- does anyone know how to stop the beeping noise from the seatbelt indicator???
- Pics of jdm integras!!!!
- 90' integra
- fuel pump
- Sound Deadening Material
- Gas Leak by Fuel Injector #1
- MSD, advance or retard?
- Post your MPG
- Adding power
- will 99 civic Corbea racing seats brackets work on my 00 gsr?
- My Integra!
- noise from engine at start up? 1995 LS
- Back Tire, LS
- 4dr side skirts
- Early Vtec???
- Opinions on lowering?
- My Wheels....
- K&N Filter part #
- NA or BOOST
- Rims Question
- horsepower
- so im sure its been asked 100 times... but i DID use search ;)
- turbo
- ground wire voltage and stabilizer for my GSR
- I need an integra guru!!
- Have A ??
- This My Co worker???
- Hooking up Kill Switch to Rear Wiper Switch
- Which tires should I get for the wheels I just put on my Integra.
- 17" Wheels on Integra
- Coilover Question
- testing alternator????
- soft brakes
- bumper???
- oil consumption and timing belt
- Diameter of 2K Teggy center caps??
- Tranny problem... Please help!
- stock shifter
- Can I fit OEM optional Type R sides onto my 4dr?
- teg radio... HELP
- compression test...
- Headgasket
- Trans Noise?
- OEM WRX turbo
- intercooler spraying
- i want a carbon trunk 4 the 4 door
- what kind of oil should i use?
- Bypassing the O2 sensor for Cat
- 5 lug conversion
- exhaust
- turbo my teggy
- Rim Repair (Scratch Removal)
- scratched cylinder wall
- About upper control arms... *HELP!*
- staged axels?
- Most stolen vehicle in US... 99 Integra!!
- shifter bushings
- Throttle cable for upgraded IM
- Has Your GSR ever done this???
- 94 teg problems
- JDM HID Problem
- humming noise from engine
- What do you think?
- LS intake manifold removal
- Engine overhaul help/assistance?
- 1989 integra water pump replacement
- 94 Integra Project
- this actually work for the turbo
- temp sensor question
- Hahaha What Was He Thinking
- Need to do a brake job...this a good deal?
- best instake piping for a turbo?
- gsr rebuild?????
- Someone hit my teg today...
- Type R cam
- RSX Conversion
- 97 integra asking price
- Things that drive me nuts about my GSR.
- ABS light acting up?
- For everyone who owns a ITR, please look!
- Umm...brakes? please help!
- Cheapest good cap/rotor/wire kit.
- Threw a rod thru the block
- replacing a starter
- 4 door teg
- My timing belt story: 8 hours and few problems!
- oil change problem....
- White Smoke
- Transmission and IAT sensor questions...
- swap question
- NEed Help Fast, removing motor mount!!
- OK Brakes Froze Up @ local store car wont move now HELP!
- Rims???
- Help protect me from my Scary Brakes
- Maybe you guys can help!
- Car Audio place ripped me off......
- b18a1 vs B18b LS
- power steering leak
- teg is shaking at 30+ mph
- Help with rear brakes on '98 Teg
- I accidently started car, without the #1 and #3 Spark plug wire connect to the PLUGS!
- need new shocks struts
- Tire size recommendations/suggestions.
- integra website
- Buying a 94 LS, worth the $$$ ??
- Turbo and transmission for an automatic
- blown piston rings.
- Wheel Covers
- electrical problem.
- removing the plastic cam gear cover???
- Strange squeak/scratching noise...
- some quick help with IM install peeps
- need main bearing help!!!!
- Oil change, added a bit to much oil, should I worry?
- 2-door vs 4-door
- 94 Integra STOLEN in UTAH
- jackson supercharger in gsr?
- Adding hp my removing IAT Sensor
- Ignition problems!!
- SRS light
- obd1 tranny
- my buddy says
- clutch
- Help!!!!
- Abs Light
- Automatic Tranmission
- Timing belt & Water pump replacement
- Quesssstion about boost timing masters.
- Engine rotates but will not start; gas vapors
- I am a new teg owner what can I add to make my automatic car, "respectable"?
- proper size downpipe and back
- Auto transmission fluid
- turboing a da, what else do i need
- Like clockwork...
- ITRCA, have you been there recently?
- B18c1 Rebuild opinions (m22xx/jdm itr pistons)
- help
- HELP!!! Reading dipstick and some tranny issues.
- Honda MT Fuild vs. Mobil One
- "Ruby" tail lights???
- Help on changing oil pan!!!
- Guage choosing, HELPS
- sry noob question...:-(
- jdm vs. usdm itr cams?
- Help! Wheel stud replacement on a G2.
- online sites?
- JDM ITR Clip?
- 90,000 miles
- help!!! ashtrap screw problem!!!
- Head Gaskets
- throwing codes..17 and 67
- obd2 head on an 0bd1 setup?
- Cruise Control
- questions about installing oil pressure gauge
- better fuel economy for tegs!
- Fallacy about Sub Box(quick Question) in teg
- Fuel pump install
- Evo injectors on B18?
- Temperature Gauge goes to HIGH when at stop lights, shows normal temp when driving
- what should i do???
- Best exhaust for GSR
- questions about VTEC
- removing tranny?
- A good shop to rebuild my engine, North East Coast please
- USDM ITR header vs LS header
- Used trannies
- Help Locating Fuel Pump...
- Service Manual ??
- Im new!!!
- looking for bodykit
- damn smog
- What belt?
- LS/VTEC ITB's
- how much hp can a stock ls handle??
- ls/vtec parts
- ANother Dumb Question
- B18a throttle body
- 2000 civic SI muffler on my GS-R ????
- New brake pads and machining of rotors
- Odd Steering Problem.
- GSR-Hatchback driver side door problem
- vtec valve cover on a non vtec head?
- Drilled & slotted rotors for my 96 gsr
- Replacing sunroof glass
- Caliper ?
- seems like big problems someone help please
- whats this, how much and why
- New pictures of my Type R
- what car does this belong to?
- up grade my teggy
- IACV question
- LS/Vtec ECU Q's
- key wont turn
- 94 Integra
- Which size wheels for a '91?
- Install Help:Skunk2 Proseries Full Suspension
- Jdm integra pics
- 95 integra reving/slipping
- Buddy Club condenser wiring locations?
- LS Turbo
- power window problem
- HELP! the car die after i let go the accelerate!!!!!
- Chassis Front End Rebuild
- Motor Rebuild for B18C1
- obd2 distributor in obd1 car?
- Datalogger Analysis
- Quick ? Stock gsr throttle body size?
- Rebuilding Seized Engine (block?)
- Manic Depressive Sunroof and BTW, where is the freakin sunroof relay??
- How Much For All This????
- EMS systems
- Will you be there? WTDR Expo 2005!
- 94 Integra LS Climate Control removal?
- omni power camber kit Q?
- horn relay
- ALTERNATOR Question
- Help on removing air vents.
- Turboing a Type R
- how much did you guys pay
- difference between the pr4 heads
- Fixing Rust... Maybe
- front bumper bra opinions?
- Brake Light Issues, Suggestions?
- MAJOR DELEMA! 90 integra
- 94 Integra LS throtle cable adjustment??
- 9006 to 9005 headlight conversion?
- 96 Gsr Help
- HID's
- 90' acura integra
- Need help with installing rear coilovers
- Manual To Power Windows 90-93 Teg
- Hi everyone
- want to boost my teg
- Are you guys on strike
- how do I get the halfshaft off of the axle!!??? HELP
- A couple problems with my LS
- bong
- Vibrant
- hello
- What ODB really is my motor???
- Squeaking Noise From Rear Suspension
- wiper problem
- Dip stick...
- Cylinder head bolt
- i need help, burning oil!!!
- Just got my stock GSR, a few mod q's.
- Effects of high reving your engine?
- Turn Signals Not Working....help
- Can tranny be the only problem
- Water Damage
