Results 1 to 2 of 2
Thread: Help please with friends 97 Accord LX & aftermarket ignition system
  1. #1
    Junior Member ITR#974's Avatar
    Join Date
    May 2002
    Location
    Louisiana
    Posts
    13
    OK this is what he has:
    MSD Digital 6 ignition
    MSD Blaster SS coil
    MSD 8mm wires
    This is in a 97 Honda Accord LX (his model has the external coil in it!)
    When the ignition is hooked up, bypassing the extenal honda coil, it's just the Digital 6 & the SS coil he can drive the car for about 30 miles then the check engine light comes. He resets the Digital 6 and the car runs fine, again, for about 30 miles then the check engine light comes on. Keeps repeating itself.
    He then tried adding the MSD 8910 Tach adapter just like the tech guys at MSD said he should. The car starts up and runs fine till he takes it out of gear and the car kills on him instantly. The car won't start again till he re-hooks up his factory coil.
    He called MSD back today and they are more puzzeled than us, talk about your tech support. Anyway can anyone help me out here. Does he have the wrong stuff, or has anyone run into this same problem?
    Thanks for all the help in advance!
    Jurassic
  2. #2
    fear the dark side
    Join Date
    May 2002
    Location
    Raleigh NC
    Posts
    146
    what check engine light was he getting?
  3. #2
    Honda-Acura
    Honda S2000
    Honda-Acura
Bookmarks
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
Search Engine Friendly URLs by vBSEO 3.5.2
