- Drove 01 CL thru deep water...buzzing noise
- '05 TL Noisy Power Steering Pump
- 1993 Acura Vigor Starter Removal
- Lost key and control
- 99 cl 3.0 a/c issue
- Acura 1998 2.3 CL Speedometer Problem
- 05 TL Tires?
- '96 2.5 TL AC Fan Not Working
- 04 TL BT/HFL Issue - request help please
- Is the tl 3.2 tranny the same as the 3.0 cl tranny?
- Leaking moonroof on Acura 3.2TL
- 05 TL switchback lights and amber lens removal.
- 06 TL switchback lights and amber lens removal.
- 97 2.2 CL Brake Bleeding
- Can you swap the TL's SOHC heads with...
- 98 Acura CL HELP plz :(
- Alternator life on 99 3.2 TL
- 2002 Acura Tl type S 168k..... trans questions
- Whirring Sound 2000 CL
- help.. i bought a 06 acura tl already supercharged..
- 05 TL Battery/Starter problems
- 98 Acura CL 2.3 Auto: 2nd Gear Slipping?
- 97 3.2 TL Thermostat
- 97 Acura 3.0 CL irratic idle
- 99 TL 3.2 - Drive cycle for emissions test
- Factory car alarm 96 Acura TL
- Acura Sport Shift Knob For Honda MT Fit?
- Weird slight 2-3 second buzz after the car starts
- 99 TL Parking Brake Adjustment
- 2003 3.2 tl no turn signals????
- 99 CL timing belt cover
- Replacing front rotors on 97 CL 3.0
- Acura cylinder torque specs
- 1996 acura tl interior fan diagram
- Looking at getting an 06 or 07 TL within a week
- 97 TL 3.2 Cruise Control cuts out intermittantly
- How to replace oil pan gasket on 96 3.2 TL?
- Clock replacement
- Tranny whine
- Tech help - 2000 TL
- TL Crew talk to me about the TL 2004
- [How do I read] ABS codes
- Need a key for '05 TL
- Does anyone have ?
- Anybody know how to remove back seat of Vig or similiar car
- 1997 Acura CL 3.0 Spark Plug Torque
- Viggy roll call: holler!
- Noob, but not to Honda or tuning: '93
- Have anyone put red "A"s on?
- 97 TL Fuel tank Issue
- 2002 tl-s
- 98 Acura 2.3 CL Brakes
- Speaker sizes for a 97 TL 3.2 prem?
- steering wheel lock [2004 TL]
- change out TL Radio
- 1994 acura vigor factory car alarm
- 96 TL AC / Heater / Defrost fan acting up - Help?
- Question about steering problem
- Do You Think The ?
- Acura 2.2, new clutch same clutch problem
- 2000 TL won't start, Hydraulics problem??
- 99 tl: P1456/p0401/p1739 obd ii
- 96 TL Wiper Not working - Need help with diagnosis
- 99 TL 3.2 popping sound from front end on braking
- Wondering something 05 TL?
- HID Inverter & bulbs a rip off
- Aftermarket headlight assys for 95-98 TL
- fastest way to replace 97 tl 2.5 distributor cap
- diy distributor cap 97 acura tl
- Remote starter for 97 TL 3.2
- 2005 Acura TL
- 99 Acura cl 3.0 spuddering then shuts off
- 97 cl 2.2 no start
- Tire Suggestion
- '01 CL-S HID needs replacing...
- sticky shifter on 2000 TL
- 97 CL O2 senor issue
- air intake question
- Help! looking to purchase a 97 acura 2.2 cl any tips,hints or advice?common problems?
- "High Mileage" oil
- 2003 Acura TL Stype HeadLamp Adjustment needed.
- Brake pads DIY project?
- help!!! 96 tl gas tank removal
- 96 acura tl blower not working ?
- 2.2 vtec CL motor
- 2005 Tl
- 97 Acura 3.0 CL driver seat removal help?
- 99 tl evap probs
- 97 CL Clock
- resetting 2001 CL maintenance light
- acura cl rear alignment bolts
- 97 2.2 CL Hesitation, Stutters
- obdII location
- Acura 2.3cl idle issues, Need Assistance
- 99tl rear driver door handle will not open
- 1998 Acura cl a/c wont blow
- Ny new audio system
- 99 acura 3.0cl adding amp help..
- 99TL Oil Leak
- 2006 TL Fuel Mod Chip
- 01 Cl-s Aftermarket Parts
- noisy vents
- 1997 Acura 2.5 TL
- 2000 Acura TL CD Player
- How to program keyless entry
- Where can I find how to replace a C.V. boot?
- '99 Acura TL Catalytic Converter
- Can't shift out of Park, Sunroof no longer works and wipers don't work
- Acura CL driver side seat removal
- 2000 Tl
- 01 CL occasionally will not start
- 1997 CL 3.0 SRS Light
- c
- 1998 2.5 TL A/C Blowing warm air
- Radiator Fans
- 1997 Acura CL cooling fan
- distributor
- Automatic transmission compatibility
- 2000 TL - How to change front Wheel bearings?
- Acura 3.2TL-A/C stopped suddenly
- 2001 TL lumbar seat lever squeaks against leather seat
- Repair Manual for 2002 TL-S ???
- how to take a BOSE head unit
- 03 TL climate control wacky
- How to Change Fog Light for 2003 TL
- Instrument Back Lights on Dash of 02 TL-S
- Center Mounted Rear Brake Light on '05 TL
- timing belt maintenance
- acura98tl trans problem
- navigation screen
- TCS and Abs lights
- Just got a 02 3.2 TL Type S-Questions???
- Air Conditioner blowing warm
- 99 tl radio code isssues
- 3rd generation TL Realibility (2004 - 2008)
- 1998 Acura TL 3.2
- Acura/Honda Mechanic Wanted
- 2001 3.2TL - AC and fan fail together intermittently
- crankshaft position sensor problem help!!!
- 2001 Acura 3.2 Tl
- 98 cl radio wiring
- 97 3.2 TL premium gas octane
- 3.2 CL timing belt replacement
- 92 vigor check engine
- 2001 TL 3.2 alarm keeps going off
- acura vigor factory alarm
- Repair Code Acura TL 99
- 2001 acura cl HID CONVERSION?
- Newbie needs advise on buying a 2002 TL-S
- 1999 Acura CL 3.0
- Oil in #5 spark plug Cylinder
- 2001 TL battery
- 03cl&tl
- can an accord flywheel bolt up to a vigor 5sp???
- 2002-03 TL/CL Information
- change sprak plugs on 99 TL
- 1998 Cl Stalls at high speed, Scary, Help!!!!
- how to replace tail light?
- Honda Recall for all 2004-2008 Acura TL.
- 2004 Acura TL lip
- how does 10% ethanol gas affect Acuras and Honda's?
- 2000 3.2TL, getting engine light, code P01456 (or P1456), then Maint Req light.
- 1999 cl 3.0 clunking sound
- buying 01 CL S NEED HELP??????
- Can 3.0L CL trans be fixed?
- speedometer
- Acura Vigor Headlight JDM
- TL bumper removal/replace front and rear
- alternator failure
- 99 TL question
- 1996 3.2 tl heater blower not working
- Performance exhaust systems
- 97 3.2 TL O2 Sensor
- CL starting problems
- 97 CL door window
- Brake Light Won't Turn Off (96 Acura 2.5TL)
- 99 ACURA 3.0 CL problems?
- Rough Idle & Check Engine
- 02 CL Type S navi pin needed
- removing acura tl 2004 radio
- o2 Sensor
- 92 vigor check engine light
- Chrome rims on your CL?
- 1997 Acura CL Headlamp
- Removing Stero 2001 TL
- Buying a 2003 TL Type S or A-spec
- Its kind of like a small roar roar?
- 96 Acura 2.5tl Erratic Overheating
- Gonna buy an early 2003 TL, have a question on transmission
- no start 97 tl 2.5 5cyl.
- Clutch replacement on '03 CL-S??
- CL turn signal assembly
- Blown engine?
- wtb: wood grain console for first gen tl
- Ignition Switch Recall on 98-99 Acura CL
- Cylinder Position Sensor Issues
- 2001 Acura Right Low Beam Light Now Working
- Another Egr Cleaning Questions
- What's The Best Struts For Acura Vigor
- 2005 Acura TL radio code
- help-removing passenger mirror
- 93 Vigor dash lights does not work
- brake pads for cl 1999
- check engine light
- 97 CL Radiator fan/Cooling Issues
- 97 Acura CL V-6
- 1996 Acura 3.2 TL back lights
- 98 CL 2.3 Stereo Replacement
- Door actuator for 97 3.2 TL
- Headlamp on 99 Acura 3.2 TL
- 99 TL valve clatter/chatter
- Simple 3.0 CL question
- 97 3.2 TL remote programming
- problems 2000 TL
- I need your opinion!
- 1997 won't start
- 2004 tl
- radio wont turn on, 2004 TL
- Lock not working
- Check Engine Light
- ABS troubleshooting help needed
- Anything to know about 1998 CL 3.0
- 2008 TL Navigation
- 2000 Acura TL OEM Skirt Package
- '98 2.5TL Frt. rotor torque specs
- 98 acura tl muffler
- I imported a 04 tl I want DRL to work, How?
- Looking for NYC Acura mechanic
- 96-98 TL 3.2 Starter Contacts
- Vigor front lip???
- question about vigor
- 92 Vigor and LS web wheels?
- New guy w/ 02'TL-S
- Performance parts - 02 TL?
- Oxygen Sensors
- 3.2 CL Headlight Problem
- 99 CL speedometer issue
- Please help! Alarm issues
- 03 Acura CL Tire Recommendation
- SRS Light won't blink twice after MES Reset Sequence
- Yeap... there a newbie in town...
- Looking to buy a 2003 TL
- Good OEM Exhaust for 97 2.5 TL
- 03 Tl Instrument Cluster Problem
- 1993 Vigor...need some help
- Blue smoke from tail pipe
- New car?
- surging issue??
- Starting System Problem
- 97 TL Main Relay
