- 94 prelude
- Starting issue
- How to Convert HD Video with HD Converter
- No Start 1989 SI auto trans
- Need Radiator, OEM or aftermarket?
- Prelude map light
- H22a Ignition Help
- Center console
- HELP can not fix this idle problem clip inside
- p1259 vtec system malfunction
- Working ATTS with Redline Standalone ECU, can it be done?
- 98 prelude axel question.
- 1991 Prelude bogging down while driving
- 5th gen oem front bumper place to buy?
- idle..
- 4th gen digital dash conversion
- Mp1a Auto tranny filter
- Car accident :(
- Car won't start
- AEM Intake
- cel codes.
- throttle body sensor...
- trans fluid
- 1990 Prelude Si Restore
- B20a5
- just bought 1990 si...B21A1...:ugh:
- Prelude Issues
- **NEED HELP** 97 prelude h22 auto trans
- Fog light question
- New to Preludes just picked up a 88' SOHC
- 2nd generation clutch pressure-plate?
- battery issue?
- Problem with starting
- 94 Prelude SI headlamps
- 4th gen prelude supercharger
- Squeaking noise from rear suspension
- 5th Genners HELP
- All of you please help identify this...
- 4WS Error Codes
- 95 Lude clutch problem
- 93 climate control
- parking break on one wheel spins abs light on
- prelude dying n nuetral after press gas good
- V-tec engine
- H23 Balancer shafts. Can they be safely disconnected? Please help.
- Knocking/Crunching Noise
- Only Rev's to 3k then bogs and when the Gas Pedal is Pressed to Hard.
- JRSC for SH
- re prelude jackson r supercharger
- A/C bypass belt, 2000 H22
- Headlights
- 92 Prelude AC Cutoff Question
- Ground Controls Squeek on 97 Prelude
- prelude pics and writeups at my site
- 98 Prelude SH ATTS Light On, No CEL ... HELP
- Whats this for?
- Honda Prelude Spoiler
- ????will 19's Fit On A 5th Gen Prelude????
- 92 prelude muffler system
- 92 prelude motor screw
- 92 prelude install front axles
- 92 prelude charging ac
- Need help for real!!!
- coolant leaking on to exhaust pipe
- steering rack question
- does anybody know?
- Haven't been on in a while
- Sputtering Lude needs TLC!! Driving me CRAZY
- h23 manual tensior swap
- need help
- Removing shift knob on '91 auto 3G
- 1989 Prelude Electrical Problem
- Struts
- prelude low idle problem
- Rear brake squeal when turning right?
- Swap Question: Which is the better K24 motor??
- Fog Lights on 5th Gen
- Flush Coolant
- NGK Iridium Plugs
- how do these look?
- Hey
- Simple Key FOB Question
- Camber kits. Which is the best way to go?
- blinker problem
- New brakes or 5-lug conversion??
- 2001 prelude ignition timing
- 1994 Prelude fuel pump relay location
- '88 Prelude bushings
- 4WS doesnt work after rack change
- Shaved engine bay we did
- prelude 93 SR
- tail light gaskets
- Lowering springs for 93
- what engine is it
- Engine Error Code P0420 Any suggestions?
- DIY Lug Stud removal for 5 Gen
- H22 Head bolt socket size??
- 99 Prelude: Slipped timing belt / tension problem
- Koni
- Prelude 1999 S- O2 Sensor help
- steering wheel jerks on start up
- How To: 92-96 Prelude 5th Gen Moonroof Conversion
- 95 Prelude SI (Need help identifying sensor!!) And need the sensor.
- 96 prelude clutch replacement
- weird noise
- H22a swap into 95 SI, HELP!!
- What is this wire for?
- How do I remove the front bumper from my 92 honda prelude
- What would be best swap for 95 Prelude SI?
- prelude, accord parts exchange
- O2 Sensor v Wideband vs Narrowband
- f22
- Looking for a replacement H23 Long block, anyone help??
- 95 Prelude, stock with H23, what is needed to swap in H22
- Momo Wheels?
- question about 5th gen prelude OFFSET?
- Need advice on buying a Prelude!
- horible noise
- Fog Light Wiring
- What is this thing?
- If I remove the cat.....
- major problem plz help
- 4g rims... Are they stock?
- Cylinder Misfire????
- shift knob sizing??
- swap question
- pics of my ride
- PS Pump
- h22a, jdm?
- 17's or 18's
- Clutch help needed
- TDC crankshaft position sensor where is it? vtec 93
- 1995 Prelude Si
- no spark help!
- no spark help!
- fs: Jdm Prelude Type-s Cluster 97-01
- brakes
- 5g upper ball joint puller
- Contact info for prelude moderator or administrator
- Prelude Problems
- need a new front axel
- 2.3 l engine swap
- 2nd gen question....
- Honda Prelude Alram Question
- b18b 4th gen prelude
- Fog Light Brackets
- hey guys help
- Timing Belt broke
- climate control
- Dash + Tail Lights
- "break" rotors
- Anyone looking to buy a Prelude?
- Product Review : Magic Eraser ( pics!)
- Oil leak coming from head?
- what its worth
- 2000 Manual Trans Problem
- slow prelude??
- no heat
- re.skunk throttle body
- 5th Gen Prelude fuel map
- 96 With a knock in one wheel;ABS?
- cat replacement
- Is 3500 rpm to high for Prelude 98 in 5th gear
- knock sensor
- bushings
- lowering
- new rack and pinion
- 96 Prelude ABS Light On
- clutch master/slave cylinders
- Lost my only key
- i need help with my 5th gen!
- trannyswap
- Clutch woes at48K in 2002Accord
- 99 Type SH Clutch/ATTS
- 90 prelude si tranny needed
- o2 sensor fail
- Almost finished....
- how to take the rotor off
- clutch fluid
- my prelude 01, stuck at 1st gear
- 91 Prelude SI
- 2000 prelude 75 shot wet zex kit / what else do I need
- shocks
- Compression Test
- How to take out the bolts
- Battery
- H23 engine build, anyone with any crazy ideas?
- need some help with this guys...
- In Shock!!!
- 97 Prelude, is this worth it??? I NEED HELP!
- swapping h22a for a h23a in my 95', do i need to buy anything?
- CEL code 80
- What year OEM wheels are these?
- burning oil
- engine swap 4 cyl for 6 cyl in Prelude
- making stuff work for cheap
- Where Is The Ac Orifice Tube Located At
- Which thermostat to use on JDM H22??
- brake problem
- 84 Prelude will not start
- mahle gold series
- Faster Lude
- Essions problems
- moon roof on 4th gen
- Need Electrical Expert Opinion
- 86 prelude help
- What rims are these? :OEM:
- Brembo rotors
- f22b1 block + h22a4 head ?????????????????
- turbo manifold
- 4th Generation Prelude LED Dash Conversion
- new member, quick question.
- New ECU
- No Answer
- rotors and brake pads help.
- hello
- 12:1 Commpression + Turbo????????
- 1989 Prelude Si - How to replace high pressure power steering line?
- Small Bubbles in my oil....water?
- getting my torque back
- a few oddball questions
- prelude ?
- Test Pipe
- 97 prelude sound system
- water coming from ac
- Code P0740 (prelude)
- 98 prelude tranny problems PLEASE HELP!
- What year and model did an H23A3 motor....
- 00 Prelude SH Radio Dash
- heatercore
- 92 Prelude (2.2 Automatic ****** Import) wont start!! HELP!!
- here's pix of my ported head and bord out block
- Whats the best upgrades for an h22a4
- timing belt whine
- Prelude A/C problem
- 92lude vtec jrsc
- Check engine and lose of power at high rpm
- strut bar length
- LS cam gears in an H23
- Timing.
- Tire brands
- BCU+ Boost controler/turbo timer install..help please!
- Air/Fuel gauge install help please!!
- flex pipe
- ATTS Horsepower Limit
- 2001 Prelude Cam Gear Adjusment
- h22a Problems
- lost interior lights and wiper function
- Thinking about buying this Prelude..chattering though?
- v6 in a lude
