View Full Version : Integra & '97-'01 Integra Type-R
  1. Air Conditioner Annoying Noises
  2. How to find whether the timing belt has been changed or not
  3. GS auto in an LS..Need to find ECM
  4. Life
  5. S4C Tranny in GSR
  6. hood latch adjustable?
  7. liquid gauge
  8. what kind Acura.
  9. squeeks!
  10. windshield wiper blade
  11. does prelude coilovers/struts fit integras?
  12. power window/lock problems!! HELP!
  13. 91 Rough idle w/ AC on
  14. Sedan Exhaust questions GSR/LS
  15. Fuel Injector Selection/Sizing
  16. Has Anyone Ever Done This....
  17. smoke
  18. saw these on ebay, are these any good?
  19. 5zigen catback *Picture*
  20. Question about gas
  21. exhaust options
  22. b18c gsr idle adjustment
  23. switching to synthetic oil
  24. Front Hub Bearings
  25. brakes giving me worries
  26. catback question
  27. blown fuses
  28. Click when Clutch is released/depressed?
  29. Exedy clutch and fly
  30. sleeving the block
  31. need help with my turbo in 92 b18a1
  32. In response to recent events...
  33. nasty idle problem bad gas milage
  34. well this sucks
  35. AC hose
  36. Please Help Carfax!
  37. jammed trunk lid
  38. integra ls antenna mast replacement
  39. Universal muffler
  40. Front Bumper
  41. Install front brake piston
  42. Finally Pix Of My Turbo Kit! Turbo!!
  43. a question about gas going very quickly
  44. help building b18a1 to handle 25+ lbs of boost
  45. New Paint Job
  46. MSD Blaster coil ?
  47. Trunk cargo area light problem
  48. A/C heating vent question.
  49. Ready for the Engine...
  50. How can i get a 98gsr to beat a......
  51. what r some basic mods?
  52. The key is hot
  53. help... stud for header broke off
  54. about short shifters?
  55. How much should 98+ gsrs be going for?
  56. light bulbs
  57. Slanted exhaust.
  58. What is wrong with my lights?
  59. any one selling a 94-97 teg
  60. Engine IACV ?
  61. Flasher Relay Location?
  62. G3 window motors
  63. theres a ratlle noise with my short shifter
  64. What Struts to get
  65. good short shifter?
  66. Gas Gauge stalls!!!!!
  67. 94-95 speed sensor OR 99-00 speed sensor
  68. High Idle with new Skunk2 Intake Manifold
  69. stalling and o2 sensor question
  70. New to Integras, just got a 98 GSR... what next?
  71. Awwww shiiiiiit. B-)
  72. Crank Pulley Nut Problem
  73. Embarrassing Idle
  74. B18b
  75. a problem with my rpm
  76. What kind of integra should i buy?
  77. Represent Represent
  78. Rear Brake Pads & Rotor Cutting...
  79. Spark Plug
  80. Type R Suspension
  81. w3rd
  82. Our Successful Turbo Install (56k killer)
  83. 92 Integra - Check Engine Light on
  84. can i change 94 integra alternator with a 95 civic alternator?
  85. V-AFC for GSR motor
  86. steering pump leak
  87. reverse grind
  88. idle problems
  89. remove side moldings
  90. Neuspeed spring questions
  91. >>> Stop Posting For Sale Items In This Forum <<<
  92. loose windows
  93. Transmission ????
  94. window won't work
  95. Does anybody take their Teg to get serviced at an Acura dealer???
  96. 90-93 and 94-95 o2 sensor???? where??? HELP!!!
  97. how to turn up my apexi safc2
  98. Clutch and fly or no fly?
  99. oil capacity for GSR
  100. Oil Seepage from Turbo Compressor Outlet?
  101. Fields SFC VTEC Controller
  102. Passenger side auto locks went crazy...
  103. i know something is wrong with my brakes, but dont know what part
  104. whats need to install fogs
  105. Boost
  106. Tein S.Tech vs. H.Tech
  107. Cleaning Up THe Front Bumper
  108. Anyone Know About A Main Relay, I Have A 92 Integra
  109. brake problem
  110. Hello, I I Think I Might Have A Bad Main Relay
  111. damn abs light is on my 94' acura intege Ls.
  112. Can anyone identify if this is aftermarket suspension.. what kind?
  113. Need help with getting car into gear on auto
  114. Help - Integra Tailight Signal/Fuse problems.
  115. brakes?
  116. 1995 Acura Integra GSR
  117. 95 LS transmission, square hole????
  118. front rotors on rear
  119. Burning smell from front wheels
  120. elec oil pressure gauge problem
  121. safc ?
  122. camber kit install
  123. My teg is shaking
  124. time to change my starter
  125. '98 LS telescopic antennae
  126. Brake banjo bolt
  127. ARP torque specs.
  128. will brembo rotors for 96-00 civic ex fit my 95 gsr?
  129. About my accident
  130. RS*R exmag not stainless
  131. slave cylinder is gone?!
  132. Greddy EVO2 Exhaust vs RS-R EXMAG
  133. hey was wondering
  134. 02 Sensor Diameter?
  135. quick question on gsr octane
  136. Car won't start - '96 GSR
  137. Jerez de la Frontera – 21st of August 2005
  138. Squeaky noise
  139. New Exedy Clutch Vs. Act Clucth
  140. B18c
  141. damn sensor
  142. Oil
  143. ODBII P72 in Jersey/Phila/Delaware???
  144. Starting problems. any suggestions?
  145. Need Help Choosing Lowering Spring
  146. Springs...help me out.
  147. Wtf!
  148. removing resonator for gas mileage?
  149. torquing??
  150. sway bars?
  151. high flow fuel rail
  152. Wtt 4 Hid
  153. Getting Antsy!
  154. My Recent Purchase!!! I love it!!!
  155. Cluster disfunctional!?
  156. b18b LS transmission fluid. how to???
  157. 1992 Integra Distributor
  158. My first car, what to do..(?)
  159. b18b-LS what gas to use?
  160. Integra gsr
  161. 4 door teg tailights
  162. Help???Name that Part?
  163. ls to type R or gsr
  164. harder to put in
  165. Timing belt/bent valves
  166. How's Every1
  167. The best place to buy camber/caster kits for ´90 Integra?
  168. Aftermarket shift knob question
  169. Starting up Rpm ?
  170. Clutch resistance?
  171. WTF is this!!!!!!!!!!!!!!!
  172. parts for my acura
  173. 95 ls teg - strangely overheating
  174. teh noobs air filter
  175. car jerking and engine stall
  176. Timing question
  177. Florida Cruise/Gumball Rally
  178. Florida Cruise/Gumball Rally
  179. car wont start
  180. Greddy EVO fitment
  181. short shifter
  182. limits of gsr stock internals
  183. 4dr Integra GSR
  184. lowering in NY
  185. window
  186. Engine quit, ck eng lite goes out on restart
  187. nitrous on 230k ls motor?
  188. teh noobs gauge
  189. b18c1 valvetrain questions
  190. Distributor
  191. header question
  192. trouble shifting
  193. Wiring in VTEC?
  194. RHD Conversion
  195. Torque steer?
  196. New exhaust w/o muffler.
  197. raced my teg last night all of a sudden 3rd gear wont pull no more
  198. car won't start after installing air/fuel meter
  199. fuel shut-off?
  200. Should I buy the Integra?
  201. Acura Integra is the Most Stolen Vehicle!
  202. Help!!!!
  203. No power coming out of the fuel injectors - HELP!
  204. Passengers´foot space gets wet... =(
  205. Buzzing In Steering Wheel ?
  206. Turboed GSR?
  207. Coolant in Exhaust! HELP! 1990 GS 209K Mi.
  208. GSR Poll
  209. throttle response?
  210. modification suggestions
  211. Uberdata Basemap Solid CEL (Shmoo help!)
  212. question ?
  213. window regulator
  214. squeaky clutch?
  215. Please Help new to honda tuning
  216. Car won't start
  217. 94 GSR Front Lower Ball Joint Tools
  218. Fender, and bumper cover replacement
  219. TB Gasket Picture
  220. coolant loss!
  221. b18 or b16 in my integra
  222. Couple of Questions
  223. Getting closer with my 91 integra
  224. turbo info
  225. oil filter on gsr
  226. drove the Nurburgring in an ITR...
  227. Front speaker question/help
  228. motor moung ??
  229. Opinions on N-Tercooler by NX
  230. HELP!!My check engine light is on!!
  231. am I getting ripped off?
  232. Bye bye GSR
  233. Im to rich..ahh!
  234. Speedometer stop running!!!
  235. interior
  236. psi ?
  237. clicking noise
  238. Auto to Manual Swap
  239. Maintence Required
  240. accelerating problem
  241. runs for 10 minutes and then dies
  242. what type of setup would be best
  243. Timing belt
  244. clutch and Flywheel???
  245. 90 integra 4 dr swap with 97 gsr motor likely????? instructions????Guides????INFO pls
  246. ughh!
  247. Is XTD Clutch a good brand?
  248. Opinions on Big brake kits
  249. Type R wing HELP
  250. type R wing HELP
go
Search Engine Friendly URLs by vBSEO 3.5.2
