- type r limited slip differential
- CEL code 1...a year later.
- 89 wreck for guru
- I need help..
- 94 Integra Holley Exhaust
- abs removal
- Help me decide on suspension
- Suspension Project
- Rebuild
- My Ecu got wet, is it alright?
- O2 sensor wiring help
- Clutch and Flywheel installed
- Got scammed on ebay, can someone ID this Harness for me???
- Reuse Arp Rod Bolts?
- hard start in morning
- B20 vtec crank balancing??
- Integra DA with b16 Idle problem..
- Crankshaft Pulley Wrench
- anyone with a 99 gsr supercharged
- Remove These Valvesprings!!! [Merged w/ Tool Query]
- window tint problem
- Type R shift boot
- need help with dlr
- New Teggy Owner
- Diagrams for Integra LS B18B1 REBUILDING
- 4 door GSR - how many owners?
- Will my car BLOW UP or no/HELP!
- Looking @ 96 GSR 100k miles, should I worry about reliability?
- Exhaust is done and on
- Quick Power
- 1999 GSR CEL Code 72
- Gas problem
- What will fit??
- 91 Integra?
- Bent Valve. Pics of the carnage!
- I Gave in to the darkside....and bootsed ny ITR
- Tuning Help
- Understeer - Hopping?
- Going to look at a 94 teg tomorrow.
- no spark to plugs
- Turbo GS-R Owners-Need Your Input
- I want to get some opinions
- Help
- Massive Help Needed!!!
- Trading in the '93 Accord for a '98 Integra
- Rear Running Ligts?
- question about gsr tranny
- Philosophical question
- How do you know if you need to rebuild your motor??
- Toyo Proxes4
- type r lsd
- Help! Wierd Stuff Happening...
- All Red 98 GSR Tail Lights...?
- Turn signal sockets HELP!
- intake and exhaust cam
- Lsd Tranny
- dome light wont turn on when door open
- !Put this suspension puzzle together! ITR strut, CRX LCA, and sway bar?
- drivers side window
- I Crashed....Where to get GSR Front End?...
- apexi ws2
- omni coil-sleeves with AGX?
- yet another A/C thread
- DC Headers
- Type R or Skunk2 Cams?
- K20 or Gsr swap
- Door panel
- radiator 1996 gsr
- Clutch Pedal Adjustment
- intake wearing on AC lines
- integra gsr struts
- pistons
- Help with a Coolant Leak
- Will a Knock Sensor from a D16Y8 Work on a b18c? Need Help!
- NEED vaccum Diagram for JDM98 B18c Did search no luck PLEASE Help ASAP
- dc2 turn signal
- Just got my RSR exhaust, but my GSR won't turn on anymore...
- cranecams
- Looking for a da integra anywhere between 1990-1993 for $2000.
- 94 B18B swap to B18c1 ??? HELP
- Dish me your theories on this odd problem (very stumped)
- Need a quick opinion from HAN on wheels
- Headlight Help!!!
- will the hbrace really work?
- swap conversion trans mounts
- 15's or 16's ?
- Help on changing fuel filter!
- Integra Alarm-need Answer Asap
- Stage 3 weight reduction, yo!
- Interchangeable CV boots?
- Type R cams
- b18c or b18c type r???
- IT STARTED!!! VID w/ question
- b18a1 crank pulley swaps???
- Some nice Pics Of ITRs and others
- head compatibilities(sp?)
- B18C Head Assembly Procedure
- clutch cable help
- Evaporative Emission Control System insufficient purge flow
- ZC spark
- Who makes the best slouted cross drilled rotor
- premium unleaded in an acura integra gs-r
- tanabe medalion concept g
- sinking brake pedal?
- Gsr Motor Mounts Need Help>>>>>>.
- Need Help with Climate Control!!!!
- Bench Bleeding the Clutch Master Cylinder?
- Funny smell at 80+ MPH
- shudder/vibration @ 55+mph
- Turbo GSR
- 2300lbs...mmmm
- ingalls camber kit
- First Integra on my hands!!!
- cel code 92
- D16A1 DOHC...sTuMpEd!!
- How Fast have you guys gone in your integras???
- 94 4dr integra door question
- 95 teg ac
- Suggested chassis mods for DA
- toda spec a2 cams vs type r cams
- Where to mount the air filter? PICS
- Where to mount the BOV?
- Lowering the front of an 86 integra
- Exhaust for my 4 door integra
- cruising rpm for 97 gs
- My GSR still shakes
- tail light
- GSR Valve Chatter above 2500K
- weird idle possible vacuum leak?
- ignition question
- Low beams, High beams...confused?!
- The way integra fans work?
- Is an Integra a good starting car?
- stupid, but difference between integs?
- Please help might buy integra Tommorow...need your expert advice
- is this exhaust a good deal or what?
- Hopefully buying a 95 LS...
- 96 integra exhaust question?
- How To Diagnose This issues. Tie-Rods perhaps? No Clue
- 97 gs question
- No Compression on one Cylinder!! Now What??
- stock exhaust construction
- Help with CV axle replacement
- Oxygen sensor
- Oxygen sensor
- overheating
- Front ends
- could someone help
- what do your guys think about this
- my integra's idle keeps on jumping from 1-2???help!!
- tire wear
- All Motor Build
- what is this?
- Problems Getting into Gear Please Help!!
- Clutch Master Cylinder (need helk)
- Spun Rod Bearings
- call me dumb but what does this mean
- Ctr Or P30 Pistons And Eagle Rods??
- AEM vs Stock fuel rail
- H22A or B18c Type R....Need help guyz!
- opinion needed
- Stock Alarm Cut on GSR
- I need help idle problem?
- which would be better
- Advice for 2nd gen owners!
- Intermittent stalling, usually on a hot day ... a call for ideas!
- HID retrofit v.230498
- 1987 integra header pipe
- Identifing the type water pump...
- Which car is the better deal for my situation?
- Oil for 96 integra rs
- Opinions need
- type r front end
- turbo install
- dc or jg edelbrock headers?!
- loud valves
- Turbo Install on hold, PLEASE HELP!
- g2 power window conversion. What is this plug? *pics* plus water leakage question
- ES bushings install post-game
- Advice Please?
- 90 spoiler on 88 Integra?????
- cams for gsr
- How to replace side rear view mirror?
- hks hi power exhaust
- Car is knocking and stalling out in neutral
- Cylinder head rebuild
- GSSR's retrofit: These pictures do it justice
- simple Q
- gsr swap help
- function form coilovers
- what whould be better?
- Is this ok?
- Honda financial refinance offer.
- *Searched no luck* how to tell the difference between alternator??
- PLEASE HELP ME get this oil crap to work!
- Heater switch problem??
- found a foreign object in my ecu?
- Fuel Injector Issue.
- My AC smells bad
- question about ECT sensor
- small radiator leak
- kind of oil and rad fluid
- ITR and GSR valvetrain
- engine swap (TL or CL)
- sinking brake pedal...
- Yet, another Stolen Type R :(
- a very sad end to an all to short story..
- i need ur help
- My ramhorn...fix it or leave it?
- funny oil
- FooD's Custom Turbo set-up
- 1987 Integra starts sporatically...
- Motor mount
- Vtec head, missing parts
- I finally did something with my lame PCV system
- AC Refrigerant Type
- GSR 120,000 Miles without Timing Belt change?!?!
- Want To Run Crower 402's Or Jun Stage 2's
- best suspension setup
- integra 4 sale
- 94-01 Closest replacement shift knobs
- eagle manifold and vac lines
- transmision
- Test Pipe Question O2 sensor
- bigger pistons or not
- please explain tire sizes
- Obd-2---->obd-1
- getting a new trans, which one?
- how many own second gens?
- Idel problems and oil burning
- shitty ebay intake? (SRI)
- b16a1 question
- Wheel assembly??
- Possible vacuum leak
- HP an torque gains?
- 95 Integra LS. Electrical Issue
- Turn signals :x
- b18c swap
- performance injecters
- 01 itr & 00 lude cat. converter interchangable
- ebay catback system
- Do my plugs look ok?
- How to set the timing on my Acura Integera.
- altenator help
- Bogs bad past 3/4
- weak ass turn signals
- ITR Lip ITR Rear Wing
- TRD, Mazdaspeed, Nismo, what does honda/acura have.
- Question on Headers...
- tranny questions
