engine problem
Old Sep 6, 2005 | 01:42 PM
92b18hatch's Avatar
92b18hatch
Default engine problem
after i drive my car and get it all warmed up then shut the car off, when i press the gas it will cut out on me for a second and then come back. i had good fuel pressure when i checked. i tryed a new fuel pump relay and that didnt work. help!?
Old Sep 7, 2005 | 05:32 AM
psx_pat's Avatar
psx_pat
Did you pressed it Wide Open Throttle all the way very quick? Or you just tap the gas very quick (tap about 25% throttle and then release it very quick)?
Old Sep 7, 2005 | 01:31 PM
92b18hatch's Avatar
92b18hatch
i mean after driving the car i can be driving at 40mph and it will just cut out on me for a second and then come back without me moving my foot. for some reason it doesnt to do if it sits and the car cools down, it only happens when the car is warm.
Old Sep 7, 2005 | 04:40 PM
IntegraType-R's Avatar
IntegraType-R
ALL MOTOR KING
igition.. check your igition.
Old Sep 7, 2005 | 04:41 PM
IntegraType-R
ALL MOTOR KING
igition.. check your igition...depending on the motor i'd suggest replacing the whole dizzy setup but check your coil, igintor and coil module to make sure their working properly alot of times of that coil/module get too hot they dont work right if their old.
Old Sep 7, 2005 | 05:24 PM
92b18hatch's Avatar
92b18hatch
sounds good, ill tell you what happens
