Page 1 of 2 12 LastLast
Results 1 to 30 of 31
Thread: thicker thicker pistons [B18C into DA Integra]
  1. #1
    I'm about to put a b18c1 into my 93 ls, but I wanted to do some internal engine work to the new motor before installing it. I dont plan on ever turbo-ing it, so raising the compression ratio sounds like a plan. The GSR starts at 10, and the tegra type R has 10.6. My friend was telling me about people who have gone to 12... I don't know enough about getting thicker pistons to know what all there is to consider. Should I stop at the tegra Type R's 10.6, or should I go higher? I've also heard that the civic type R's ratio is higher than the integras, but I dunno what it is. What do you think?
  2. #2
    I missed Sean sherwood's Avatar
    Join Date
    Aug 2004
    Location
    Fairfield/Bridgeport CT
    Posts
    11,284
    you can go higher, but the higher the compression ratio the harder it is to tune it to run on pump gas. i'd stick with something less than 12:1, it really depends on how much time you are willing to spend on trying to make it work well on pump gas and how much power you are looking for.
    11-12:1 with headwork and some new cams i would imagine to be an ideal situation. you would subsequently need to increase the redline and also upgrade other misc. parts of the rotating assembly.
    as far as the compression ratios go-- the gsr head will net you a higher compression ratio than a type-r head. so putting in JDM spec type-r pistons will probably push you to about 11.4:1
    on a more personal note--
    if you are going to do internal work you might as well go for forged internals and then boost. the time and money spent on headwork alone will equal the ammount of a good turbo setup, and dollor for dollar, horse for horse, the turbo setup, with new internals and tune time will net you major gains. not only that but they are fully scalable, allowing you to run pump gas and then still have a different ECU map for the track, or any other of the million ses for differnt powerbands.
    1.8L Acura Integra GSR: Back where it belongs.
    3.2L Pontiac Tran-sport Montana: that things about to go.
    2.2L Honda Accord EX: Sold to my sister
    232CI Mercury Sable: Sold to some lady, by my father, while i was on a camping trip. IMM232
    http://imagegen.last.fm/minimalDark/..._vigilante.gif
  3. #3
    On permanent hiatus
    Join Date
    Jul 2004
    Location
    A forum with actual tech
    Posts
    9,716
    Paired with an aggressive pair of cams, a higher compression ratio will be a cood combination. You will need some sort of fuel management with raised compression since the fuel and ignition curves will change.
    The P30 (JDM B16A) piston seems to be a good choice since it will raise your static compression ratio to around a pump gas friendly 11.5:1. The PCT (JDM B16B) piston will raise static compression to around 12:1 which will require a decent tune in order to run the car without detonation and you may run into valve-piston clearance problems with large cams.
  4. #4
    What kind of HP gains could I expect if I ONLY did the b16a pistons?
    Thanks
  5. #5
    higher compression = high octane gas = a lot of money
    buy some skunk2 pro2 cams they kick ass
    i put them in my 91 crx and gained like 70 hp my motor woke the fuck up and buy some cnc heads b ut there like 3grand which is expensive
    ~urbanSTREETZ~
  6. #6
    Quote Originally Posted by awormofearth
    Thanks
    none really there just pistons nothing special about them if u want pistons find some dome pistons it will do more than stock
    ~urbanSTREETZ~
  7. #7
    On permanent hiatus
    Join Date
    Jul 2004
    Location
    Posts
    9,716
    Quote Originally Posted by urbanSTREETZ
    Your advice sucks.
    70hp with S2S2 cams? Right. Too bad Skunk2 states that with proper tuning, increased compression and a high flow manifold, the gains will be less than 25 hp.
  8. #8
    Quote Originally Posted by Däs Schmoo
    Your advice sucks.
    dude bullshit ill even email you the dyno sheet it raised my hp from 170 to about 250 with them 2 cams so i have no clue where u looked at but i know what the the fuck it did to my motor
    ~urbanSTREETZ~
  9. #9
    Join Date
    Aug 2004
    Location
    Posts
    11,284
    there is no way in hell-- and you say you already had 170 to the wheels?
  10. #10
    Quote Originally Posted by sherwood
    yea um maybe someone knows what he is doing to get hp out of his car
    ~urbanSTREETZ~
  11. #11
    Join Date
    Aug 2004
    Location
    Posts
    11,284
    i'm not saying you can't do it. but not in the way you suggested.
  12. #12
    On permanent hiatus
    Join Date
    Jul 2004
    Location
    Posts
    9,716
    Where is the dyno sheet already? Just attach it as an image.
    If it were that easy, why the did I waste all that time and money on a turbo setup when I could have bought a pair of cams and made just as much power? It isn't plausible, so stop playing it off like it is.
  13. #13
    I <3 Boost dubcac's Avatar
    Join Date
    Jan 2001
    Location
    Westside til I die
    Posts
    56,393
    This guy just doesn't stop. 70hp from cams, writes service bulletins for acura, MTF is some magical fluid..what next?
    2011 WR Blue Mica Subaru Impreza WRX - AEM.CobbTuning.FastMotorsports.Grimmspeed.Invidia.Kartb oy.MR.TorquedPerformance.WorkSuperWheels
  14. #14
    265 whp 170 tq
    alright here is mhat ive done to my motor
    b16 b block 13.2/1 comp
    balanced crank 89mm
    probe rods retanged for gsr bearings. drilled the stock oil holes like ls rods
    gsr oil pump
    wiseco 8.25cc pistons milled .050 off the top
    Bdl block guard
    custom breather kit
    Competition head from PURE TUNING
    supertech valves .5mm oversized flat faced
    custom valve springs
    stock retainers modified for big lift
    skunk2 pro 2 cams
    pro series cam gears
    jg edlebrock intake manifold
    68mm throttle body
    precision 440cc injectors
    hondata
    carbon fiber velocity stack with 3" short ram
    SMSP b19 1 piece header
    msd sci ignition
    nology wires
    ~urbanSTREETZ~
  15. #15
    ~urbanSTREETZ~
  16. #16
    ~urbanSTREETZ~
  17. #17
    alright it might not of been a 70 hp gain but it was atleast a 69 hp gain
    ~urbanSTREETZ~
  18. #18
    Senior Member mberndt's Avatar
    Join Date
    Jun 2005
    Location
    Allentown PA, - Phila, PA
    Posts
    672
    Oh, I see your mods, gee lemme guess, you paid someone to do all that?
    Or did you just make it all up? LOL
    IMO, I don't believe you cause of the way you talk. If you really had all that work, then why did you say you added a cam and got 70 HP. Did you forget about all of the other mods you had done?
    Oh and I do know how a clutch works, I don't think you do...
    Dude, seriously you make yourself look like a complete idiot, LOL
    Just stop talking shit on here, cause obviously you don't have a clue what your talking about...
    You make assenine comments and try and back them up with retarded school kid talk.
    P.S. I'm not trying to insult you but seriously, GROW UP!
    ----> Mike
    -00 S2000 Silverstone/Black - New addition!
    -95 Subaru Legacy AWD - Beater
    -97 Prelude Type-SH - Totalled - R.I.P.
    -93 Civic DX Coupe - Far from Stock
  19. #19
    piss off bitch im a big boy i can wipe my own ass
    ~urbanSTREETZ~
  20. #20
    On permanent hiatus
    Join Date
    Jul 2004
    Location
    Posts
    9,716
    It's cubic_inches N/A archrival.
  21. #21
    Join Date
    Jun 2005
    Location
    Posts
    672
    Really? How old, 14??
    Nice comeback LOLOLOLOL
    Don't come on here like your some tuff guy, cause no one gives a shit...
    OBVIOUSLY, from your demeanor, everyone on here can see what kind of idiot u are...
    We all know that you wouldn't say that if I was in front of you LOL...
    Stupid ass LOL
    ----> Mike
  22. #22
    Join Date
    Jan 2001
    Location
    Westside til I die
    Posts
    56,393
    I was thinking they were buddies.
  23. #23
    been there done that Snoopy's Avatar
    Join Date
    Jun 2002
    Location
    916
    Posts
    30,607
    so you were making only 170hp with the mods you listed below? looks like someone DOESNT know what they're doing.
    this is my signature. there are many like it but this one is mine.
  24. #24
    SDSU Basketball hitman619's Avatar
    Join Date
    Jul 2005
    Location
    Diego
    Posts
    9,395
    Internet Racer..
    ftl
    Benzino: Any mother f**ker who wants to write something bad about me, I’m f**king coming to their doorstep.
  25. #25
    Vivere est Cogitare TheOtherDave™'s Avatar
    Join Date
    Nov 2002
    Location
    The Left Lane
    Posts
    51,551
    Oh really?
    You posted a fully built motor (which I for one do not believe you own).. and claim that the cam was the sole part to deliver an additional 70 hp.
    Then, after talking a big game, you post a question like this:
    http://www.honda-acura.net/forums/sh...d.php?t=243780
    Perhaps you need to tone down the ego and stop showboating with toys you don't have.
    :: david - supermod
    :: PSN - TheOtherDave-tm
    :: HAN Integra FAQ: Utterly antique, but still useful... sort of.
  26. #26
    Join Date
    Jan 2001
    Location
    Westside til I die
    Posts
    56,393
    Why don't you swap that beast of a motor into your 86 Pony?
    http://www.honda-acura.net/forums/sh...d.php?t=243753
  27. #27
    gsrcrazy1 gsrcrazy1's Avatar
    Join Date
    Oct 2004
    Location
    SoCal
    Posts
    154
    im kinda late...but still funny as hell!!! lmao....
  28. #28
    Senior Member silvic00's Avatar
    Join Date
    Jan 2005
    Posts
    871
    this "kid" is almost as bad as colem, best advice awormofearth dont listen to urbanstreetz....instead take advice from Provocateur, snoopy and sherwood
  29. #29
    On permanent hiatus
    Join Date
    Jul 2004
    Location
    Posts
    9,716
    Holy hell.
    Why is it necessary to revive 6 month old threads for no fucking reason?
  30. #30
    Join Date
    Aug 2004
    Location
    Posts
    11,284
    Quote Originally Posted by Provocateur View Post
    Holy hell.
    Cause they are new... but I have to say this thread was classic.
  31. #30
    Honda-Acura
    Honda S2000
    Honda-Acura
Bookmarks
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
Search Engine Friendly URLs by vBSEO 3.5.2
