View Full Version : CL, TL, & Vigor
Pages : 1 2 [3] 4 5 6 7 8
  1. Compass on 2006 TL ?
  2. wanted:acura cl wheels
  3. door locks on 99 CL
  4. 99 acura cl front noise
  5. 1999 TL diagnostic problem
  6. 1999 TL engine miss
  7. blower motor relay?
  8. 1999 3.2TL w/Nav
  9. 99TL Brakes Hissing at random
  10. Catalytic converter PO420
  11. starter problem
  12. 2000 3.2TL, ran rough, check engine light, "fuel air metering" code
  13. 93 vigor trans or diff promblem????
  14. '92 vigor grille
  15. Changing rear speakers in '94 Vigor
  16. Help Need To Know What To Do!!!
  17. Please --->>>Acura Vigor Springs/lowering suspension advice ***********
  18. Low beam replacement Acura 200 TL
  19. 2003 acura 3.2tl times
  20. need timing belt diagram for 1997 Acura 3.2 TL
  21. 93 vigor engine problems
  22. New Vigor
  23. after market stereo system for tl-s 03?
  24. Just purchased a 3.2 TL
  25. 03 TL Type S
  26. 2007 TL Transmission Problem
  27. Seatbelt Replacement on '04 TL
  28. D4 light does not turn on
  29. vigor trans
  30. any one change the side marker on '04 TL?
  31. '93 vigor fog light change.
  32. 98 cl check engine light
  33. no lights on the dash!
  34. The New 2007 Type-S
  35. 93 Vigor Brake bleeding issue
  36. CL/Problems Maintainance
  37. acura cl 3.2 2001
  38. Bose Aftermarket help!
  39. water leak in Vigor trunk
  40. Help! Playing CD's on a '92 Vigor with a broken display.
  41. Tinting Advice - '02 Black TL w/ Parchment
  42. Need Help With Seats!!!!
  43. 5spd Auto vs 6spd Manual
  44. brakes
  45. 1999 TL Engine Mounts
  46. Mods, air intake, turbos...
  47. CL noise
  48. very awkward
  49. Hello new '01 TL owner
  50. 99 cl 3.0 no-start
  51. '96 TL 2.5 clicking noise behind steering column
  52. engine miss
  53. remote
  54. Turbocharging More Models
  55. Vigor tweeters?
  56. any aftermarket struts for lowered Vigor?
  57. Vigor Starts, Runs then Stalls
  58. valve adjustment
  59. ruff shifting in 92 vigor
  60. Steering wheel gets tough after a while...
  61. CD error messages
  62. noises from car
  63. Need help 1993 vigor-even acura couldn't help
  64. rear quarter panle removal
  65. Front Speaker has gone for a toss! 96 3.2 TL
  66. SRS light - third time now !!!
  67. Engine fan runs even after shutting off, 96 3.2TL
  68. Check Engine light on !!!
  69. Possible to install factory navigation in 95-98 TL's?help
  70. Tranny, engine mounts, now wheel bearings.
  71. catalytic converter??
  72. Factory Alarm/Keyless Entry Issue
  73. Continuing CEL Problem - Help please!
  74. 03 TL Type S Vibration
  75. Timing Belt for 96 Acura 3.2 TL??
  76. CL 3.0 2 door - Passenger door stuck, any help?
  77. Acura Cl -Coolant lose
  78. Oil Leak Problem? I dunno
  79. engine mount
  80. 97 TL a/c condenser drain? (water on floorboard)
  81. Looking to buy 95-98 Acura 2.5 or 3.2 tl,any advice or info that can help,thanx
  82. Need new front rotors on my 01 TL, any suggestions?
  83. oil pan removal
  84. Replacing dimming rearview mirror 4 a 99' TL?
  85. Hooking up IPOD to 03 Type S
  86. '04 Tl
  87. 2003 Acura Transmission Problems
  88. D4 Gear Indicator on Dash
  89. My 06 TL Seat is a Pain in the Butt - HELP
  90. Stero removal
  91. 96 Acura 3.2 TL, CD PE0 error message
  92. engine swap
  93. 06 TL advice
  94. 94 Vigor ABS and Brack light on
  95. 660 mile trip in a vig need opinion/advice
  96. Buying 1996 Acura 2.5TL ??
  97. Acura CL2.2 97' ABS
  98. Semi-automatic
  99. 90'vigor doesn't start when warm
  100. Rebuild
  101. camshaft help
  102. Top speeds?
  103. Ipod Integration
  104. Need advice on buying a 2004 TL
  105. 93 vigor
  106. Please Help CL 98 CL question?
  107. Dc Sports Headers.
  108. '93 Vigor, car stalls when driving thru water, WTF??
  109. 94 vigor
  110. Does my 96' TL really need a factory jack?
  111. Short Shift.
  112. Changing transmission fluid on a '05TL
  113. Which Helm's manual do I need for my '05TL?
  114. Get rid of that Stupid Compact Spare
  115. Brakes?
  116. engine jerks on acceleration
  117. "Brakes" light on the dash coming "ON"
  118. Soft Copy of Acura TL 1999 Owners Manual ?
  119. 60k schedule maintence for 1999 cl
  120. 94 Vigor A/C not working
  121. Service indicator on dash of '05TL and oil question
  122. 92 Vigor (engine light code 41)
  123. More Horsepower
  124. Transmission stopped working today on my 97' 3.0 CL
  125. Acura Vigor Strut Bar
  126. Honda Financial
  127. Intake for 1999 Acura Tl.
  128. Acura 2.2CL 97' Manual | Stereo install
  129. Warrenty when selling a car?
  130. Acura 3.2L TL horsepower??
  131. 1993 Acura Vigor Blinker Problems-Help!
  132. 99 TL Brakes Shuttering.
  133. Regular Unleaded Gas in 3.2 TL???
  134. The best suspension for a 3.0 l 99 cl
  135. 3.2 cl wheel stud replacement
  136. just got new Goodyear Responsedge tires for my 02 TL
  137. '99 CL 3.0 - Best lowering components
  138. 2003 3.2TLS spare tire
  139. Lowering a Acura Vigor Springs or Coil Over Springs
  140. 00 Accor coupe v6 or 01 3.2cl type-s??
  141. 2003 tl-s, any double din kits available?
  142. ABS problems on TL 03
  143. 96 Acura 2.5TL Fog Light
  144. R&R Replace door panel trim, arm rest
  145. replacing flasher relay
  146. 2002 CL-S, Needs More Power
  147. 1999 3.2 TL engine idling up and down
  148. Tires for 2004 TL
  149. TL Thoughts on RIMS
  150. Honda Coolant
  151. Speaker size for 2003 TL?
  152. '03 CL-S to '99 CL "transplant"...
  153. question on timing belt
  154. Looked at an 05 Accord EX L V6, what about a CL?
  155. Questions on a 1992 Acura Vigor
  156. 2002 TL typeS air conditioning will not turn on
  157. wtb :97-2000 acura CL's some advice??info??feedback?
  158. top speed
  159. Swapping a 3.2tl for the 3.2tl type s motor.
  160. Place to get updated Nav CD's?
  161. 94 Acura Vigor LS
  162. When was the last TL Major Change & When's The Next
  163. navi hdd gone bad
  164. rpm speed
  165. Side Skirts
  166. removed ign key in reverse it caused an accident
  167. Can you BAIL on an Acura lease?
  168. 2000 3.2tl
  169. Vigor Engine Removal
  170. So the Vigor is Going in for a Bit of Surgery :)
  171. Protecting the Dash Appreciate some Recommendations
  172. Help with 99 TL tranny
  173. Add fog/driving lights to TL (not S type) ??
  174. 1998 CL radio Error-3
  175. Can the dealer or I turn off the km/h display
  176. Is it my eyes or the speedometer
  177. Door Storage What mounts there
  178. 01 CLS cd deck problem
  179. looking to buy a y-pipe
  180. 1994 vigor
  181. tight automatic shifter
  182. dvd navigtion question???
  183. 06 TL wheels on an 02 TL
  184. Any One Clear Out Their Head Lights On 2004 & Up Tl?
  185. TL type S question
  186. 04,05,06 TL pics with underbody kit
  187. 06 TL High Performance Tires
  188. Transmission fluid change 01 type-s
  189. 96 2.5TL ABS light
  190. Looking to buy a used Acura TL (1999-2004)
  191. imrc installation on 2001 cl-p
  192. TL Brakes Pulsing
  193. Clicking noise from '99 TL
  194. 02 3.2TL upgrades
  195. Speed Sensor on '99 Acura 3.2 TL
  196. Vigor Questions
  197. 2003 3.2 TL type S maintenance req light
  198. Whats The Easyest Weigh To Increase My Horsepower On A 97 Cl 3.0? Thats Cheap Lol
  199. Buying pre-owned TL advice
  200. Bleeding the clutch on a vigor??
  201. TL CD player - can I random among the 6 cd's?
  202. Bumper Removal
  203. dead auto new battery
  204. Headlights
  205. 06 TL 6 speed or Auto?
  206. 1993 Vigor
  207. TL Struts
  208. CL '03 Stereo Question
  209. Azect Grill
  210. I need help !!!!
  211. 03 CL type -s interior light issue
  212. Lowering Springs
  213. Oxygen sensor '92 Vigor
  214. vigor clutch adjustment??
  215. Vigor Tranny/Clutch Trouble??
  216. engine oil
  217. Which Rims>>>????
  218. timing belt
  219. flasher not working
  220. SRS light on
  221. calipers
  222. Getting error 3 code on radio
  223. Tl's Need A Seperate Forum!!!!
  224. TL All wheel drive
  225. Question on service due indicator on '05TL
  226. how to remove the stock deck
  227. navi code
  228. OEM autoparts online
  229. Tire replacement on '01 CL Type S
  230. 98 3.2 TL Manual Swap...
  231. looking Hi Pro Chip for 92 Acura Vigor GS 2.5L
  232. Anyone use the Fumoto valve?
  233. squeaky seat
  234. Acura Vigor Headlights
  235. About Acura Vigor CV Boot
  236. Navigation always pointing north
  237. Got 2005 TL Bought Back
  238. Vigor runs but won't drive
  239. Radio Code???
  240. 2005 TL - Adding audio input?
  241. Factory Alarm Problem
  242. Wind noise in 92 Vigor
  243. exhast
  244. ACURA 3.2 TL radiator fan fuse
  245. Wheel Question.........
  246. '01-'03 CL-S Spoiler
  247. new clutch slipping!! -help!!
  248. 92 Vigor headlamps
  249. CL Tranny Problems???
  250. squeeky seat
go
