PDA
View Full Version : Integra & '97-'01 Integra Type-R
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 [29] 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87
  1. need tires for 16'' what size?
  2. Hypothetically speaking...
  3. Looking for advice on these rims please?
  4. Whats a good tire for my car?
  5. Blown Head Gasket
  6. Cam Stages? 1? 2? 3?
  7. Hehe.. New Goodies Installed!!!!!! SWEET!
  8. Used Radiator Disposal
  9. pressure bleeder pressures
  10. Stock RS height vs. Type R height
  11. warning for what p.s. the negativity on this site is unreal
  12. Just bought an Integra
  13. motor mounts
  14. Could it be the govenor???
  15. Is this a good price for a 98 GSR?
  16. GSR VS Prelude
  17. 95 teg LS. Idle probs and release bearing probs
  18. pls help with suspension..
  19. cold air molecules are more dense
  20. Fine tuning a GSR?
  21. Speed sensor
  22. dyno numbers, anyone?
  23. Will springs fit?
  24. a/c
  25. performance eagle rods
  26. Will a 94-97 teg rear bumper really fit my 98??
  27. Air Intake Info
  28. Need Transmission info on 89 Integra RS
  29. bolt snapped on the trans case!!! how do i fix it?
  30. Idle prob
  31. Re: cold air intake causes valve damage
  32. Re: cold air intake causes valve damage
  33. 90 INTEGRA removing bumper????
  34. Backing Plate
  35. Which Transmission?
  36. Engine Light
  37. cold air intake causes valve damage
  38. how can i purge my clutch??
  39. Greddy Turbo Kit With Type 31 Intercooler On 00 Gsr
  40. Building up the ls engine
  41. LSDs? for 95 'teg GSR
  42. Please comment on flywheel condition
  43. hey???compression?? good or bad?
  44. rear wiper removal
  45. TURBO, what next?
  46. new noise from motor....?
  47. 95 integra ls idle problem
  48. Bad engine... need advice...
  49. Success on AT to manual Tranny conversion
  50. Need help with 89 integra
  51. need help with buying a car issue please
  52. Clutch Question
  53. How Do????????
  54. Heat shield removed (rattle cured)...should I replace?
  55. Engine problems...need advice
  56. integra transmission question
  57. dc header
  58. Gsr Lsd
  59. DC Short shifter
  60. Maint. Reqd light?
  61. halo headlights
  62. Too many damn dents!!!!
  63. Unstoppable Oil Leak!!!
  64. Need help picking a turbo for 96 GSR
  65. Track speed
  66. Integra Road Test/ Overview
  67. Street racing??
  68. 89 Acura Integra
  69. GSR Radiator
  70. my Integra is giving me a headache!
  71. Comptech exhaust and turbo?
  72. Fuel Tank Two Way Valve
  73. P72 ECU GU-GU-GU-G unit
  74. Tein basic damper
  75. cf hood
  76. 20 Grand Into my Integra NEED SUGGESTIONS!!!!!
  77. My GSR motor with ITB from gsxr 1000
  78. Quick Question
  79. drivers side window
  80. rear pillar bar
  81. Swamp complete.....car won't start!!!!
  82. clutch/brakes
  83. So, I broke a wheel stud today.
  84. Smoke from valve cover!!!!!!
  85. Integra Sedan owners. I have an audio question.
  86. need to remove drivers and passenger frt windows...help!!!
  87. Can't find my SERVICE CONNECTOR!
  88. 91 4dr project (noober)
  89. time to replace the head gasket.... is this any good?
  90. HIN Boston...
  91. GSR Sedan makes a great sleeper
  92. time to change the timing belt!! is this a good brand?
  93. Car Kicking
  94. b16 header in my LS?
  95. Driver door lock broken, help
  96. OK to crank GSR out to 8k regularly?
  97. parts?
  98. ••• DO NOT post "FOR SALE" Ads in this forum! ••• UPDATED - PLS READ •••
  99. Mysterious race between '94 Integra GS-R and '97 Prelude
  100. F20 type R swap
  101. cold air vs. short ram vs. ice box vs. ???
  102. head gasket maybe on my turbo gsr?
  103. idle problem
  104. Lightened Flywheel Physics - Horsepower Answer
  105. turbo setup for my 00 gsr and future plans/goals
  106. TPS troubles.
  107. 99 Integra Headliner
  108. Aftermarket Fuel Pressure Regulator INSTALLATION
  109. How Low?
  110. does it matter?
  111. New to the site, from Intencity
  112. 91 Ls 'Teg for SALE: New Jersey
  113. hooked up my vtec light, have a Q?
  114. Which 4 door integras had the hatchback?
  115. Corner light problem...
  116. Power door locks
  117. New Wheels, what to get
  118. Bad Tires On 97 integra
  119. Japfest 21st May
  120. Japfest 21st May
  121. Want Loud Induction!
  122. suspension
  123. ebay headers
  124. where can i get all 6 mounts for the gsr????
  125. Turbo Options
  126. Integra rear lower tie bar
  127. Turbo Timer Problem
  128. Starting problem
  129. gsr header on type r???
  130. Auto LS Integra turbo it? or not?
  131. Need help with Custom wheel identification.
  132. fake axxis ultimate pads?
  133. Eyebrows for teg ls one piece?
  134. Suspensioln!?!?!
  135. IACV o rings
  136. 97 bumper conversion to 98+
  137. 94 GSR motor into a 98 GSR
  138. 92 teg ls auto to mt swap
  139. picked up a free ride
  140. Whats the Best???
  141. Again!
  142. driveshaft cups
  143. acura of escondido on EBAY
  144. jdm front end?
  145. greddy type rs bov?
  146. body clips?
  147. speaker wires
  148. 2" Drop Camber Kits & GC's
  149. Deciding which intake to get
  150. 4 door sedan side view mirrors
  151. electronics install
  152. does 4-1 header fit 92 integra gsr
  153. Low compression & misfire...
  154. Help, Tail lights have a leak?
  155. car just dies out.. need help
  156. 1990 Integra Rs Help!!!!!!!!!!!!!!!!!
  157. rattle round 3200
  158. type r exhaust on a gsr
  159. Temp Gauge Problem
  160. Floormat ?
  161. LS valve cover
  162. Performance mods
  163. burning smell? on gsr turbo
  164. Headers
  165. Cost of internal mod to a GSR?
  166. top speed for 94+ gsr?
  167. Code 54 ***CKS Sensor***
  168. VTEC solenoid and spool the same thing?
  169. Alittle Insight from others
  170. New guy, new guy question
  171. 97 4 door sedan JDM taillights?
  172. Cold Air Intake For LS
  173. Slow accelaration and all, need help!
  174. Trying to remove the temp controls 94 Integra
  175. nasty sound when shifting to 1st and 5th
  176. Brand new headlights, need help !
  177. either getting jrsc or greddy turbowith inter for my gsr.Depends on which better deal
  178. 90-91 4dr integra?
  179. got a little thingy
  180. what do you guys think about my plan...
  181. Upstate NY
  182. my 92 teg
  183. Trade-in value for 1989 integra
  184. Headliner....??
  185. 2000 Integra. Idle'd Funny and now CEL is on.
  186. interior design?
  187. New Member
  188. Using CEL as shift light
  189. integra ls engine swap
  190. CAms?
  191. my 1st integra, NEED HELP!!
  192. 14.5-15 Na
  193. sunroof stuck...how do i take it apart ?
  194. Scary squeaking noise
  195. '90 integra, looking for advice on short shifter
  196. 1993 4dr integra ...help
  197. AEM SRI installed on my GSR: A couple of questions on the sound!
  198. just bought a 94 teg have couple questions
  199. greddy turbo kit legal badge?
  200. Euro rear bumper and tail lights?
  201. need extra info on turbos
  202. Looking for apexi vafc 2 wiring diagram
  203. Different Springs?
  204. turbo
  205. Just bought new header: Should I hang on to my stock Header?
  206. decided to supercharge my 00 gsr
  207. tire mounting & balancing
  208. Parts For You
  209. B18a1 question
  210. 98 integra, took long to start, engine light on, whats wrong ?
  211. Wanting to build a 90-93 integra rs motor I just bought.
  212. timeing belt tightness
  213. Fuel Pressure Regulator ANYONE!?!?!?
  214. issues
  215. My g2 won't start!!!Please Help!!!
  216. G3 Alternator Replacement
  217. want to get rid of my AEM CAI
  218. Need help to install a Skunk 2 Intake Manifold on 96 GSR
  219. Sloooooow seatbelts!
  220. suspension
  221. RPM Range
  222. Help please
  223. 94-97 Integra ABS light reset procedure
  224. Have you ever heard of B18B1's blowing up?
  225. not sure where oil is coming from?
  226. h22 swap
  227. Camber spec help, Dont understand
  228. Apexi World Series vs. Greddy SP
  229. homemade hose advice
  230. Apex-i N1
  231. 88 Integra with parts needed!!!
  232. Fuel Filter ?
  233. where to locate 94-98 cargo cover
  234. Lightened Flywheel + 91 Teg = loss of pwr?
  235. fan switch location
  236. Oil Consumption!
  237. E-brake sticks
  238. are the 1991 Integra 4 doors front bumper is the same size as the 2 doors?
  239. clickin noise in front??
  240. Turbo that's cheap like whoa.
  241. emply coolant overflow tank...
  242. dyno tuning?
  243. lose plugs and overheating
  244. Finding a Old GSR cheap
  245. Here We go again AT to slapstick
  246. fan switch location?
  247. Check engine light?? Need Help
  248. Jackson Racing High Boost Gsr
  249. Who has installed Halo headlights?
  250. Getting an CTR intake cam free, question is...
