- freak LS motors?
- help - Car is throwing 6 codes,
- Climate Control Blower switch
- 96 Integra codes P0700 and P1705
- where is the Engine Coolant Temp Switch?
- camber-ingalls...help
- Turbo Pics-oooooh how nice
- 60k mile tuneup necessary?
- skunk2 IM
- 250whp (+-) B18b
- chech engine code p1607
- ball joint boot replacement: omni power kit
- headers
- Soon To Boost??
- ITR LSD into stock LS Gear Box possible?
- is this a waste of money?
- '94 Integra Starting problems
- Input on Clutch and Flywheel Upgrade
- shifting problems (high rpms)
- luvin my 93
- '87 integra pos
- New Car Choices?
- better body roll prevention
- Aftermarket Sway Bars - '91 Teg?
- headlights keep blowing? Bad Ground?
- Integra Tweeter size?
- Power making Fuel&Spark
- integra front seats all fit the same????
- Cluth Problem
- wheres the dipstick
- timing belt...how much is labor worth?$$?
- LS Vtech turbocharged with nawz
- a couple probs on 01 GS-R
- new rotors and brakes = squeek...
- Black car & CF, yes/no
- this is no pissing me off
- How much is a B18A1 and Transmission worth these days?
- used Greddy SP...loose muffler particles?
- throwing code for ECT sensor
- Blinking oil light
- Where can I find CEL codes for my 92 GS-R??
- Troubleshooting Intermittent Startup Problem on a Classic/Antique
- m/t or a/t half shaft???????? HELP ME
- Advice On Overheating and Major Leakage?
- radiator problem
- t3/t4 stage III turbo
- Parts needed for itr rear bar on ls?
- clear corner
- Rice or Nice?
- How hard is it to get sponsord on Integras?
- how to rebuid a ls 94 tranny
- B18C all motor mods?
- oil ? gsR/turbo
- Sedan owners...where can I get a window visor?
- 96 GSR engine - 90 GS 5spd tranny (will this work?)
- would you risk it
- help rough idle
- What's your mileage v.208
- 90 Teg gas tank swaps?
- new integra
- 185/??/15?
- koni shocks question
- b=series gaskets
- Sleeve or not Sleeve
- FRONT and REAR LOWER TIE BAR
- won't start/break down issue '88 LS
- does gas octane really matter?
- 2000 Integra GSR stereo
- Another Turn Signal Problem
- Cooked brakes
- N/A teg times
- new to the family any advice
- Settle for a pre 98 integra?
- A/C removal
- difference in fuel reg.?
- will this help me any?
- Ecu Reset
- Windshield molding
- Integra Rear Interiors
- Integra´90 in Finland, do you like it? =)
- Vtech Silenoid?Different types?
- 90 Rs Engine Bay
- shotty exhaust shoot out!!
- #3 Fuse keeps blowing please help!
- ...and what would this be?
- rain...what do i do????
- pictures
- Rwd Teg!!!!!!!!!
- injectors
- regulator
- F1 Clutch Input
- Have you ever had the crank pulley swallow the lower timing belt cover?
- throttle body-worth it?
- **NEW DC SPORTS CS-2 Strut bar prototype picture
- CEL Code 12
- transmission problems
- New Type R Owner Checking in
- psi on stock b18- internals $$
- type r compression
- Rim revival tricks??
- Maint Reqrd < light came on
- 91 integra heater
- Turbo help
- Replacing Rack And Pinion Boot
- problem with seat belt sensor
- Stock springs from other hondas fit on my 2G?
- cv question
- coolant
- instrument lights
- cold air stuff
- ¿how much would it cost?
- gsr trans. fluid bolt!!! HELP!!
- gs-r engine mods??
- turbo parts info
- wheel database?
- conical filters: inverted vs. closed-top
- DC Sports Header???
- Heater isn't what is used to be...
- The plastic CAM plug is leaking again..
- Exhaust manifold painting?
- header question
- junk yard teg
- condenser fuse
- Best exhaust system for all motor B18C?
- Heater
- Altezza or stock taillights?
- car wont start, help?
- Japanese Counterparts?
- Tranny swap
- Leakin Fan.... Help
- ECU Question
- GSR knock on start up
- Engine Running Hotter than normal
- FS: Four USM Integra Type R Gunmetal 15" Wheels Excellent Condition
- Piston kit or Stroker kit???
- turbo parts etc
- Does anyone know bout the toda individual throttle body system?
- Some1 who knows bout toda&the individual throttle bodies
- integra go out alernattor probleme
- I think my axle went bad, input please.
- cleaned (port&polish) throttle body...crazy idle
- Worth Keepin My Teg?
- Help...Won't Start Any Suggestions!!!
- Installing my short shifter tonight
- What are you guys using for tuning?
- Replacing window regulator.
- clutch slave????
- Little problems or maybe big!!
- what does it sound like
- Oil Return Line. I am stumped!
- Horrible problems on swap
- new wiring harness?
- Oil/ Water Temp and AIR/Fuel Gauges Installation
- inlet and stock like muffler
- gsr died on highway
- Is it safe to powder coat calipers?
- Shift Lock Help!!!!!!!!!
- New owner
- Intake and Vacuum line "elimination" question
- Do honda dealer service a teg?
- DTC Code P0181
- DTC Code P0181
- D4 light blinking on dashboard
- Spotted: P06 ECU Cheap on eBay
- Testing the water on my Type-R
- '92 Acura Integra HB - Help - Will Not Turn Over
- what horse power does my teg have
- How good is this turbo kit??
- 92 integra ls
- Aem Intake 98 Gsr
- I think my friend blew my engine. Help
- upgrade the radiator?
- Cleaning B18 Valves? Scotchbrite?
- What does an S80 transmission come off of???
- Integra OEM Spring rates
- what kind of wax do you all use?
- 90 Integra GS hatchback: Interior door latch?
- 2G cupholder
- Pin Outs For Ecu
- Head light trouble
- Brian's Clutch Summary! YAYYY!
- Clutch Replacement guide
- wastegate gaskets
- 90-93 integra mounts/throttle cable. same as 94-95???
- Looking For: Rolling Chassis, rear axel, control arms (rear)
- new clutch for the gizzer
- Distributor Wiring Question
- A/C Condenser Belt Question
- plastic trim
- newb lookin for integra
- 2.5" pointless on DD
- Speed Shfiting gona bad
- Horn Wiring
- 93' Radiator help.
- How do I fit the ITR JDM 5X114. on my GSR?
- so i want to remove my power steering
- turbo manifold keeping a/c & p/s
- skunk2 vtec controler instal help!!!
- ODB2 -> ODB1
- Dipstick tube is loose? Anyone else experience this?
- Dash Light Bulbs
- Ah yes, the actual hard part of upgrading my clutch.
- My horn stopped working. Help!!!
- so my brake light came on
- MPG vs. Flywheel Weight
- gsr driving erratically
- New Kid on the Block
- 98 GSR radiator damaged
- Taillights keep fogging up.
- nastiest G3 taillights ever?
- idle adjustment screw
- problem with backup lights
- Buying B-Series Turbonetics Turbo Kit
- major turbo help
- Another antenna question, but slightly different.
- Prob with my stock alarm!
- Are teggies prone to leaking oil here? Pic inside...
- Video of ITR at the track
- question on hangers
- Itr ECU Euro 99 spec
- My fan stays on after I turn the car off.
- Syncros?
- Radiator fans come on when car hasn't been running for a couple hours?!
- Difference between '90 and '92 and '94 models ?
- Need GSR ECU have Type-R
- Engine differences in 91 - 92
- tranny spools
- GSR to TYPE R tranny...good or bad
- oil problems
- What your T/O bearing SHOULDNT look like.
- Replacing Timing Belt: Brand? Special Tools?
- 95 GSR: Do i need a fuel rail w/ new turbo setup
- frozen caliper?
- B18a1 How To Install Timing Belt Walkthrough
- Do any of ur clutches feel like this?...
- will gsr cam shafts work for my b18c5?
- Redline
- squeal/chirp during acceleration, possibly alternator bearings?
- lifter install
- Unlock Code for Stock CD PLayer
- 91 Integra Automatic Tranny Swap HELP!
- Please diagnose my clutch symptoms
- itr lsd
- Energy Suspension bushings
- Stock re-build for a B18A1?
- Blah, clutch install help asap please!
- mixing???
- Trany
