- Gsr
- Question about B&M command flo
- Smell through ventilation system
- GSR codes...where do I begin?
- 1st gen CRV steering wheel on 94 Integra???
- code reading
- 1995 Ls Suspension Question
- Check engine light
- Ebrake problem
- lip
- >>>>>full Interior Panel Swap!?!?!?!!!!!! Unheard Of?!?!?!!!!!!
- my gsr sounds like a diesel engine?
- Sound Deadening The GSR
- integra models...whats the differences?!
- Need help plz on size.
- 94 RS listed with leather and sunroof?
- how hard is it to replace the IM?
- compression test numbers...i hope we did the test wrong... :/
- brake light going off WTF??
- New shocks for my 01
- GSR owners w/ intake
- USDM ITR Header question
- Am I missing a bolt? *pic*
- Need Reputable Shop in SoCal to Drop a Clutch
- This is getting on my nerves....
- New Type R Owner
- Cruise control and 5-speed questions
- Looking to buy my first Integra
- sticking cv joint?
- just bought typer moto for only 950
- totaled my gsr on Chrismas :(
- Still having problems
- Rsx wing to Integra
- Finally got the $
- SES after replacing distributor?
- RSX of teg
- Idle Bouncing
- S2000 Spoon Calipers.
- gs-r buy? yes or no
- Please, just a little help from someone !!!
- I need a cat!
- not running , no spark
- New Member..
- 96 coupe leaking! Fixed everything i can think of! please help
- hit a rock
- Quick 5zigen question!?
- sawp form nonvtec to vtec
- gsr aftermarket cluthes
- B-series Transmission Question
- Moderator help
- Dropzone struts...any good?
- Jdm Front End Paint
- 92 GSR mods
- emissions failure question
- Please Help My Integra Gsr Cel Is On
- changing over
- how can I limit the door to slam?
- Code: 1 Oxygen Content
- 01 Gs Teg (r.i.p.)
- ecu problems.
- clutch sticking
- First DIY - brake pad and rotor replacement
- acura.gsr and honda prelude vtec
- JDM ITR b18c into DC2
- Dear God =O
- is this normal?
- Power Question??
- ES: Motor mount inserts
- Gears Grinding Like Hell
- Best headers?
- What would you do? What do you have? What would you do?
- front carbon fiber lip for a 95GSR
- Will be replacing brakes myself...any helpful hints
- Need some insight...noise from brakes.
- 00' integra or 02' rsx ?
- big problem guys...
- can the starter be swapped from diff year or civic
- questions about engine
- Fuel economy
- Buying clutch, not sure where....
- o2 sensor for air intake
- needing help on the AC uninstall
- 00 Integra GSR:Having problems starting! any suggestions?!
- what year is the best GSR?
- Tusdo catback fitment, help
- 1994-1997 equipment difference RS and LS
- JDM B18c and emissions ...
- need help on deciding [what to buy next] {MERGED}
- acceleration question
- itr insurance
- Thanks HAN!
- need free carfax reports..look no further....
- Jumping idle in 94 teg
- throwing codes and car won't start most of the time...
- opinions on championship white
- flushing my tranny oil in my 5-speed 96 teg
- Final Release of my DC4 Turbo Integra - 12.529 @ 112.393 - Dyno Videos - New Footage!
- Indiglo guage
- Is my car dying?
- mtec bulbs....
- my gsr is having alot of carbon build up!!!
- 9006 Headlight Upgrade!
- 01 Gs-0r-05 350z
- obd1 or obd2
- Best price for Comptech header?
- Cylinder leak down test...
- E Bay Header's Any Good?
- carfax for '99 gsr
- jun 3 cams and vafc tunning
- help: how to install a throttle position sensor on a 1990 GS
- Pic of lower control arm?
- 89 integra starting issues
- Gs<gsr???????????????
- Removing front fenders {MERGED}
- tranny oil
- ls vtec?
- need a good clutch/flywheel
- Noob, saying hello, few questions
- xenon hid light bulbs question?
- anybody know?
- Help!!!!!!!!!!!!!!!!!!!!
- Michelin Pilot Exalto A/S
- Curious about turning GSR into ITR
- Brakes Issue 98 Integra LS Sedan
- Swap price
- Test pipe check engine light
- integra pedal assembly
- Is it Possible to change the oil pump without removing the engine?
- Get Oem Parts
- forced indo
- pedal assembly removal
- Can't remove alternator..need Help!
- My friend's 96 LS....
- 94 Integra LS
- Sell my LS and buy newer
- Engine mounts
- ATF Fluid engine flush?
- Tein Type Flex
- My car fixed itself.
- Type-R OEM Flywheel Weight and Visuals
- Power Antenna + Aftermarket Stereo...
- Looking for online car manual
- GSR Turbo vs. All Motor
- rear hatch
- Need some help setting timing....
- header questions; 93-94?
- FINALLY got a tranny!!!
- Nitrous help?
- I'm stilll having problem with idle
- Squeaking
- Helio Coil on block?
- passenger power window prob
- i need a parts list
- CTR Piston question
- goin with amsoil..what u guys gots!!
- car sputters need suggestions
- are these skunk2 coilovers worth $81
- engine turns but wont start...whats the problem ?
- Steering wheel question
- 95 GSR is it worth buying?
- is BF Goodrich Sport a good 16" tire?
- B18C1 Block Deck Clearance Troubles
- Acura radio error-3 message
- 01 GSR Bumper
- Distributor cap and rotor keeps going bad...
- coil over suspension
- bulding b18a
- 96 SE teg, More tranny problems...
- frontend
- gear box is stiff
- tranny swap auto 2 manual
- Suspension...
- My new 1997 jdmspec type R
- Body panels
- 96 Acura integra wants to stall wen im just letting of the clutch
- ECU Compatability
- from auto to manual, how hard is the labor?
- Advice Please...
- Anyone have satelite radio in their Integra?
- ECU doesnt flash
- ITR Expo 6 - Gingerman Raceway June 12/13
- Turbo question
- Water leak in passenger side
- Rubbing ?
- my auto integra ls in the 15's with common upgrades
- I might purchase 1994 Integra.. but..
- my car
- rear quarter rust
- Heater
- Timing belt
- 3 angle grind advantage.
- 1990 integra has no spark
- Integra GSR with retarded heating system
- Intersting video but unrealistic #'s
- Who ever thought that.....
- about to buy a 1995 GSR
- crashed my teg help!!
- need help
- LS to GSR Exhuast Compatibility
- crankshaft position sensor 94 integra
- Finally!
- car won't heat up
- Test pipe with rsr
- Front LCA for G3, same as Civic 92-95?
- acura abs?
- '96 5 spd transmission types
- How do you find Honda numbers for Acura parts?
- Car Stolen [Update: Recovered, but Stripped]
- sell or fix
- Building a turbo kit for a GSR with $800
- Lowering and Body Kit
- just checking
- im getting a 94 gsr for $600
- car sputtering!!
- stock b18c1 hold 6lbs boost safely?
- which bushings are critical?
- Jdm Climate Control.
- Firewall Plug fell out of Rear Wiper Hole
- Stock Ls Rim Offsett???
- Tegs in snow
- how low can you go?
- ABS light comes on when driving
- help me decide on exhaust
- First Mods For A '96 Teg GSR
- 98GSR Timing Belt/Water Pump?
- Ls Rim Question
- when are stock gsr shocks worn out?
- O2 sensor heater circuit malfunction??
- weird fan problem (i searched)
- Installing dizzy
- noob here about to get 95 RS
- 1992 Integra LS 3dr Blower motor, switch
- starter relay fuse
- convincing info about itr's.
- Turbo help??
- Head gasket replacement from hell!!! need advise
- port and polished 97 gsr
- Help decide first mods
- steering oscillations....
- IACV wiring question
- 1990 Acura Integra with Emission Problems
- Gsr Lsd
- type r ecu on a gsr
- Wiring in Type R vs. GSR
- Installed my Skunk2 manifold and CTR cams today
- Another turn signal thread
- Wires
