Drag Strip From the staging lanes to the finish line, this is the spot for on-track drag racing discussion.
What should a 91 Civic Si hatch?
Old 05-22-2007, 09:50 AM
gingas
gingas's Avatar
Default What should a 91 Civic Si hatch?
With a B18A & only mods SRI/ DC headers in the 1/4 mile??
Old 05-24-2007, 11:51 PM
theturbocrx
theturbocrx's Avatar
depends on your weight, wheel and tire size and if your a granny shifter or not.
With the stock engine they run around the 16.7 second range I believe.
So with your set up, and lets say 15" rims on 50 profile tires @ 2000 lbs. you might be able to run late 13's to mid 14's that is if your putting out 150-180 whp. I would say you are most likely in the 14's but theres only one way to tell for sure, so take it to the track.
Old 05-25-2007, 04:04 PM
JoePoonani
Lexus Tech y0!!
JoePoonani's Avatar
I'd say mid to low 15s if you're a good driver and have a good launch.
Old 06-17-2007, 03:17 AM
ef9dave
ef9dave's Avatar
low 14 verrryyyyyy high 13 matters i car`is gutted or not.and driver
Old 06-17-2007, 04:16 PM
Snoopy
been there done that
Snoopy's Avatar
you're on crack
a b18a with i/h is putting out less than 130whp. paired with a shit for acceleration tranny, low 15's are more probable.
Old 06-21-2007, 09:15 PM
18crx
stock booster
18crx's Avatar
my swapped crx ran 14.6 with int and street tires and ls tranny before turbo.. thats not to bad
