- Time to move on and sell the R!!!
- $400 for a middle pipe?
- Would this fit...
- Dist. Cap VTEC and NON-Vtec?
- ...Skunk2 Catback...
- Anybody here have 99up si wheels on their teg?
- Tranny mfr code..
- CEL Code 43
- Exhaust Questions
- are 01 R's have yelloe interior fot the top
- Does this intake fit on turbos and N/A?
- Just letting you guys know I am selling the R.
- Turbo, Or Port Polish+Tune...
- Underhood Noise
- Hello! I'm new, and have a lot of learning to do, but hi! :)
- Need help with internals!!
- B16 integra LS 4doors
- 86 Teg Intermediate Shaft?
- anyone knows any cheap insurance company??
- b18a valve cover
- What regualar maintenance should I do?
- 1996 Integra HB Question
- Give me an estimate or a guesstimate
- headlight question
- VIN# vs Serial# on armrest
- LS integra clutch problems
- hondata s200? should i get?
- need help with my turbo teg' ? what should i do next?
- scraping noise, power steering compressor suspected
- specs
- Help Lost Lug Lock Key !!!!
- Integra alternator question.. is this the right pulley and connector?
- Can I use an auto LS ecu in a manual LS?
- Rally ITR
- distributor king
- newbie here
- block girdle
- Type R oil pump
- Rear Defrost Not Working!
- Got my R
- Where can I find replacement rear quarter panels for my car!!!!!!
- sunroof weatherstripping
- Exhaust Problem..:) Suggestions.. from the pros..
- srs
- Valve cover
- What price
- turbo or type r motor
- Help changing ITR transmission fluid !!
- itr carfax please!!
- S mode
- HELP I cant get into gear? whats the prob
- which brake pads
- Bad Relay??
- How do I disable seat alarm? - Gen2
- rear wiper sprayer question
- Wheel
- Upper control arms
- SRS light on
- I think I have a loose valve...
- Stupid suspension question...
- Weird shaking coming out of a turn
- Running Cold?
- Charcoal Canister Problems
- Clutch/Synchro Prob
- DC2 versus DC5
- Car Totaled
- getting into my gauges
- What Size Tires Can I Use?
- Need Buying Advice Fast
- What all comes with a skunk2 IM for a gsr(in the box, i got one NIB)
- Horn/Cruise/SRS failure?
- 87 clutch slipping
- Screw Shipping company's
- Trunk release inside 2001 Acura Integra???
- reverse glow gauges
- Luminescent Questions
- What sounds like Apexi DUNK?
- cat length
- Bushings
- Headlights: Low beams not working
- wanting to do a ls/vtec on b18a
- Problems after Car Wash
- Is this car worth the purchase?
- Head change
- Breaking in a New Clutch Required?
- b18b1 whp ??????
- Integra Vs. Civic
- '94 Integra GSR coil replacement Q's
- HONDA ECU website
- Problems...
- What's the best place to buy fenders for 98 teg?
- Stock cat length for 2000 LS sedan
- Driving with a Cel 67
- need tires... wha should i get
- Eibach Lowering Kit
- Installing a freshly powdercoated valve cover...
- Water Leak Tip - '94-'01 Integra Hatch
- Are fenders the same on 94-97 and 98-00 integra?
- grounding / electrical problem?
- Throttle Sensor Question
- What tires to get? (205-45-16)
- weird whistling noise?
- 91 GS Noise
- 90 RS Antenna
- changin axle
- Guage Cluster and Climate Control
- My site...
- :revised:
- 98-01 Integra Extreme body kit to TRADE for stock bumpers
- Help!! 1995 Integra heater control
- 98 wings west rs kit
- type r rear sway bar question
- USDM ITR Fog lights
- Straight Thru Cat. Converters?
- Help ABS light stays on 95 GSR 4dr
- 1992 Acura Integra RS radio system
- Antenna....
- 93 ls alternator output
- Bore Honing
- jdm 96 spec 98 spec charts
- Tein SS for ITR as daily driver
- Tranny Griding Question
- timing belt and water pump question
- dip stick is burnig?? why
- Hydrolocked...!!!!!
- Mods for my 94 Integra RS
- Intake Question
- Gauge Cluster+ Clock Failure (broken?)
- Will an 94+ guage cluster fit in 93- Integra?
- Water leaks in my integra
- Rearveiw Mirror Paint Help
- what color is this teg??? PICS
- Pistons
- Hello everyone, I will also be moderating this forum
- how many miles should a b18b1 typically last
- Wooot
- Squeeky rear end
- Best price on headlights for a 95
- Low Compression in cylinders..
- LS..Temperature problem...HELP!
- ...Interesting Story...
- Technical question, AC-need help!!
- Mechanical or Electrical Gauges?
- question
- progress camber kit
- Help
- 2005 ITR Expo Registration Deadline Hits January 24
- anyone knows?
- automatic to manual trans help
- HELP - Fuel delivery problem on a 95
- Are the sensors on a 97 type r same as 2000-01?
- Are sensors same on 97 type r and 00-01???
- Shift Point
- suspension basics
- '93 LS Drive Axle Problem
- what car is a better deal?
- wont be posting in here anymore!
- how to tell motor year
- URGENT: Flashing CEL
- speedometer wobbles at high speed
- ignition signal voltage? b18c wont start!
- Quick Questions
- 98 gsr factory alarm/keyless entry
- Dees Butterflies
- Broke Caliper Mounting bracket bolt
- Transmission noises
- OBD II version B ECU
- I need pics of 00-01 Integra ECU.....
- what to do for 6.5" speakers in back
- A'PEXi N1 exhaust
- air intake filter separate apart while driving....
- Irratic Idle And Code 21
- windshield leaking?
- what move to make...
- comptech sport springs or eibach sportlines?
- New here, front end swap??
- 94 integra rs
- JDM Brochure Scans
- help! jdm b18c swap no spark
- help, integra has a weird starting problem
- I need to get through firewall!
- strange electrical problem
- broken spark plug
- Anyone have pics of 00'-01' Type R ECU??
- tell me how low i should go
- Stolen 96 Integra
- DC2 questions
- which springs for 4 door gsr
- 96' GSR with 96' Spec R swap.......help
- 96' GS-R conversion harness for Type R swap?
- Im impressed... ITR Quicker than a cossie?
- j's racing intake
- B20 Built VS ITR
- S2000 antenna placed on a type r??
- OEM alarm/keyless entry
- new tranny is grinding have some questions
- ...Ohh Shhiiiiii GSR PROB...
- I found the squeek and you'll never guess what it was...
- I know that Sports Car...
- ITR differences
- coilovers
- Type R LSD Install?
- tail lights where to get
- Exhaust manifold busy-ness
- some help please
- Porting a B18A head
- Upper Control Arms
- Idle Problem
- Vtec Problems
- Manufacturer's recommended maintenance?
- clutch troubles
- DC2R Mugen Lowdown Sport Suspension FS
- Powersteering Loop
- Has anyone done the front end.....
- my thermal exhaust
- Turbo Help!!
- Help with a link please?
- Hello everyone...
- cam help
- Whats up guys...another GSR here!
- AC Harness
- bad ground on tailight
- more problems ....
- 1yr later
- Winter Time!!
- How many lbs of compression?? B18A1
- '91 Integra GS or '92 Integra GSR.....which is better winter/commuter car?
- God****indammit! Car just got stolen!
- JDM Front End ITR owners
- European 15" ITR Wheels? Where 2 Get?
- Head Light Bulb Number
- ...Lovin' The GSR...
- How Many.....
- skunk 2 stage 2 cams or jun?
- New guy from AZ!
- Good Deal??
- carburetor and fuel vaccum line
- wheel offset
- OEM Fog lamps
- My Integra has started to squeek. Any ideas?
- turbo help!
- Water in the hatch
- do these motor mount inserts fit?
- Hey! Whats up.. New
- Has anyone swapped out their LS tranny for another B series tranny
- weird noise from under car
- Third Radiator for 97 GSR
- Mod List Help
- Heater fan problem
