- 98 acura tl muffler
- I imported a 04 tl I want DRL to work, How?
- Looking for NYC Acura mechanic
- 96-98 TL 3.2 Starter Contacts
- Vigor front lip???
- question about vigor
- 92 Vigor and LS web wheels?
- New guy w/ 02'TL-S
- Performance parts - 02 TL?
- Oxygen Sensors
- 3.2 CL Headlight Problem
- 99 CL speedometer issue
- Please help! Alarm issues
- 03 Acura CL Tire Recommendation
- SRS Light won't blink twice after MES Reset Sequence
- Yeap... there a newbie in town...
- Looking to buy a 2003 TL
- Good OEM Exhaust for 97 2.5 TL
- 03 Tl Instrument Cluster Problem
- 1993 Vigor...need some help
- Blue smoke from tail pipe
- New car?
- surging issue??
- Starting System Problem
- 97 TL Main Relay
- HELP Looking for Acura 3.0 CL Performance Parts
- 20's?
- How can I figure out which remote I need
- jdm cc2 vigor headlights installation?
- How Can I Improve Acura 07 TL Suspension, Ride Comfort ?
- 1999 CL timing belt
- Acura 2000 3.2TL
- 99 2.3 CL Radio Wiring Diagram needed
- 97' CL Short in the Steering Wheel?
- 3rd Gen TL For Magazine Feature
- Front disks and calipers for a 2003 CL Type S
- Acura Maintance required
- 2003 CL Cupholder squeaking
- Passenger Seat does not recline
- n00b...kind of
- Audio & Integtration Question
- 02 Acura tl Type S going to visit Acura dealer
- Acura CL 3.2 Series S Headlight Problems
- What are these buttons for?96 TL
- Won't shift out of park
- TL 1999 heater problems
- HFL Problems
- burnt cd wont play on 3.2 tl
- Hi New to this forum Cl Issue
- key stuck
- Where can I find manual for 97 3.2TL
- '99 tl dies while driving
- 98 CL-Help with power window
- tl maintenance
- Acura CL won't start?
- fng w/ 02 tl ?s
- Need Good Acura Mechanic In Los Angeles
- Car Stalls
- 97 2.2 CL automatic transmission issues
- 1988 Vigor Carburetor Compatibility
- vigor key
- 2000 Acura 3.2 TL radio code please
- 2004 Acura tl SRS light stays on...HELP!!
- 2006 TL with radio reception problem
- Radio Code for 2003 Acura TL
- 2000 3.2TL A/C and heat don't work
- How to Retract Rear Caliper Piston?
- Accord control arms/tie rods work on Vigor?
- Timing Belt Replacement 2000 3.2Tl
- 2004 tl with navigation..should I?
- 96 3.2TL Prewired For CD Changer?
- '98 3.2TL wheel bolt pattern
- 96 TL ABS motor runs and runs and runs
- 99TL with the maintenance required soon
- My 2003 TL check engine light is on-HELP
- Sub with aftermarket HU
- 01 CL Rear deck rattle, speakers?
- 05 acura tl
- 2.2 cl window regulator problem
- does the TL really need premium?
- 2000 TL Radio Code & Nav Pin
- Need help replacing HID bulb on 2001 CLS
- Need 2007-2008 TL Type-S Auto/Man Times
- 2000 Acura 3.2TL Question
- 2005 TL Bumper towing plug popped out!
- Just got an 04 TL Loving it but what the hell.......
- TL mechanical help
- 2nd Gen TL Type-S A/T
- does a 04 TL Comptech rear sway bar fit on an 07 TL?
- RSX wheels on a TL?
- 03 tl type s
- What do these 3.0CL Trouble codes mean
- 02 TL Type S Spoiler??
- Need Help with an 2000 TL
- Need help: about to buy 3.2 tl type-s a spec
- 99 2.3 CL Catalytic Converter
- 2003 TL won't start
- Acura Transmission Miles to Engine Miles..Need Help..!
- 92 Acura Vigor GS wont start
- 1999 TL Nav System
- '05 TL reset Maintenance Req'd Light
- Need programming instruccions for 04 acura TL keyless remote
- How do you install 2005 TL Cabin filter?
- Did Acura lie????
- wew !!!!!
- TL 04 - Passenger Seat Upgrade
- Need help with installing a cabin filter
- Removing Headunit on a 02 TL
- Acura TL2000 - Radio Code needed
- with my hands up
- Harmonic Balancer Question
- 2004 Acura TL w/Navigation
- Performance Chips
- need acura code 1998 cl2.3
- good deal?
- Help Here Pls Car Got Stolen
- acura tl gear shift stuck occasionally
- Looking to buy 02 TL S - Questions
- vigor distributor shaft seal, where to buy them??
- quick question... 01 cl-s
- Need Help with a brake upgrade
- '99 TL Brake Light
- where else to look for used cars?
- '05TL rattles from dash
- Free Type S exhaust!
- 1999 Automatic Door Locks
- 97 CL 2.2 Automatic transmission issue
- 2003 tl type-s
- TL Wheel Suggestions [Split from News & Rumors]
- 2000 acura TL
- '93 Vigor Won't Start after Battery Disconnect!
- 99 acura 3.2TL transmission prob
- 02-03 TL A/C Problems
- 1997 CL A/C Problems
- Removing fixed glass
- '92 Vigor; OEM radio - CD won't play.
- 93 Vigor shift light not going on
- 1992 Vigor 2.5 liter 5 speed transmission
- 97 Acura TL Driver's Power Window
- What exactly is the difference?
- 93 Vigor Drive4 Blinking
- 96 Acura Thermostat
- Help
- CL 3.0 Transmission slow to wake
- Acura CL ABS wheel sensor
- 2004 Acura TL
- TPS voltage low 03 CL-S
- CL-S motor mounts
- Comptech swaybar vs. stock Type S sway bars
- TL vs Caddy STS?
- SRS Light 02 TL
- i need a code for my tl
- Maintenaince Light for TL
- DIY Stereo Install '00 TL
- Acura CL First Gen Reviews
- Remote Keyless Programming 1999 TL
- Buying a used 2004 TL
- 1999 acura radio code please?
- this is for a friend.. 2000 cl tranny problem.
- ABS Motor Replacement
- 2000 TL - CEL - Chech engine light
- A/C Compressor Clutch Low-Pressure Sensing Switch
- Possible new 3.2CL Type S owner
- 1997 CL radiator question
- Woofers on the TL
- Speaker installation
- throttle position sensor
- Best HID brand input.
- 99 CL 3.0 vibration during breaking at speed
- Considering Lowering...
- Just a warning about Dave Mungenast St. Louis Acura
- 93 Vigor, smoke wisps from right side of engine, WTF?
- Vigor shifting problems, need help!
- HELP car wont start
- 2002 TL Type S Keyless entry
- 97 acura CL 3.0 HELP
- KYB vs. Monroe Sensa-Trac
- Sound Dampening
- 2000 TL Problems and more!
- air conditioner
- TL Diagnostic Port
- Rear seat removal
- Seat Belt Beeper
- clunk noise
- Acura TL 03' Type S: Brake Light on dashboard panel just came on - How do I resolve
- Acura 03' TL -S: Maintenance Required Light - Need Help Resetting
- Tires For 05 TL?
- rattle from front center speaker - 05 TL
- 97 CL key fob HELP
- Mystery Sensor
- Mysterious Buzz in 99 CL3.0
- TL Head Unit Installation
- 94 Acura Vigor HELP
- headlight issue
- 1997 cl 3.0
- IPOD Recommendation
- Vigor minor electrical issue
- Carbon Fiber Interior Trim
- 2003 3.2TL S-Type warped rotors
- Tl or G35?
- 01 CL Type S Passenger Seat
- tie rod ends
- '98 3.0cl
- Selling my TL
- Transmission
- timing belt?
- Cant get my trunk open
- CD-Radio problem
- Just Got My Vigor Today
- A few questions to get me going
- Quiet 97 2.2cl acura exhaust
- 2005 TL Owner's Manual Online?
- CL a project car?
- tire compatibility??
- Vigor seat swap!!!
- Acura TL VCA, ABS, VCA indicator lights on
- '04 TL opinions please
- Acura 3.2 TL 1997 Check Engine Light
- 92 vigor auto transmission problems need help
- body shop recommnedation in SJ , CA
- New edition to the Family!
- Check engine code 1459!!!
- 97 TL turns off on own
- check fuel cap displayed on display
- 01 CL Type-S - XM Roady II advice
- 2.5 TL shocks/struts
- Calling all Vigor owners
- 1996 Acura 3.2 TL Transmission
- 98 TL P0420 Fault Code
- P0118 ECT Circuit High Temp
- What year TL wheels are these?
- My Acura TL 3.2. Weird Problem!
- Turning OFF Maintenance Light.
- CL Type-S SRS Light
- help with flasher ticking sound
- what weight oil change for winter on Vigor
- Need HELP on how to change shocks please
- Gear shift handle stuck...
- shocks for TL
- Engine Leak Repair
- please help me
- 99' tl help
- 97 3.2 tl - Check engine light on after changing spark plugs
- 1999 Cl 2.3
- dirty headlight lenses on the 97 2.2CL
- Tires
- loud whirring noise coming from front wheel well ('92 Vigor)
- Speed sensor location on 1999 Acura 3.2 TL
- terry
