Drag Strip From the staging lanes to the finish line, this is the spot for on-track drag racing discussion.
Slicks options
Old 04-09-2005, 09:19 AM
westcoaststyle
Still here... sorta...
westcoaststyle's Avatar
Default Slicks options
Need some advice on slicks, guys. What do you recommend and where can they be purchased? Looking for something that will fit a 15x6.5" rim.
Thanks!
Old 04-09-2005, 10:00 AM
BoostedITR41
BoostedITR41's Avatar
I would get a 15x7 wheels cause 6.5 is too small for your power. also run 24.5x8x15 slicks
Old 04-09-2005, 04:18 PM
b16ahybrid
b16ahybrid's Avatar
Thanks!
24" m&h or m/t should do you good.
Old 04-09-2005, 09:18 PM
30psiciv
www.speeddreamz.com
30psiciv's Avatar
The m&h are a much softer compound than the mt. The size you need is much more a function of your tranny vs roll out vs hp. Do you plan on using 5th, probably not.
If you want to know what I think about each manufacturer lmk because I have used them all.
Old 04-10-2005, 11:03 AM
TeHJuSTiN
NAM #0001
TeHJuSTiN's Avatar
Judging by his trap speed he's probably rolling across the line at ~121mph. I'm not sure what tranny he has but if he has the GSR, he's probbaly red lining 4th.
Old 04-10-2005, 11:13 AM
BoostedITR41
24.5" slicks should allow him to stay well into 4th
Old 04-10-2005, 11:54 AM
westcoaststyle
Depends on how badly I spin. I have to shift into fifth now and then. I might have the rev limit upped a bit so I can use more of the lower gears and hopefully not bounce on the fuel cut in 4th.
30psiciv, what axles are you using?
