PDA
View Full Version : Integra & '97-'01 Integra Type-R
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 [37] 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87
  1. belt slipping noise coming from intake manifold
  2. will water hurt a clutch or a flywheel?
  3. 95 tegra auto shifter locked.
  4. Strut Bar
  5. B16 headers in 91 Integra
  6. timing belt successful but.....
  7. Door Lock problem..HELP
  8. '95 integra starting problem
  9. Expo Logo Contest - Place your votes
  10. I really hope not..
  11. Think theres a difference in brands?
  12. Lsd
  13. Help Identify What's Wrong Wit My Integra
  14. Tire application
  15. grilles
  16. cam question
  17. Will prelude injectors work in 92 integra rs?
  18. Air Intake for GSR
  19. seat belt indicator
  20. Bad news
  21. new Integra owner
  22. DIY Icebox
  23. Eibach Prokit/ Koni Yellow SP3?
  24. GSR cam timing
  25. Teg Rods / Rpm
  26. Which turbo is the best?
  27. Difference between High lift cams and turbo cams?
  28. Variable/Intermittent windshield wiper
  29. Changing rear rotors
  30. Relocating IAT sensor
  31. Need info on Integra specs.
  32. Radio Section
  33. Where is a good place to look for an underbody spolier kit?
  34. Trying to find a part...
  35. Shifter Problems
  36. CEL po172
  37. just got turbo. need new clutch?
  38. tires for the teg
  39. exhaust question
  40. Type R injectors
  41. Wheel bearing problems
  42. Removing the ECU from 99 GSR
  43. Need for front end conversion
  44. Fawkin Curb Owned My Car!!
  45. Noise when pressing gas
  46. fender rubbing? 17" rims and 1.5 drop
  47. 1/4 mile time
  48. What kind of strut bar wont rub?
  49. Engine Light on 92 Integra LS
  50. Cooling Fan Draining Battery
  51. vacuum hose?
  52. 93 Acura Teg, Ls
  53. Car Seat Covers for 94 Integra
  54. Need new a/c lines
  55. auto tranny fluid change - hmm
  56. 2000 Jdm Itr?
  57. Notion to lock all general questions...
  58. New Pic of my R
  59. Buy a new RSX!?
  60. what is itr anyways?
  61. Best year/model Teg?
  62. B18C5 cam description
  63. 91 Integra b16a swap NEED HEADER!!
  64. 4door/2door g3 mirror interchangeable?
  65. noisy brakes
  66. drivetrain whine
  67. Need some Non-VTEC Hatchback exhaust help
  68. LS/RS automatic tranny question
  69. parking brake
  70. help with a DTC...p0450
  71. Need help diagnosing a DTC...
  72. problem with getting head.
  73. Importing Integra type-r.........
  74. Rota's slipstreams ???? on ITR??
  75. just got turbo kit need new clutch
  76. K-series in DC4
  77. is a knock sensor really needed
  78. Blow off Valve Recommendations
  79. AEM CAIs vs Generic EBAY Stuff
  80. New wheels so happy - woot!!!
  81. 8800 rpm..
  82. installing glow gauges.
  83. KYB AGX/H&R Sport - Poor ride comfort
  84. Radiator Replacement
  85. Skunk 2 intake manifold
  86. Burning smell and whining noise
  87. WTB: 94 Teg Passg Headlamp Unit
  88. I have an automatic 2000 acura integra
  89. tech question about lower tie bars
  90. shaved my side moldings
  91. New to VTEC. Noobie Question
  92. Diagnose My Engine numero 2
  93. looking at an integ?
  94. Should I buy a Civic or an Integra?
  95. radiator
  96. Timing Belt Removal
  97. horsepower for cheap
  98. good deal, or no?
  99. release pressure
  100. Color code question?
  101. most power for the buck?
  102. 4 door rear door handles on the fronts of a 2 door
  103. final drive gear ratio
  104. Valv adjustment specs on a 91 GS
  105. driver side mirror damaged by deer
  106. 98 GSR Timing Belt and Water Pump $490.00
  107. Terrible New Sounds:95 GSR
  108. Help! 6500 rpm fuel cut off on a GSR engine
  109. how do you take out the o2 sensor..
  110. TEIN SS Coilovers/Shocks
  111. those w/ 16" wheels
  112. Have you seen this petition to bring ITRs into the states?
  113. CTR cams in GSR
  114. Fawkkking Intake manifold
  115. $7k to spend HELP!!!!
  116. new guy with weird problem
  117. Question about lower and coilovers/springs
  118. 96 se integra gauges
  119. strut/sway bars
  120. Integra or Prelude
  121. OEM Integra Alarm
  122. ITR planning question
  123. ebay turbo..HELP!!!
  124. Where can i get a set of gabs wheels?
  125. Installing 96 leather seats in a 91.
  126. GSR Revs out of Control. WTF?
  127. JDM headlight
  128. Best Exhaust for my 97 GSR
  129. short shifters
  130. Anyone of ever heard of www.tuner007.com?
  131. GS-R Brake Conversion
  132. JDM headlight type?
  133. car shuts off in the of driving
  134. wheel and tire issue
  135. Sos
  136. Where can i get genuine spoon parts?
  137. ABS light?
  138. b18c in a 91 integra
  139. Maintanance Req Light on Integra
  140. First autocross time!
  141. Exhaust Setup
  142. short shifter pictures
  143. Is this a good deal?
  144. how to make your muffler angled?
  145. helms manual
  146. Rhode Island Integra Owners
  147. NOOB: Question about swaps
  148. quci questiong about 98 eibach sportline springs
  149. is this a good deal?
  150. Celica vs. Integra
  151. Rear strut bar on 94-01 LS sedan
  152. Ripped shifter cable boot under car.....
  153. Vibration
  154. exhaust sound
  155. Sound System
  156. help: 89 integra giving me trouble when starting
  157. help exhaust is backfiring or popping
  158. Engine probs from about 2k to 3k rpms
  159. Good Deal??
  160. Jumped battery blew electrical system
  161. Brake Light
  162. BG44k
  163. NSX Steering Wheel on Integra?
  164. Integra Alignment (toe in/out)
  165. brakes.
  166. Rotory Compressor??? I Need Info
  167. Ebay Name Brand?
  168. I need a good I/H/E setup for my GSR
  169. fun road bad times
  170. Car Alarm/ Remote unlock
  171. Fuel Cut in a 99 GSR w/ t3t4
  172. can any one help a new guy??
  173. Noob! Getting back into an Integra tomorrow.
  174. Valve Adjustment
  175. Brake light on dash
  176. want to build ls turbo
  177. Choices of Exhaust Help/Suggestions...
  178. 00 GSR K20 type s swap finally complete.
  179. Cap and rotor
  180. here first! this will help most of you out...
  181. speedometer reclocking
  182. 95 integra LS Timing belt broke
  183. integra brake conversion
  184. ls vtec conversion
  185. Ebay headers
  186. Rocker arms on 95' SE
  187. Exhaust camshaft sealing plug
  188. power window
  189. 2ndgenint
  190. New Car
  191. Headlight
  192. Recaro installation: Brackets and Sliders?
  193. JDM ITR conversion
  194. Max tire size?
  195. Swapping ECU's In a type-r From OBDII to OBD 0
  196. new guy
  197. Integra Transmission fluid
  198. good trade???????
  199. what's your status?
  200. Good Deal?
  201. noob help with break pads replacement
  202. A sad day....
  203. cusco 25mm sway bar
  204. Engine dies out
  205. weird a/c
  206. Missfire in all cylinders.
  207. running sluggish.
  208. spark plug blew out
  209. Problem w/ back struts...
  210. integra rims
  211. Removing A/C
  212. Problems with Automatic Door Locks In LS
  213. Short Ram Intake for Gen2 Teg???
  214. Help!
  215. Noob Question
  216. out of the frying pan...
  217. JDM Front End
  218. Do GSR parts fit an RS?
  219. I saw this A C U R A sticker the other day
  220. Engine Ground Cable
  221. Jun Ecu
  222. just wondering??
  223. Need help with wheel offset
  224. power antenna and sunroof problems
  225. jdm swap ecu trouble?
  226. "Electric" Turbochargers
  227. anyone know how to remove the governor
  228. Door Slam
  229. engine swap?
  230. Q on k20 vs b20
  231. ECU problem: GS-R motor running P75
  232. Brake problems
  233. Saying Hello
  234. Exhaust Question?
  235. HELP!!! 1989 Integra Not Starting
  236. Need Help Installing Oil Squirters In B18B (LS) block
  237. bay area ITR meeting oct 17 look here
  238. secondary o2 sensor wire
  239. Type R ECU
  240. Exhaust Exhaust Exhaust
  241. Clear Coat?
  242. fog lights
  243. Which Turbo to Purchase??
  244. Eratic idle at running temperature.....help???
  245. Honda badge
  246. Redline ATF: Will it damage my 5spd tranny?
  247. This might be a dumb Question...
  248. Integra Advice, Need Help!
  249. Firestone = expensive liars
  250. Head replacement question...
