lil' oil
- code 22 after vtec
- Chipping 2001 ITR
- type r gunmetal wheels
- Help on wiring turn signal mirrors
- wholesale parts online?
- b-series timing theory
- Jdm Itr Headlights
- dc5 R brake calipers.
- is it a good buy?
- Front Bumper Screws
- window stuck!
- coilover question.
- new teg
- hard to shift into 1st
- high flow cat
- This sound is killing me!
- LS Vs. GSR???
- Dashboard
- LS to VTEC
- Power antenna suddening stopped operating
- Turn signal problems..
- LS wont go into 3rd when raced please help
- Mugen Pedals
- list your Apex'i WS complaints here
- taking off stock pedals
- A/C overheat???
- installing carsound cat messes up my tuning?
- Replacing my wheels, suggestions needed.
- anyone tried KYB GR2 struts?
- engine swap
- need help on coilovers
- shop manual and camber
- 95 Integra LS Axle question
- How much boost?
- What To Do!
- rim size
- Can You Swap Fuel Injectors, and fuel rails?
- lowering my car...
- speedometer
- handling ????
- coilovers
- Need knowledge about certain coilovers/shocks...
- interchangeable parts?
- expanded parts view
- Newbie Help
- how much should a new radiator for a 97 integra cost?
- engine & tranny for 95 GSR
- Question about Stage 1 Exedy Clutch
- Octane, detonation and CAI
- where can i find OEM front 89 integra shocks?
- problems with 99 Integra
- Happy birthday Chris N
- new to integra - advice & basic questions
- map light help@!#$@$#
- turbo help
- something is wrong!
- Are GSR brakes bigger than LS?
- ECU'S & COLOR CODES
- Miss the Manual -- LS Auto Woes
- it seems very cheap
- Abs Light ON 92' integra gsr
- helms Manual 2
- JDM fender mud guards
- Can someone look in G2 Hanes manual for me please???
- LED question.
- Is my tranny bad or is it the clutch?
- how do i check my clutch fluid?
- Stupid technical question - please help!
- watch the Honda Integra Movie
- Are these CTR Cams?
- I got my Car.. but...
- anybody know cheapest place for clutch?
- helms Manual
- header question
- ECU Connector for a 95 GSR?
- Mugen rear wing
- I can't change my timing belt!!!!
- Brake Pad Question
- Trunk brace bar installation
- V vs H rated tires
- Ola!
- stiff clutch/gear shift???
- Suspension for GS-R
- Spark plug and coil question
- Here is my plan...
- Whistling Sound inbetween shifts
- Car shakeing..Help please
- Toda cams
- exhaust leak... help fix?
- Demystify tires please
- will coilovers froma 96 civic hatch fit on a 96 gsr
- car stalled now wont start
- where can i find some good ol' OEM 89 integra parts?
- '94 GSR vibration under the car?
- Trade my WRX for your ITR
- Help a girl out
- Just Curious...
- Suspension issues: stabilizer bar rusty
- Strange noises killed my GSR, PLEASE HELP!!!
- 88 Integra Cylinder Heads Help...
- rim offsets?
- g2 website
- replacing rotor ?'s & spark plugs
- machined rims
- anyone ever replace the radiator support?
- G2 dash removal help please
- Anyone know what the stock tires were on the Type R? (in the us)
- Just got my integra, a few quick questions
- turbo help
- 1st mods to GSR
- RS-R Exmag
- wheel well rust
- New integra
- Sputtering at Low RPMs
- is it normal??
- Power Antenna -- Bent on Failure
- 300 zx VS. 2001 GSR
- Damn Valve Cover caps.
- check engine light S3 light flashes
- 5 lug or 4 lug
- 98 GS SRI and exaust help
- New Integra owner..
- anybody replace their own weatherstripping?
- Squeling rear brakes
- Temperature Gauge stuck on cold
- 99 Integra LS - SRS Light, Door Open Light, and ABS Light problem
- LS vs GTS
- Shocks Installment, noise?
- Replacing Antenna on G3
- Loud Click -- Braking in Reverse
- The Integra stock intake........
- Question about 91 Integra Front End
- does anyones have spec for B18C???
- best sounding intake?
- 2002 Integra Electrical Problem
- Spoon Decals
- clutch set
- Would this be a good deal?
- Integra Clutch Set
- 92 Integra Engine Problems
- Starting to get involved in autox, need advice on mods
- Engine
- Electrical
- Rear Camber Bolts
- Tranny Clutch problem? Please Help!
- Changing the Clutch Plate on an 87 Integra
- Greddy Evo2 tip clearance
- new cat = check engine light on?
- spark plugs?
- Milky Transmission Fluid
- difference?????
- GSR cam swap
- Neuspeed Springs
- Exhaust Leak! Help!
- got the car DYNO'ed yesterday...
- Albany/Duralast brake pads
- type r five lug
- Radiator with oil cooler
- aebs intake manifold
- Re-Installing Shocks
- :Your Two Cent Please:
- Parts suggestion
- New to the Family, Basic simple bolt ons to gain hp??
- What parts to buy for ITR???
- Power steering fluid leeking??
- 2001 integra fender question????
- Vavle job needed in SoCal (Orange County)
- my radiator is finally starting to let go..
- are any of u guys looking to sell your seats?
- cv joint boots
- Integra Carbon fiber hood?
- Mounting tires
- Self Locking nut on Shock
- Racing ECU's? + MOre
- Integra tasty?
- How much to Replace Transmission and Clutch on a 2001 Type R?
- G2 Versions & Updates
- Hesitation under load
- Time for some new Rotors and Pads
- Any one with a white 95 gsr?
- Are they all at the same place?
- Rota Slipstreams or Circuit 8's?
- Break problem 93 Integra
- where to get fiberglass front end for a '94?
- License plate hole plugs; where to get them?
- Sleeved Turbo 2.0L Type R
- New to Integra, basic questions
- 2000 gsr cel on and throwing cel codes.Please help
- Year to Year differential Please.
- civic seats into integra fit right?????
- Oem parts
- horn & brake lights not working
- Need some advice on what to do, might buy a GS-R
- need to decide
- Wheel Help Please!
- Mugen Lip For 2nd gen?
- ABS code 8-2 ???
- My 96 ls special wont pass smog so...
- idle problem
- smogged today..high HC level
- motor mounts
- Pictures of our new Pro Street Online Project Turbo GSR
- Speedometer a bit off...
- Help! CARB/SMOG legal I/H/E setup for my GSR
- Tranny noise.....noise record included
- humming noise
- caliper hanging up...i'm at a loss...
- price for 97 itr?
- Q's For California folks
- Smog Help Needed.
- Crank Sensor
- Need Help and input
- apex rsm installation
- Helms Manual
- I Can Barely Hear VTEC, How Do I Get VTEC To Scream?
- Rally in east bay area?
- Brake Calipers
- Spoiler LED??
- Alright, if you had $15k to spend on a car and mods....
- recaros
- where to find the check engine light plug?
- ITR rear swaybar
- LS turbo Upgrade? Some Q's
- Removing the Resonator?
- vtec not working
