questioning boost on B18B
i'm wondering if boost is right for me. I'm not a tuning freak or anything so if something were to go wrong with the car then i probably wouldn't know how to fix it. Do you think it's okay that I boost? I do have close friends that could help if something went wrong, but im personally not a car genius.
Do you think it would be OK to get turbo?
my other questions are this. If i were to buy something like a greddy turbo kit (i know its not the best but in example), would i need anything else that the kit would not come with? i.e. injectors, fuel management.... are these a must? or anything else?
i just want to know a ball park range of what i would most likely be spending going the turbo route if i pieced up a kit myself..
Is a STOCK B18B good for 8psi boost? how long would this app last?
rebuilding
The B18b is just begging for a turbo.. I definately am a fan of turbocharging the LS but youll want to look into doing some other things at the same time. Such as plugs and wires, and maybe a mild head job. But you can turbo it as it sits and run like 5-7 psi all day for a good while. I turbo'd a LS/VTEC and it ran for 2 years b4 I took it apart to go all motor. Its pretty much up to you.
