Results 1 to 2 of 2
Thread: Some serious block building Q's
  1. #1
    Ok, heres what I'm looking into doing this winter:
    I have a B16a2 and have invested some serious cake so far so I'm going all the way. Ok the b18 and b16 blocks are identical except for the stroke and sleeve length, correct? And pretty much all the cars breaking 10 et's have the H22 or the B20, so I wanted to know if 84mm darton sleeves for a B18c will work with a B18 stroker kit in a b16a block?
  2. #2
    Join Date
    Jun 2002
    Location
    albuquerque, new mexico
    Posts
    229
    the B16 has a shorter deck than the b18...for a 10 second honda..your gonna need lots of boost..and a bigger engine than a b16...you can get a b16 resleaved by eagle to 84mm i believe...and they garuntee them to like 40lbs of boost..that would probably be your best bet and way to go
  3. #2
    Honda-Acura
    Honda S2000
    Honda-Acura
Bookmarks
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
Search Engine Friendly URLs by vBSEO 3.5.2
