Honda Accord 98-02: Brake Pad Replacement
Originally posted by lubs
jschmid - Thanks. Mind posting step 9, I don't think it came through.
01ACCORD:
Sorry, I don't have the larger pics on the internet, and to email them would max out my email attachment.
About the centercaps, just go to you local Honda Parts dept and see what they have. They guy I deal with there took about three different ones out to my car, and we picked the one that looked like it would fit, then when it did, I bought the other three.
You wouldn't have a scan of the section on how to replace the Pollen filters would you? Anyone have any directions? Like where it's at? Anyone...Bueller? :-)
I picked them up today, but haven't got a clue where they go. I'm thinking it's behind the glovebox somewhere.
Here's my write-up:
https://www.honda-acura.net/forums/s...&highlight=DIY
More Black on Black Crime
I replaced the front brake pads on my 2000 Accord with no problem. Now I took a look at the rear pads and I don't know which of the bolts to undo to remove the caliper to replace the pads. Does anyone have pics of this procedure like the ones above which showed the front pad replacement?
Okay, here you go. Now, when you remove the two bolts (C) the place they thread into can be held with an open end wrench if it spins. Remember, you don't push the piston back in on these, you take a big screwdriver and screw it in, and one more caution. Wrap the brake fluid resevoir under the hood with a rag. Mine overflowed when I screwed the pistons in.
Good luck!
Good luck!
Location: Uturoa, Raiatea French Polynesia/Hubbard Oregon
01Accord, Do you perchance have the instructions for a 2002 Acura RL 4 Door Rear Disk Change and adjustment or will the post you made above work... Looking for which bolts etc I have to remove and the proceedures.....
Thank you in advance, BTW the post you made is awesome!
