View Full Version : Integra & '97-'01 Integra Type-R
  1. deciding injector size for b20 turbo
  2. pace setter exaust?
  3. vtech conversion
  4. Suspension
  5. White smoke from tailpipe 97 b18b1 Engine
  6. suspension setup for maximum comfort?!
  7. hose
  8. valve cover
  9. difference between JDM itr and USDM
  10. has anyone heard anything about tenrai springs
  11. GSR Spark plug torque spec
  12. '92 Integra front end clunking
  13. Apexi n1 exhaust
  14. vtec solenoid gasket
  15. Best Pistons for B18??
  16. B18b Ls What pistons are the best
  17. '89 Integra Experience Needed: Cold Rough Idle
  18. Valve Stem Seals
  19. brake problem
  20. Federal Mogul gasket?
  21. Need Help w/broken PCV valve in my 90 ls
  22. I got a defective equipment warning for my exhaust. What's the best approach?
  23. 93 teg JDM headlights
  24. clutch help
  25. considering doing this...
  26. Snapp off boss kit opinions please
  27. Turn Signal Problem - Help!!!!!!!!!!
  28. Manual Tranny Fluid
  29. more power without getting ripped off?
  30. zc parts`
  31. Should I??
  32. axles
  33. 93 Integra LS - Should I buy this car?
  34. Emblems?
  35. Omnipower Coilover Questions
  36. Integra GT-R??
  37. '98 GSR -- should I buy this car?
  38. 95 Integra Ls / Vtec
  39. Tire Fitment??
  40. vacuum leak?
  41. 91 ls ?
  42. IAT Problems
  43. Synchros
  44. radiator replacement
  45. heat problem
  46. engine smoke
  47. srs light
  48. building engine
  49. rough idle at startup
  50. motor swap ?'s
  51. sway bars
  52. questions on the integra
  53. help
  54. motor build ques
  55. springs
  56. Just installed a AEM V2...
  57. 4dr seats in a 2dr
  58. 1990 LS, engine rough on acceleration
  59. What cams can I run?
  60. Ordered my pads-rotors 98 GSR
  61. Problem When V-tec Engages
  62. K&N filter Q....
  63. 96 LS; Questions re: Turbocharging
  64. diff in 90-91and 92-93
  65. steering wheel vibrates
  66. '92 integra BAD vibration diagnosis
  67. car shuts down while driving, check engine light comes on, wait 10 minutes starts up
  68. self install [Timing Belt]
  69. Aem Cai
  70. Can/Will Z3 seats fit?
  71. 93 Integra => DA6 JDM (real) 1 Piece Headlights Install / Bulb Question
  72. PCV and crankscase ?'s
  73. Sway Bar endlinks confusion
  74. Turbo kit from eBay?
  75. Turbocharging a GSR [Split from SC/ TC thread]
  76. I Have The Fastest Integra Out There
  77. Matience
  78. fender question
  79. GSR Cam Swap
  80. Odd symptoms, tranny, perhaps clutch?
  81. About prices in eBay
  82. GSR Head Rebuild
  83. Clutch install on my 99GSR.
  84. 93 ls
  85. Brake shims....do you really need them??
  86. Supercharger or Turbocharger
  87. Bolt on upgrade question
  88. Problem with rear hub replacement....
  89. ABS question
  90. doing a valve adjustment?
  91. Top speed limit
  92. New to the forum...
  93. #2 and#1 injector too much fuel
  94. Need advice on bore and compresion ratio
  95. Need help with rear hub bolt size??
  96. oil
  97. i have a 95 acura integra LS 4dr
  98. hello all
  99. so i bought the 91 lS
  100. how many miles on your GEN2
  101. '92 Turbo Teg that goes into a retard mode...
  102. Help: Fuel Injector cylinder order (JDM)
  103. Shift kit
  104. idle problem
  105. ´90 4dr Integra taillights, from where?
  106. gen2 with leather
  107. 1996 Integra idling noise
  108. JDM b18b on a USDM 94 teg please HELP!!
  109. 95 integra NO idle!!! help!!!!!!!!
  110. finally after 8 months got my 94 dc4 outta the shop
  111. Hatchback won't open
  112. weird vtec
  113. How to start
  114. 95 gsr paint and body?
  115. questions....[RE: Suspension Setup]
  116. Please help!!!
  117. What to do with exhaust
  118. oil on sparkplug!!
  119. Clutch Problem 2 *****
  120. Front Wheel Bearings on GSR
  121. ss brake lines
  122. question....[RE: Sale Price]
  123. clutch problemss plz help
  124. clutch problem*****
  125. integra Ls Top end....
  126. Keeping a 96 Integra with 139k running smoothly
  127. NSX caliper on a ITR
  128. What's the differance?
  129. Burning Oil through piston rings...
  130. Trouble with Shifter
  131. ABS Light is on
  132. Gen 2 rear brakes
  133. rpm problem
  134. integra Ls Turbo vs Gs-r Turbo
  135. Slim Fans?
  136. ignition lock problem
  137. How much to repaint a g2 integra - (approx, anyone done it)
  138. Just finished clutch install...YAY!!!!
  139. difference btwn 4-2-1 1piece and 4-2-1 2piece
  140. Ac/heat cabin fan not working
  141. ys1 y21 lsd
  142. oil filters....again....
  143. Whats wrong?
  144. whistle sound
  145. Type R Question
  146. 1995 Ls Pcv???
  147. Weird noise when I turn left?
  148. headers
  149. ARP Head Studs
  150. Cheaper parts
  151. nrg ground wire kit?????
  152. Suspension?
  153. Turn Signals thread
  154. Need Help Wit Transmission
  155. nitrous jet sizing help
  156. Need help with ITR suspension install on DC2
  157. quiet titanium exhaust?
  158. 1990 LS brakes, mastery cylinder?
  159. 90 integra Gs drains battery
  160. 93 Integra GS Questions
  161. Need a keyless entry remote 98 Integra
  162. obd0 to obd1
  163. Pricing $$$$
  164. What Aftermarket Exhaust?
  165. help me make my automatic into a manual
  166. 90 Integra LS Codes 9 and 4
  167. something i thoguht u guys would like
  168. stage 3 cams: to agressive for daily driving?
  169. nitrous troubles
  170. Gsr Head
  171. Wheel Bearing? Clicking sound
  172. Separating exhaust at the cat converter
  173. rear camber issue
  174. clutch pedal gets stiff after warm ups
  175. tips...
  176. check engine light
  177. coolant leak on hood...
  178. E-brake....?
  179. vacuum for b18a
  180. CEL Help: 00' DC4 with B18C5 code 91
  181. Quick Question: winter tire PSI
  182. Checking CEL Light
  183. B18C3 info
  184. How to lift an integra
  185. bout to start my clutch install...
  186. Can the stock pressure plate hold any extra power?
  187. installing type R spoiler
  188. i wanna turbo my LS
  189. Who makes the best cams & cam gears? for B18c1
  190. 92 GSR Question?
  191. brake/caliper question
  192. Is there any way to upgrade the air conditioner?
  193. 95 integra worth this much?
  194. Want to upgrade my integra but dont know where to start
  195. Da Owners Need Ur Help!!!!
  196. Help: Is the Intake Air bypass check valve neccessary
  197. clicking when turning right..not CV though?
  198. Need 1989 Integra LS VECI Label
  199. Intake Manifold help
  200. Seat belts!!!
  201. Still Slugish!!!
  202. turbo ?'s - ruff idle, fuel pressure
  203. 93 Integ / Only starts in hard reverse
  204. 89 Integra LS - Idle Adjustment
  205. ****offset question****
  206. Need Mechanic In Smyrna Ga Area
  207. 94-95 security unit wire harness
  208. Belt deflection/tension measurement tool?
  209. help!!!! on the gsr
  210. popping noise...
  211. Sell mine and buy 2??
  212. Adjusting the camber
  213. tranny swap
  214. engine temp?
  215. timing issues
  216. 1990 Integra??
  217. steering wheel swap help
  218. Raising a '98 Integra to Stock Height
  219. Help: anybody know how to remove the pulley from the alternator
  220. problems with my fans
  221. why was my thread closed?
  222. Fog Lights
  223. 3rd Gear Grinds
  224. air intake manifold trouble
  225. Control Module
  226. Recommendation on engine
  227. 1996 integra breakdown possibly timing chain failure
  228. Help
  229. Fuse for fuel pump
  230. What spring rate is everyone running?
  231. Tweaker blinkers...?
  232. turboing integra....radiator question
  233. Help w/aftermarket gsr h-beam rods
  234. Finally I got what I need
  235. radiator leak
  236. anybody knows how the intake work on a b18c1--- vvis intake port
  237. Ques: What Radiators to use with JDM B18C GSR
  238. Rubber Strips On Roof
  239. grindding when shifting.
  240. del sol seats?
  241. HELP: does anybody have pics of their Intake manifold for JDM B18C GSR
  242. Reseting the ECU
  243. KYB* Shocks
  244. A few questions...
  245. OEM brake pads vs Axxis Ultimates
  246. front bumper damage
  247. 1990 Integra - A/C Relay
  248. lookin into the cost for a ls motor, n what i need for it
  249. Ls Daily Driver Turbo Question
  250. o2 sensor
go
Search Engine Friendly URLs by vBSEO 3.5.2
