Drag Strip From the staging lanes to the finish line, this is the spot for on-track drag racing discussion.
launching
Old 04-15-2007, 12:53 PM
ls_on_boost
ls_on_boost
ls_on_boost's Avatar
Default launching
hi anyone got any launching info for coming out the hole hard even on street tires i heard you gotta burn the clutch is this true and how do i do that
Old 04-15-2007, 02:00 PM
Snoopy
been there done that
Snoopy's Avatar
burning the clutch is not what you wanna do. slipping it is what you want.
bring the clutch up right to the point before it engages and hold it there until the last yellow if you're at the track. smoothly and quickly let it out while at the same time giving it more throttle and modulate the two until you get traction. takes practice.
Old 04-15-2007, 03:39 PM
dubcac
I
dubcac's Avatar
Launch at redline...it's the only way to put the power down correctly.
Old 04-15-2007, 06:11 PM
ls_on_boost
ls_on_boost
ok thank you friday i'm going to the track i ran in the 8th on steet tires 9.64 ls turbo integra let's see what i do with your technique
Old 04-16-2007, 11:35 AM
18crx
stock booster
18crx's Avatar
I LAUNCH IN 2nd at 5 grand.then shift. thanks god for new setup.
Old 04-16-2007, 02:46 PM
ls_on_boost
ls_on_boost
u lanch at five grand then shift to what to 3rd more info
Old 04-19-2007, 11:22 AM
CrJenkins13
CrJenkins13's Avatar
If you've got a stock motor I wouldn't do more than 4k.
Old 04-19-2007, 11:38 AM
Snoopy
Snoopy's Avatar
i would. depends on the tires.
Old 04-19-2007, 02:26 PM
ls_on_boost
ls_on_boost
right now i have no names but i just bought some bf drags and my car is turbo when i heat up my tires the car starts bouncing i guess the tires are tring to grip also i'm on 17s the drag radials i bought are for my si stocks
Old 04-19-2007, 09:39 PM
2001TEGGSR
2001TEGGSR's Avatar
Thats called "wheel hop." Do a search for it, there are several remedies depending on how far your willing to go. i.e. LSD, Various types of Traction Bars, etc.
