Car Overheating HELP!!!
Old 08-31-2003, 01:11 PM
Orange95GSR
Orange95GSR's Avatar
Default Car Overheating HELP!!!
The car seems to be loosing fluid from under the car under a lil black box (not the radiator) on the driver side. It seems the be dripping off one of the bolts. The box is a black box the shape of a square with 4 bolts in it. Any suggestion would be appreciated.
Old 08-31-2003, 03:14 PM
drift
Flaccid Member
drift's Avatar
take it to a mechanic to be inspected. your description is horrible.
Old 08-31-2003, 06:08 PM
Orange95GSR
The "fluid" that im talking about is the coolant that is leaking.
Old 08-31-2003, 08:23 PM
Nelson
Administrator
Nelson's Avatar
Check your water-pump...
9Y0 Cayenne GTS
E46 ///M3
YD4 MDX
- SOLD
EG Ferio - SOLD
FA Ferio - Returned
www.NelsonLee.net
Old 09-04-2003, 09:38 AM
SUPER LAUBO
KiMBO's Hubby
SUPER LAUBO's Avatar
i believe he was referring to the description of your mystery "black" box. is this the black box that's visible from the top of your engine or the black box behind the intake manifold?
the black box on top, driver side is probably your cruise control. the other black box deals with vacuum..i think it's your EVAC tank... i keep forgetting the proper name.
don't worry, it's probably an old cracked hose that needs some TLC. get underneathe the car and trace it back.
Old 09-16-2003, 04:43 PM
Orange95GSR
The black box is at the bottom of the car it is to the right of the driver side wheel. It has some bolts in it, thats where I see the coolant leaking out from and it leaks a lot. I dont think its the hoses because the hoses are on the other side.
Old 09-17-2003, 07:21 AM
JimBlake
JimBlake's Avatar
I've got a '95 GS-R & I can't follow your description of the 'black box'. I can't think of anything down there to fit the description.
When my water pump leaked, the coolant ran down & dripped off the oil pan bolts near the crank pulley. Almost made it look like it was leaking out from where the crank comes thru the lower timing cover. Obviously, I knew there wasn't any coolant down there, but the water pump is halfway up the engine on that side.
Old 09-17-2003, 08:20 AM
Orange95GSR
ok thats what it is the water pump, thax for the help
