axle help
axle help
can i use a 90-93 driver side axle on my 1st gen b16a with the b16a intermediate shaft? i have the b16a axles but the one is bad and i'm just looking to replace it. thanks.
http://www.hasport.com/News/Articles...rt%20Axles.htm - you should be able to tell from this which axle you need
b16a 2nd gen axle?
I just put a jdm b16a into my 95 civic with 94 gsr axles and it seems that the driver side is like an inch too short. The boot looks stretched and when I put the car in the air the transmission side of the axle (on the intermediate shaft) was actually coming out. Did I get the wrong axle? Thanks
axles
i did the same swap in my 1997 civic you can use the delsol vtec to i think there the same as the gsr axles i should work with the swapmine did i hope this helped
