- 1995 Legend Coupe L cranks but will not start
- Temperature gauge
- Need help with Legend cruise control, please.
- a lil knowledgeable help
- Check Engine Light
- I need help asap please help on a 2nd gen Acura Legend
- Acura RL Remote keylesss FOB
- '97 RL very bad rt front vibration/shimmy.
- 91 acura not shifting
- Start run prob 90 Legend
- 91 Acura Legend not shifting
- looking for 91-95 legend coupe for trade
- 92 legend sedan seat compatability
- Running Lights
- 92 legend overheating
- acura legend 1990 6 cylinders
- 91 legend going to aftermarket stereo
- OFFICIAL: SSR Introduction and Vienna Kleid Wheels on the New RL!
- 2005 Acura RL- Sound system ground problem
- Running lights & dash lights go off when headlights turned on.
- Acura RL-Acura TL rack & pinion swap!
- RL On remote lock no confirmation beep.
- 92 c32a honda legend starting problem
- 91accura ledg.noD4 no start
- fuel filter location
- 88' legend shuts off wont start
- O-Rings...
- KA7 and KA8 Strut tower bars!
- Thinking of coming back.
- 92 Acura Legend
- 92 Legend Transmission
- hot/cold running a/c
- No high beam on my 91 legend
- 1988 Legend.Window will not go up
- WTB: '88 Legend Mileage Computer
- 87 acura legend coupe condenser fan fuse keeps blowing
- Front and Rear struts for 97 RL
- Sudden Shut off
- Fuel pump relay
- 97 RL Power Window Problem
- headers n suspension
- 93 Legend Getting Hot.
- 92 acura legend
- 95 Legend - Radio Problem
- stock stereo
- 1990 legend 4 sedan warning light comes on ANTI LOCK then air condt. quits repeatedly
- please i need help
- 96 RL 6 cd changer
- 89 Drivers seat will not move
- 1989 Legend
- 1989 Legen
- 94 legend gs transmission problem
- transmission
- Replacing rear quater glass in 89 Coupe
- odd problem
- 88' Acura legend trunk won't open
- HELP! 91 legend only starts when its warm outside
- Rough Idle, lost power legend 94
- 93 Legend-starts and immediately dies
- TDC Sensor!!
- heater core
- '99 Acura RL 3.5 radio relay?
- 2000 Acura RL dash kit???
- Parting out '96 RL
- ledgend acura 93 starting problem
- EGR Valve
- 1994 Acura Legend - Rough Idle
- MR Rl
- 91' legend tranny problems
- NEED 89 Acura Legend 5 speed transmission!!
- High Decibal Whizzing Sound
- 92 Legend Overheating- NEED HELP!
- Acura Legend store now open!
- Rear Brake Job
- 1991 Acura legend cooling system
- Acura Legend to buy ,how reliable??common problems??tips??
- 90 legend cpe no brakes no fluid leak
- Jarring Noise in '94 Legend
- RL Design
- Brakes & loud tapping sound from lifters or values
- 93 legend shifts hard and lifter noise adj?
- My odometer/trip gauge is dead. My speedometer and tach are fine.
- Timing Belt
- 93 automatic wont shift into d3,2,or1
- 3.5 head gaskets on 3.2 engine
- Will The Acura Dealer Service My 01 Rl
- The Telion Chip Thread
- 3.5 (C35a/RL) Aluminum Crank Pulley Group Buy is on
- 1990 Acura Legend LS sedan for sale
- 94 Legend check engine light
- rl will not start
- wtb parts 1990 ls cpe
- head gasket kit
- 1996 Acura Rl
- 89 Acura legend water pump trouble!!!!!
- 89 legend coupe L manual- brake goes to floor when engine is hot
- 1991 Legend Giving me a Headache
- 2005 Acura RL AFS Light Always On
- When did the Legend switch to r134a?
- 1991 Acura Legend Coupe -
- 92' Legend with many probs?? Need HELP!!!!
- Looking for 17 inch Acura Rims
- Engine Swap
- Heating prob? 88 Legend Coupe
- 03 honda civic remote control programming
- 1998 RL, what is different from JDM version?
- Radiator hoses
- 91 Legend Door removal
- just a quick question
- I just got my 90 Legend and need someone to clarify and all help is needed...
- Possible new owner of a 98 Acura RL (pics!)
- door lock 94 L sedan
- 2000RLTiming Belt Cost
- moon roof want open
- 1995 Legend overheating help!
- fuel injection maintenance
- hard start and black smoke
- Porb starting when car set in sun to long
- Legend engine and tranny weight?
- 2006 RL with Technology Package... upgrades?
- 91-95 acura legend sedan parts
- 94 legend problem
- Battery replacement
- Check Engine - starting - gas cap?
- 95 Legend grey exhaust smoke
- 91 legend -where's the control module?
- 88 acura legend body kits
- Struggling Start-Up & Rising Coolant Level
- Parting Out - 1991 Legend Sedan Type I engine and 5-speed manual transmission
- Where can I get just the lens to my Rear Right Taillight.
- Radio, Interior light and cigarette lighter - doesn't work
- Need help to program a 95 integra GSR remote transmitter
- Advice on what to do with a 90 Legend Coupe
- Help: 00-03 RL Climate Control Wire Harness Diagram Needed!
- need help!
- abs light
- Wiring harness...seat
- engine interchangeability
- 96 RL entire car shakes and shimmies at 50 mph
- 88 Acura Legend Stalling
- Remote for a 94 Legend
- P0141 & P1456
- driver seat problems!!!!
- Dead Legend
- Oil Pan removal
- A/C blowing hot air
- 1991 legend problems
- Remove alarm on 89 Legend Coupe?
- ac compressor question?
- 92 acura legend on the rise...
- brake lights stay on...
- 1989 Legend
- 95 Acura Legend overheating
- Fuel relay acura legend 1988 HELP?
- Mold cabin - Defective Design
- instruction for the 97 honda legend (RL) remote control
- Help need with '92 Legend - weird idling - temp.gage
- 1st Gen Legend Transmission
- bumper lens
- My daily driver! 94 LS sedan
- reving at idle
- 92 Legend Starts but won't stay running
- 91 Legend sedan the (HULK)
- Me too
- D4 Light out
- is it worth it to put a cold air intake on my car
- 96 RL front end vibration
- 93 acura legend surging at idle and more
- Matching HID lights
- 92 Legend D4 flashing
- defroster switch assembly where can ibuy ?
- I'm looking for some proformance!!!
- 94 legend intake.
- 99 Dash Pics/engine
- Change alarm back to beep
- Vibration after timing belt change
- is a 92 Legend a good buy??
- 92 legend cruise control
- yo check this out
- Window issue
- 99 Rl Custom Interior Pics
- Antenna Adapters
- Legend reliability
- There is no fire
- 2002 RL - engine oil leak
- 2006 RL Wheels
- Topside Oil Change??
- Electrical problems...i think
- Head Light Switch
- my custom RL grill check it out
- 92 Legend not shifting into overdrive
- remote
- 93 Legend stereo
- 91 Legend No Check Engine Light /no Spark /no Fuel Pump
- 92 acura legend problems
- Dual-piston caliper piston sizes?
- Motor Mounts????????
- legend trany problem
- 95 Acura Legend
- 92 Legend Starting Problems
- Average mileage
- Relay Test could someone clear it up for me?
- '88 Acura Blower Motor: Help!
- O2 sensor
- 92 acura legend question confirm
- Acura Legend emission problems
- performance chip for 06 RL
- custom RL pics
- 89 Legend Coupe wont start
- Automatic transmission - need advice
- Driver Door Lock Actuator
- 2006 RL price question
- Honda legend 1996 Navigation/T.V(Please help)
- 1990 Acura Legend warm start problem
- New 97 RL owner in England - Trying to sort out 1st to 2nd gear noise
- Can't get check engine light to "come on".
- Pilot change sound for door lock confirm
- A video of my 3.5L RL powered Acura Legend coupe.
- 95 LEGEND AC just QUIT!
- Turbo
- Acura '98 RL with no heat
- does the differential make a loud noise
- legend 96 timing belt faulty replacement ?
- 89 Legend overheating -Help! Help!
- trunk plastic pieces
- Trans clunks from 1 to 2 only when warm
- '96 rl engine revs when stopping!
- Need help! How to program 98 infiniti remote control
- What's new in the 2007 Ridgeline?
- Interest in Legend. How cool are they?
- 01 Odyssey AC Blew Mist
- Removing 97 acura door panels HELP
- gen I Collector
- 2007 Acura RDX
- Legend CAI
- '96 acura rl premium speaker info?
- Should I pop for a new engine for my 1991 Legend?
- 1991 Legend ac not blowing cold
- 1997 RL, Tuneup parts
- Keyfob programming 91 Legend
- Automatic Noise Control????
- 2006 Honda Civic
- legend auto tranny jerky
- Power Seat
- I Need Help!!!
- 92 Acura legend Timing
- trans fluid level
