- Newest Member to the family
- 92 Acura Intergra LS quit running suddenly
- What kind of anti-freeze to use??
- Unstable Idle on first gen '88 teg
- My First Gripe
- JDM hood release switch over?
- Power Mirror Question
- is it ok to use non mandrel pipes fer intercooler?
- Gsr
- Uprights and brakes
- What kind of oil do you use?
- My GSR Makes A Weird Noise Around 3100 RPM
- Attn: DO NOT POST FOR SALE ADS HERE!
- fujitsubo exhaust systems?
- Head back on but a lot of problems.
- Bleeding Brakes, what size tubing?
- b18b1
- Oil coming in from floor
- battery light
- b18a1 block
- RSX seats in an Integra
- Plugs and Wires question
- One high beam dim
- Hood Won't Release on 95 GSR
- Can Bad Timing Result In A Rich Burn?
- thinner head gasket
- engine light still on ...?
- how big are the ....
- Maintaining your 94' LS, timing belt etc.
- 94' LS i need more low end torque power..
- pics of ws1 and ws2 exhaust?
- H&R springs.....
- Hearing a new noise.
- Removing rear rotors after screws are out
- oil light stayed on longer than usual
- Should I sell my integra for a s2k ?
- Factory Security System
- compression test ?
- Remove Air Intake Resonator + High Flow Filter = Cheap CAI?
- Need a Carfax?
- won't hold idle on startup
- stock speakers in 01
- strut bar
- 99 dash in 95?
- question?
- Where might I find connectors?
- Anybody using a Black Widow BWN-500P 2 way paging Alarm in their TYPE R ??
- Hey Master YoDub or Dubster
- Red Line Does Not Ping
- 120k service?
- help! gears grinding
- R Conversion Confusion, drilling.. etc.
- Pros/Cons for a Lightened Flywheel
- How often should I replace transmission fluid?
- turboing a type r motor
- 1998 Championship White Integra Type R
- Skunk2 Exhaust
- Integra Type R stock air filter
- ITR new clutch time..what should i replace it with??
- Cat Removal equal better gas mileage?
- intercooler off eclipse will it fit mines
- Halo Projector Bulbs.
- Better lighting for my teg
- Honda Center Caps in Integra GSR Rims
- Speedo too fast
- turbo?
- 2500 RPM Noise
- 98 GSR Check Engine Light
- breaking in the turbo
- Valve Adjustment required @150k?
- Needles Sticking after putting in Aftermarket gauges
- Black/clear Corner Lenses
- rear engine mount
- Car failed B.A.R. Smog test.
- High mileage vs. regular motor oil
- Buying GSR, got question
- Strut bar(s) question
- JDM, Mugen, Spoon P72 ECU
- My exhaust sucks...
- Type R exhaust on an LS
- price for a b18b?
- What the hell is going on here...
- How often should you change your fuel filter?
- found a G2 on Ebay
- Remote starter
- civic conversion possible?
- 90 Integra oem Am-Fm-Cd
- Changing Muffler+TIP
- O2 sensor removal
- so much body roll!
- Starting it.
- Steering pulls left from a stop?
- Where does this dang hose go?
- 273k+ & out
- Anyone chenged their own rotors?
- high rpm problem
- Need advice on where to buy a teg
- TEg cracked sunroof
- steering column noise?
- Quality replacement radiator
- 02 sensor in the way...
- '95 GSR Problems. Help!!!!
- Replacing CV joints? Help
- Alarm time.
- launching problems, pls help!
- Installing JDM Type R Cluster into 95 LS
- 94-95 and 96-up ls heads
- OBX cams
- How To get the ECU codes 92 ls
- Tranny Question
- Just installed Eibach Prokit and Koni Yellows got a ?
- bought a G2 integra last night!!!
- need help with rotor.
- CFT's Integra Test Run @ 26psi
- advice.
- JDM Cams any different than U.S. Spec
- gauges
- is it possible to convert from cable to hydraulic tranny?
- HELP! engine problem but no CEL
- 95 teg w/ 200k miles
- 2005 RSX Type-S Test Drive
- One Piece Headlights
- 6-speed tranny
- Almost done and :madfawk:
- Do you know any junkyards in LA area?
- When to replace water pump?
- Car shakes at low RPMs
- Distributor Cap for teggie
- is this worth the money?
- Any one to help ?
- Alternator/battery Prob
- Stupid question about spark and air filter...
- headlight question
- Exhaust leak from where?
- b18c intake manifold
- clutch adjustment
- Allignment messed up?
- Answers for a rookie
- Daytime Running Lights Problem - Please help
- Timing belt?
- Where Is A Jdm Conversion?
- Need Help Diagnosing '01 GSR
- The Difference between Intake valve springs and exhaust valve springs?
- window problems
- integra ???'s
- Apexi Dunk Loud or Not?
- Brake (stop) light switch needs replacing...?
- need help with intercooler
- how common is it to snap an axle in a gsr?
- 94 integra rs wiring problems...
- Finally, the piston ring thrend.
- Whats the difference?
- Help Tranny problem
- what exhaust for my turbo gsr?
- your 1/4 times n/a or turbo
- brakes, what kind are stopping your car?
- Starting Work
- converter question
- Replaced thermostat, whole new set of problems....
- so my radiator cracked...
- Starter, or not?
- ITR EXPO 4 DVD Teaser
- hit and run
- Part numbers
- How to change pads/rotors w/pics
- Most bang for the buck
- distributor: gs-r vs. LS
- Key won't take its turn...
- sorry, again, i'm new at this :P
- hello! i need HELP with my integra!
- Shocks and Springs
- Torque steer
- Gearing Question
- Rover Engine Conversion....
- new clutch
- Strut Bar Help
- cruise control problems on 95 ls
- Cat is flangless
- 94' LS Shifter / Syncro problems
- Left blinker flashing rapidly and there is NO burt bulbs
- Should i get this B18C5 head?
- belt slipping noise coming from intake manifold
- will water hurt a clutch or a flywheel?
- 95 tegra auto shifter locked.
- Strut Bar
- B16 headers in 91 Integra
- timing belt successful but.....
- Door Lock problem..HELP
- '95 integra starting problem
- Expo Logo Contest - Place your votes
- I really hope not..
- Think theres a difference in brands?
- Lsd
- Help Identify What's Wrong Wit My Integra
- Tire application
- grilles
- cam question
- Will prelude injectors work in 92 integra rs?
- Air Intake for GSR
- seat belt indicator
- Bad news
- new Integra owner
- DIY Icebox
- Eibach Prokit/ Koni Yellow SP3?
- GSR cam timing
- Teg Rods / Rpm
- Which turbo is the best?
- Difference between High lift cams and turbo cams?
- Variable/Intermittent windshield wiper
- Changing rear rotors
- Relocating IAT sensor
- Need info on Integra specs.
- Radio Section
- Where is a good place to look for an underbody spolier kit?
- Trying to find a part...
- Shifter Problems
- CEL po172
- just got turbo. need new clutch?
- tires for the teg
- exhaust question
- Type R injectors
- Wheel bearing problems
- Removing the ECU from 99 GSR
- Need for front end conversion
- Fawkin Curb Owned My Car!!
- Noise when pressing gas
- fender rubbing? 17" rims and 1.5 drop
- 1/4 mile time
- What kind of strut bar wont rub?
- Engine Light on 92 Integra LS
- Cooling Fan Draining Battery
- vacuum hose?
- 93 Acura Teg, Ls
- Car Seat Covers for 94 Integra
- Need new a/c lines
- auto tranny fluid change - hmm
- 2000 Jdm Itr?
- Notion to lock all general questions...
- New Pic of my R
- Buy a new RSX!?
- what is itr anyways?
- Best year/model Teg?
- B18C5 cam description
- 91 Integra b16a swap NEED HEADER!!
- 4door/2door g3 mirror interchangeable?
- noisy brakes
- drivetrain whine
- Need some Non-VTEC Hatchback exhaust help
- LS/RS automatic tranny question
- parking brake
