PDA
View Full Version : Prelude
Pages : 1 [2] 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21
  1. rotors and brake pads help.
  2. hello
  3. 12:1 Commpression + Turbo????????
  4. 1989 Prelude Si - How to replace high pressure power steering line?
  5. Small Bubbles in my oil....water?
  6. getting my torque back
  7. a few oddball questions
  8. prelude ?
  9. Test Pipe
  10. 97 prelude sound system
  11. water coming from ac
  12. Code P0740 (prelude)
  13. 98 prelude tranny problems PLEASE HELP!
  14. What year and model did an H23A3 motor....
  15. 00 Prelude SH Radio Dash
  16. heatercore
  17. 92 Prelude (2.2 Automatic JAP Import) wont start!! HELP!!
  18. here's pix of my ported head and bord out block
  19. Whats the best upgrades for an h22a4
  20. timing belt whine
  21. Prelude A/C problem
  22. 92lude vtec jrsc
  23. Check engine and lose of power at high rpm
  24. strut bar length
  25. LS cam gears in an H23
  26. Timing.
  27. Tire brands
  28. BCU+ Boost controler/turbo timer install..help please!
  29. Air/Fuel gauge install help please!!
  30. flex pipe
  31. ATTS Horsepower Limit
  32. 2001 Prelude Cam Gear Adjusment
  33. h22a Problems
  34. lost interior lights and wiper function
  35. Thinking about buying this Prelude..chattering though?
  36. v6 in a lude
  37. light gauge cluster connection?
  38. jdm parts
  39. 92 prelude si engine swaps
  40. 3rd gen head gasket - bad or not?
  41. Q about shifting an auto-manual transmission
  42. Sticky Idle
  43. trans
  44. auto to manual swap
  45. Fog Lights
  46. h23 rebuild kit
  47. Enkei JS+M
  48. ac and heat
  49. h23a timing marks
  50. Dash lights and gauges
  51. how to swap h22 into 97 cl auto.
  52. need help with dash
  53. Please I need to know...
  54. 97 Cl Auto H22 Swap
  55. f23 in 92 prelude
  56. "Maintanance Reqiured" Light
  57. What's the difference.....
  58. B20A3 Keihin to Weber conversion
  59. Need some insight here please!
  60. looking for a P13 ECU for sale
  61. prelude h22a1 problems
  62. bent and cross threaded lower crank pulley
  63. f22 with h23 head
  64. rotors?
  65. ABS question
  66. Valve train troubles
  67. what engine do i have???
  68. ECU location
  69. Is this good
  70. advanced timing...
  71. Please help me out if you can...
  72. a/c removal worth the extra hp?
  73. overheating...........ahhh!
  74. ECU Flashing
  75. 2000 Prelude keyless entry help
  76. overheat / white smoke, coolant leak? blown head gasket? HELP!
  77. Head Gasket
  78. camshaft for h23
  79. quick engine mods.....
  80. S4 flashiing atcu code 4
  81. 94lube f22
  82. Bushing bracket cracked
  83. quick suspension question.... :/
  84. 1994 Prelude H22 Questions
  85. KYB AGX's or Illuminas
  86. steering
  87. Coilovers....way too bouncy
  88. gas smell
  89. Thinking about selling my EG hatch for a 94 Prelude?
  90. h22 timeing
  91. valve cover bolt
  92. new catalyic converter
  93. i need timing specs for 89 2.0 si lude
  94. Window off track.
  95. emission problem
  96. spring cleaning...
  97. 96 si used oem part
  98. check engine lights came off by itself, then oil pressure light went flashing
  99. check engine
  100. Prelude VS 240 (Silvia)
  101. 99 luda brake lights
  102. Valve chatter.......
  103. Check Vin
  104. Questions on replacing my upper control arms...
  105. F22b lost power
  106. Removal of A/C on a 93 Lude
  107. prelude 97-01 skunk 2 coilover
  108. 91 SI, need picture of relays in engine bay box
  109. Got some new rims for my prelude!
  110. -Problems-
  111. Stock radio
  112. blown 92 prelude
  113. jdm h22a, skunk2 intake manifold.... HELP!!
  114. 1988 Prelude 2.0 Si 4WS intermittent battery warning light
  115. whats the best sohc for prelude ?
  116. 1989 Prelude EFI,ECU Fuse Blows on Startup
  117. stroked H22
  118. 97 Prelude service
  119. Vtec
  120. 1998 Prelude
  121. 93 J-spec
  122. gear oil
  123. help i need a new shell
  124. Advice/Opinions needed, Please *smiles*
  125. continued...
  126. Applying pressure to the brake causes drop of idle
  127. Vafc-neo
  128. timing belt
  129. Prelude "leggin" when I push on gas?
  130. Where do INTAKE hoses go! No spot on After Market intake
  131. How do you remove a distributor... QUICKLY?!
  132. 1999 Honda Prelude Bottoming Out!
  133. some hamster sniffer broke my car window and stole...
  134. My fun has begun!!
  135. 5th Gen Maintenance Questions
  136. Car stalls when not in gear
  137. Turbo'd luder??
  138. Power antenna for a '92
  139. Where do "2" Hoses from stock Intake go?
  140. 88 prelude
  141. skunk2 adjustable coils
  142. Balancer belt question
  143. gas smell
  144. Whats the fastest you have gotten your auto lude to go?
  145. Car starts without pushing in clutch
  146. 3rd gen DC sports header on ebay
  147. VECI Label?
  148. In search for: H22a type-s pistons or mahle gold series h22 pistons
  149. why is my car eating so much gas???
  150. h23 to h22a swap wont start. fuel????
  151. is there
  152. '84 Prelude problems (idling)
  153. sh vs base?
  154. b20?????????????????????
  155. odd engine cut off problem
  156. starting question
  157. hmm? q. need a.
  158. h23 to h22 swap question
  159. need help on a hardd decision
  160. 1992 Prelude SI Vs. S
  161. 97 Prelude Trouble Starting
  162. >> Prelude FAQ: Under Construction; Contributions Welcome
  163. 2001 Prelude: MT w/ low mile slipping
  164. I think it's my distributor bearing...
  165. turbo question for H23A1
  166. My new 93 Prelude
  167. h23a + boost
  168. idle problem
  169. vtech controller
  170. Blinker Freak out, alternator?
  171. 92 Accord Valve Adjustment
  172. change of transmission
  173. 4WS problem
  174. '93 Prelude Center Channel
  175. H22 auto or H22 manual
  176. Post the Pics of your Lude!
  177. Electric Cool Air intakes, Legit?
  178. question about cat
  179. wide body kit
  180. Im Thinking Of Tradein My 99 Prelude For A Some What Hooked Clean 95-99 Civic
  181. VTEC controllers?
  182. Need help figuring out engine
  183. the B18C is dead
  184. Si VS. Vtec? Help me out here!
  185. Looking for F22B
  186. Key broke off in drivers side door!!!! HATERS, any suggestions
  187. swap help
  188. idle problem...Err
  189. steering gear
  190. passengers air bag question???
  191. Alternator replacement on '88 Prelude Si
  192. 93 prelude wont start, but battery good and gages wont come on, but headlights will
  193. speedometer reving with tach
  194. hoses for powersteering
  195. weird cut out when i ;punched it
  196. i need a 92-96 lude shell
  197. yea sell it to me
  198. thx
  199. over done question probably about idle jumping until car is warm
  200. my brake lights are always on
  201. no heat
  202. Engin Swap lude 92s to H22
  203. 95 h22 lude egr problem
  204. Should I Sell the Lude?
  205. Swapped to h22 now what?
  206. how do you get the steering wheel off 95 prelude
  207. Question: gas smell
  208. Question about 95 prelude
  209. Need Help With My Flashers
  210. anyone seen a k swap in a bb4 prelude?
  211. Question On a 93' Prelude
  212. I have a h23 head question...
  213. Changing ATF write up
  214. anyone got any body work tricks
  215. recommended speakers????
  216. everyone what would u do and is it possible
  217. Best Tire Size
  218. Blown Head Gasket?
  219. Infinity Basslink Cracked Case
  220. Transmission Jumps when you come to a complete stop!!!
  221. engine swap
  222. Rack and pinion
  223. Engine Swap. How to install VTEC
  224. Need techie help!
  225. 96 prelude Si auto Value???
  226. Apexi ws2...not to happy
  227. headers?????
  228. Weird transmission problem
  229. give me some quick and easy mods for a h22a1
  230. TN title question
  231. question on 92-93 prelude
  232. Camber Kits
  233. Get your 2007 Honda Prelude Calendars!
  234. Looking For 96 Honda Prelude Shift Assembly
  235. Car shakes.. Really bad...
  236. Nieve question
  237. Need advise..ideas..
  238. *Newbie* White exhaust smoke/smell in car
  239. BB6 Grilles
  240. 01 Prelude odd shifting/transmision
  241. Sunroof Stuck
  242. 5th gen ABS is disabled and ABS light is on
  243. RARE JDM RIMS 4x114.3 THAT FIT YOUR 4th GEN PRELUDE
  244. New Altenator
  245. 95 Prelude Vtech Abs Light Won't Go Off
  246. 97 Prelude SiR (4ws) -Japanese
  247. SON OF A !@#(*$&#(* This sucks...
  248. Vehicle speed sensor questions
  249. What are these white marks?
  250. VTEC Problems
