Go Back   Honda-Acura.net > Tech Forums > Do It Yourself
Thread Tools Display Modes
Old 01-28-03, 09:32 AM   #1
wadzii
fear the dark side
Send a message via AIM to wadzii
H22/accord swap faq's
H22 Swap Faq's
General Swap Info
Use the accord wiring harness and lengthen/modify the harness to fit the H22.
ECU Wiring For Obd1 ecu's
vtec soleniod: Pin A4
vtec pressure switch: Pin D6
knock sensor: Pin D3
Secondary Intake Soleniod: Pin A17
Use accord axles
Buy a manual for the year prelude your H22 came from, the year of the ecu you have and the car.
ex. 97H22 with p13 obd1 ecu into a 94 accord. Get a 97 prelude helms,
a 93 prelude and a 94 accord helms manual. Goto www.helminc.com to get them
Air Conditioning
To keep ac take the bracket off the F22 and put it on the H22 and use the accord compressor
Power Steering
Use the prelude pump and bracket
For 5TH gen Only
Use 92-96 prelude timing belt side mount, keep in mind that you will have to grind it down to fit, and the rest accord mounts
Swap pin A6 with pin A11, the accord is unique from other hondas. those 2 wires control
the o2 sensor heater and egr control soleniod. they are backwards in the accord
The exhaust must be reduced in length and it is reccomended that you get a cat to match the year
header you have. (ex. if you have a 94 h22 header get a 94 prelude cat, etc) the 97+
header is different and the cat isnt the same.
To keep the Powersteering you must have a custom line made using the lower 1/2 of the accord line and upper 1/2 of the prelude line OR use a 97 prelude line
For 4TH Gen Only
Use all accord mounts
The exhaust bolts up to 93-96 Prelude header
No pin swaping is required
No changes need to be made for the power steering hose
obd2 engine in a obd1 car
ex. 97+ H22a4 into 90-95 accord
You must get an obd1 ecu, obd1 injectors and obd1 distributor.
obd1 engine into obd2 car (5 Spd Only)
ex. 93 H22a into 97 accord
Get your favorite obd2-obd1 conversion harness, skunk2, hondata, etc
Move the crank angle sensor wires from the crankpully/timing belt area to the distributor.
Repin the distributor connector using the obd1 plug that should have come on the engine, put
the 2 wires you just moved into the 2 left over pins on the plug.
Internal/External Coil Issues
If your car came equiped with an internal coil then the jdm h22 distributor will plug right
in no problem. However, if your car had external coil then you will have to modify one plug.
The plug you will need to modify is the plug that went to the stock coil. There are is a yellow
and a yellow/black wire, splice those 2 wire together. The green wire is useless, dont worry
about it
What Cap To Use
For JDM internal coil use 00 civic SI or 90-93 accord ex cap and rotor
For USDM internal coil.... DUHH!!! use 93-95 prelude vtec cap
MSD Install
For External Coil equiped cars
Cut the Plug that went to the stock coil off, splice the yellow and yellow/black
wires together, and you will also need to hookup the small red wire from the MSD
to these 2 wires.
The green wire is the trigger, connect it to the White wire on the MSD box or
the negative side of the coil if you are only adding a coil
For Internal Coil cars
You will need the MSD conversion distributor cap.
Take the coil out of the distributor. Run the 2 wires that orignally connected
to the coil out through the hole in the cap, rember which one is negitive and positive.
Connect the positive to the small red wire and the negitive to the white wire.
ApexI VAFC Settings
These settings are different for each car, use these as a baseline and get your car on a dyno
-2 from 0-4800 wide throttle
-5 from 4300-8000 wide throttle
vtec low<>high 4800
Vtec high<>low 4600
Throttle point low 10 high 50
1/4 Mile times for your Hybrid
It really depends on how well you can drive and the condition of your engine. We have seen
anywhere from mid-low 14's to 16's in accords with H22 swaps.
6TH GEN TECH
There isnt much info on 6TH gen swaps. Aperantly the timing belt side mount is an issue as
well as the immobilizer
Transmision Codes
thanks to V4lu3s
m2a4...jdm prelude tranny non-lsd
m2b4...jdm lsd h22a tranny
m2s4...usdm h23a1 tranny/possibly also JDM f22b tranny as well
m2f4...usdm h22a1 tranny
m2ya...usdm h22a4 tranny
m2u4...usdm type sh tranny
      Registered and logged-in users don't see this ad!
Register your free account today.
wadzii is offline   Reply With Quote
Sponsored Links
Registered users do not see this ad.
Click here to register for free!
Old 01-28-03, 10:26 AM   #2
AccordSleeper
Former H22 Accord Owner
AccordSleeper's Avatar
Just to add:
A 97+ lude p/s bracket with accord p/s pump and line is another option.
For cat just get universal, anything oem or made to fit will be $$$. I paid $87 shipped for my carsound cat and the install was covered in the swap price since you got to mess with the exhaust anyways welding.
Now Living the AWD & Turbo Life
AccordSleeper is offline   Reply With Quote
Old 01-28-03, 11:23 AM   #3
JWise1203
Send a message via AIM to JWise1203
Quote:
Originally posted by AccordSleeper
Just to add:
Anyone have a bracket?? I may be interested in buying it off ya if so.
1994 Accord LX Sedan
DIY Mods I've Completed:
| JDM H22A | CP 3 Inch CAI | Neuspeed Strut Tower Bar |
____________________________________________
****F22B for sale. Runs perfectly! Contact me if interested.****
JWise1203 is offline   Reply With Quote
Old 01-28-03, 03:28 PM   #4
AccordSleeper
Quote:
nope bought at the dealer, i think they cost around $85.
Old 01-28-03, 06:42 PM   #5
SoCalAccord
Send a message via AIM to SoCalAccord
Thanks for the info I hope to do this swap in the summer
SoCalAccord is offline   Reply With Quote
Old 01-28-03, 09:08 PM   #6
XxRONNxX
MUGEN Whore!!
XxRONNxX's Avatar
Send a message via AIM to XxRONNxX
for OBD2 96-97 Accords.....
If you use an OBD2 engine on your OBD2 Accord, you can keep it OBD2 for smog legal purposes....no need to convert to OBD1. You can't use a 97+ Prelude ecu because of the immobilizer. However, if you can find a 96 USDM P13 or a JDM P5M ecu, you'll be fine. JDM ecu's do not have the immobilizer. I was able to pass smog and the state ref here in California. 100% Smog Legal Swap!
XxRONNxX is offline   Reply With Quote
Old 01-29-03, 02:27 AM   #7
AccordManiac
Korean Member
Send a message via ICQ to AccordManiac Send a message via AIM to AccordManiac
I have two PDF files about 4th and very detailed 5th generation Accord H22A swap.. If anyone one it.. E-mail me or find me on AOL.. I collected this swap faq from Honda message board I have no idea which one...and made into PDF files. Thanks to who ever wrote this H22A swap faq..
1st car: Frost White 1991 Honda Accord EX sedan.. (Dec. 1999 ~ Jan. 2001) *Sold*
2nd car: Black 1993 Accord 10th Anniversary Sedan (Feb. 10, 2003~Forever?)
AccordManiac is offline   Reply With Quote
Old 01-29-03, 02:35 AM   #8
aux
More Black on Black Crime
aux's Avatar
Send a message via AIM to aux
Thanks for the write up wadzii.
aux is offline   Reply With Quote
Old 02-28-03, 11:23 PM   #9
pinoy830
you can find the ps bracket at junkyards for like $20. i bought one to fit my my '94 swap for $20 at a local junkyard.
pinoy830 is offline   Reply With Quote
Old 03-14-03, 04:16 PM   #10
TaylorC01
TaylorC01's Avatar
Send a message via AIM to TaylorC01 Send a message via MSN to TaylorC01 Send a message via Yahoo to TaylorC01 Send a message via Skype™ to TaylorC01
you said use accord axels... use your factory ones?
taylor
TRBOTAY
http://picasaweb.google.com/civicdriver.tlc
TaylorC01 is offline   Reply With Quote
Old 03-14-03, 04:20 PM   #11
wadzii
fear the dark side
yep, and the factory accord 1/2 shaft
Old 03-28-03, 10:07 PM   #12
yun cheezie
does anyone know where i can find detailed info on the 6th gen accord h22a swap? i have a coupe of questions reguarding the injectors, map sensor, and distributor wiring. as well as the perfect ecu to run with my '93 obd1 jdm h22a motor. i have a 00 accord coupe lx 4cyl 5spd 2.3l vtec. any and all help is greatly appreciated!
yun cheezie is offline   Reply With Quote
Old 03-31-03, 12:08 AM   #13
wadzii
fear the dark side
try h22a.org dont know if that site is still up or not, havent been there in a while. i dont know much about the 6th gen swap. never done/seen one
Old 05-04-03, 01:51 PM   #14
93CivicH22aVtec
Got a question, I dont have an Accord but do have the 95 H22a. My power steering is not hooked up. I'm not sure of all the components that I'll need but do i use all the prelude components or do i have to mix and match with civic components? TIA!!
93CivicH22aVtec is offline   Reply With Quote
Old 06-01-04, 10:55 PM   #15
atlfalconz112
Send a message via AIM to atlfalconz112
so i can use my stock axles and stock motor mounts?
slammed '92 accord ex sedan
17" rss daiwa's wrapped in 205/40/17 kumho ecsta tires
lowered 3.5 inches on spw coilovers
si style tail lights
intake, exhaust
future mods: my next goal is to paint my trim out then drop an h22 into it......if anybody has one for sale let me know
atlfalconz112 is offline   Reply With Quote
Old 06-02-04, 12:13 AM   #16
wadzii
fear the dark side
Quote:
its a civic, you dont need ps... but if you must, then you have to use a prelude pump and im not sure of the line you need. we usually throw ps out.
Old 06-02-04, 12:13 AM   #17
wadzii
fear the dark side
Quote:
yep, sure can
Old 06-15-04, 10:08 PM   #18
99Accolude
heavy cars Rule!
Send a message via AIM to 99Accolude
for the motor mount placer racer makes it. call emm. they have the mount for like 162 plus shipping.
h22a 99 accord(REST IN PIECES) Totalled April 12 2005
97 ITR
sleeved b20z, je 10:5 pistons arias rods. jdm b16 gen2 head, skunk 2 double valve springs, valves, retainers. skunk 2 cams, aem cam gears, aem fuel rail fpr, walbro 255 fuel pump venom 450 cc injectors. mild port and polish 3 and 5 angle jobs. ctr crank pulley unorthodox true time pulleys, jackson racing supercharger @13lb. turbo upgrade in the mail!
99Accolude is offline   Reply With Quote
Old 06-30-04, 12:10 AM   #19
92hb
anyone know how to wire a accord obdII dizzy wire connecter to a obdI prelude connecter. I've brought the CPS up to the dizzy and have a few diagrams but anyone have an idea which wires go were??
if you can email me at nsxyello@yahoo.com with the info. Its the last thing I have to do to get my buddys shit up and going
92hb is offline   Reply With Quote
Old 02-22-05, 12:15 AM   #20
jdmh22agsr
i have a 93-96 jdm prelude p/s bracket for sale its on ebay
look in ebay i have one there
jdmh22agsr is offline   Reply With Quote
Old 02-22-05, 12:16 AM   #21
jdmh22agsr
i have an h22 p/s bracket
my email addy is jdmh22agsr@aol.com
Old 03-16-06, 08:49 PM   #22
kjd983
Send a message via AIM to kjd983
I am swapping a 96 h22, to a 93 LX accord the motor is wired with a EX accord motor harnnes on it already can i plug it into the lx main harness in the car. Then wire the v tec seperate. Or is there a difference between the LX and EX harness thank you keith KJD983@hotmail.com
kjd983 is offline   Reply With Quote
Old 03-29-06, 10:14 PM   #23
Trusi15
got a h22 on 2000 accord. speed sensor and temp. gauges aint workin???? any help???
Trusi15 is offline   Reply With Quote
Old 04-27-07, 12:30 PM   #24
Beast71
I am putting a 97 H22 into a 95 Accord EX. I have both the Accord EX obd1 ecu and the 97 Prelude obd2 ecu. Will either of these work, or do I need to get an obd1 from a prelude?
Beast71 is offline   Reply With Quote
Bookmarks
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Advertising - Privacy Policy - Terms of Use - Jobs
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.2.0
