Vtec question for newbie
Old 01-11-2005, 05:59 AM
oldcivic
oldcivic's Avatar
Default Vtec question for newbie
What is the Rpm engagement point and oil pressure reading for a mini-me conversion of a b15y7 block
Old 01-11-2005, 06:44 AM
dustimus
Better golfer than you
dustimus's Avatar
Whats a b15y7??????
Old 01-11-2005, 08:07 AM
b16ahybrid
b16ahybrid's Avatar
I'm going to take a stab at this one.
I believe he means d15b7.?
Anyways the correct way to find the rpm where the cams should switch over is on a dyno. Doing so otherwise is pointless and you could be losing power.
Old 01-11-2005, 08:08 AM
honda_pilot
DeeCeeFo'
honda_pilot's Avatar
I dun think thats a noobie question :dunno:
Old 01-12-2005, 09:22 AM
vinnyzcrx
vinnyzcrx's Avatar
no theres a d15y7, its in the 92-95 civic hx. it would be a hassle because that engine came duel carborated. i dont really see the point in putting vtec on a carborated engine. convert it to fuel injection first then add vtec. i recommend the 99 civic ex intake manifold.
Old 01-13-2005, 04:49 PM
b16ahybrid
b16ahybrid's Avatar
Where is this suposed obd-1 carborated civic? I believe everything from 1988 up is fuel injected.
The Hx didn't come out till 96 and only the dx,si,ex,vx,and cx were available inthe 5th gen civic.
They are all fuel injected.
The hx came with a 115hp vtec-e
Old 01-13-2005, 07:43 PM
yellow civic ex
ghey slow d16 modder
yellow civic ex's Avatar
if you're just using the ex ecu then it's around 5800rpm.
