- ES bushings install post-game
- Advice Please?
- 90 spoiler on 88 Integra?????
- cams for gsr
- How to replace side rear view mirror?
- hks hi power exhaust
- Car is knocking and stalling out in neutral
- Cylinder head rebuild
- GSSR's retrofit: These pictures do it justice
- simple Q
- gsr swap help
- function form coilovers
- what whould be better?
- Is this ok?
- Honda financial refinance offer.
- *Searched no luck* how to tell the difference between alternator??
- PLEASE HELP ME get this oil crap to work!
- Heater switch problem??
- found a foreign object in my ecu?
- Fuel Injector Issue.
- My AC smells bad
- question about ECT sensor
- small radiator leak
- kind of oil and rad fluid
- ITR and GSR valvetrain
- engine swap (TL or CL)
- sinking brake pedal...
- Yet, another Stolen Type R :(
- a very sad end to an all to short story..
- i need ur help
- My ramhorn...fix it or leave it?
- funny oil
- FooD's Custom Turbo set-up
- 1987 Integra starts sporatically...
- Motor mount
- Vtec head, missing parts
- I finally did something with my lame PCV system
- AC Refrigerant Type
- GSR 120,000 Miles without Timing Belt change?!?!
- Want To Run Crower 402's Or Jun Stage 2's
- best suspension setup
- integra 4 sale
- 94-01 Closest replacement shift knobs
- eagle manifold and vac lines
- transmision
- Test Pipe Question O2 sensor
- bigger pistons or not
- please explain tire sizes
- Obd-2---->obd-1
- getting a new trans, which one?
- how many own second gens?
- Idel problems and oil burning
- shitty ebay intake? (SRI)
- b16a1 question
- Wheel assembly??
- Possible vacuum leak
- HP an torque gains?
- 95 Integra LS. Electrical Issue
- Turn signals :x
- b18c swap
- performance injecters
- 01 itr & 00 lude cat. converter interchangable
- ebay catback system
- Do my plugs look ok?
- How to set the timing on my Acura Integera.
- altenator help
- Bogs bad past 3/4
- weak ass turn signals
- ITR Lip ITR Rear Wing
- TRD, Mazdaspeed, Nismo, what does honda/acura have.
- Question on Headers...
- tranny questions
- Catback or Muffler?
- HELP Please
- cd changer on stock 95 radio?
- News
- Rough Shifting
- Where To Buy Oem Pistons
- clutch pics and a question
- ls vtec intake manifold
- side molding
- Sun Roof drainage tubes
- Need part number
- 4 door integra ls, worth $10,990?
- may want to check scammed thread
- It's that time again!!! May Meeting for ITRs Only. Brooklyn
- so uh, like, what's the LS redline?
- where I can get cheap '00 F. Bumper
- any heard of ERICKS RACING?
- Well here we go again...another garbage dizzy
- Upgraded MAP?
- 99 gsr oem spoiler
- help with the alternator
- Headlight???????
- GS-R - A Type R
- jdm Intake mani
- just bought a 92 integra
- suggestions.....
- fan cut off
- Trunk Part Question
- I Need A Transmission
- rims, what size is the best?
- different front end...
- Hks Ssqv?
- Uh-Oh i crashed it :(
- Integra Type R 96 Spec!!!!!!!!!!
- suggestion for a 1993 teg rs
- Turbo on GSr w/high mileage
- Exhaust question
- IC is hitting bumper
- Lost Clutch Pressure...
- My First Car (94 Integra) Someone help me identify it? Pics Inside!
- What do you guys think of these ebay headers?
- Weird Idle in my 95 Integra LS
- few questions about oil pan gaskets.
- CVbootRepaired
- Porting the LS head, viable option or no?
- Abs Light Wiring
- Best combination
- emissions close to fail - low speed HC
- Big enough?
- ITR lip ????
- rim offset, bolt pattern?
- teg qualitys
- Race gas/timing
- 90 Integra air ride
- Ditch the gsr trans for a LS?
- DA Integra rear upper control arm?
- full catback system
- Leaky Radiator - Hairline Cracks - Pics Inside
- Help!! Possible Susp. problem?
- Good price on teg?
- AT/Drivetrain problems
- p1399 integra 2000
- Painting chrome jdm integra housing headlight
- b18b question
- Just got my injectors in-PICS
- The best header?
- VAFC...Best Setup!!!
- ITR Exhaust on GS-R
- Port and Polish?
- gas leak at fuel injector...
- head job
- Need help with 91 Integra
- Question about buyin a Integra
- need a new engine
- looking to avoid a scam!
- Yonaka Motorsport
- My Integ's Door keyhole mangled
- 2001 ls
- well... i finally let my poor gsr go today... now i can move on...
- PCV install
- rebuild in progress
- To Boot or not to boot
- knock sensor
- maintenance required
- plastic conector for front turn signals
- How to bleed 94 ABS system?
- Idles Up And Down
- radiator support spot weld
- Hayame catback Exhaust system
- Interested in buying an ITR
- gauge cluster....
- do I have a deathwish? (if so, you gotta tell me...)
- Changing the final gear of a GSR to LS
- what will go next??
- rough idle
- Towing a 1991 integra - manual trans.
- chip or replace this ecu without building bottom end?
- ~best way to soop up ur integra fast~
- I Need Help
- 95 integra headlights
- someone help!
- how easy is it to change the brake light bulb?
- Factory Optional Fog Light Question......
- Arm Control Bushing 96 SE Integra
- seats
- Rebuilding Tranny
- Type R tranny
- type-r parking precautions?
- carfax help
- Need advice
- tire size??
- wierd loss of power?help?
- coupe rear seats fit into a sedan?
- .H.E.L.P. Why wont my Teg go faster!
- A little advise on moding my new teggy...
- Check Engine Light
- Leaking anti freeze
- Rims for my integ.. Rota C10's
- Turbo Complete at 8psi
- where can i find the cheapest AEBS mani.??
- got CEL probably my HIGH FLOW CAT
- Just About Done
- GSR vs Infiniti I35
- Once camber adjusted?
- Keep P/S or not?
- Keep P/S or not?
- Newbie... with a couple questions
- So a new video of the n/a beast..
- Carbon Fiber Hoods??
- axle not going in!
- Say hello to my little FRIEND
- Info on My time slips?
- The numbers...finally!
- turbo beginnings
- how do wastegates work
- Is it normal??????
- brake issues
- engine problem...
- itr internal in a gsr
- LSD: OBX vs Quaife
- Really Bad Oil Comsumption
- any one from slc?
- manual trans price
- OEM shift knob question
- rebuilding caliper?
- im looking for a thread....
- How Many Miles can you get out of a timing belt??
- afraid my car will overheat
- 93 swap question
- My Engine Light just came on (97 Integra)
- Went for a ride in a boosted teg today!
- Vtec Solenoid
- powerlock relay?
- heating problem
- AFPR with Zex dry kit?
- why does my exhaust sound like a bee.
- road noise after rotation and balance?
- Preping oil gauge, help
- How much would you pay for a used Greddy turbo?
- Is this gona be too loud???
- bad bearings= no brakes? Help!?!
- Help- no brakes- bleed+new master cylinder
- Running Lean Questions
- Strut bars
- Integra Aftermarket Options
- HELP! First time this ever happend
- oil pressure gauge reading wrong
- Increasing the flow. One of my last engine mods.
- Electrical issues
- looking for lower ball joint nut
- abs codes
- buying a GS-R...good deal?
- Question re: Low Impedance Injectors [DC2-Turbo]
- Integra upgrades, please help.
- Racing seats on a 1991 Integra?
- Is it worth is or am i getting ripped off??
- New Numbers On AEM UEGO GETTING CLOSE?
- possible dc4 future owner, any known issues?
