ls/vtec swap problems!
Old Nov 13, 2005 | 10:05 AM
IcY's Avatar
IcY
Default ls/vtec swap problems!
ok i just finished my swap and im running into problems. First problem is it idles at 2500rpm and stays there no matter what.... the butterfly is closed all the way and i checked if there was a leak but didnt see anything. The only way i can drop it down by about 800-1000 rpm is if i plug the hole in the tb to the tps. My next problem is my engine light is on and when i go to check it nothing flashs (just my srs where i have a problem). if anyone can throw out ideas on what it could be id love to hear it...
thanks in advance....
Old Nov 13, 2005 | 03:21 PM
teg92's Avatar
teg92
WHAT OK YEAH!
have you checked for vaccum leaks?
Old Nov 13, 2005 | 03:54 PM
b16ahybrid's Avatar
b16ahybrid
Fix your vac leak and your idle will drop.
How are you checking for codes?
Old Nov 14, 2005 | 04:54 AM
IcY's Avatar
IcY
through the jumper but it wont flash..... my srs light does because i have a problem there but my engine light stays solid
