Go Back   Honda-Acura.net > Tech Forums > Do It Yourself
Thread Tools Display Modes
Old 08-22-08, 12:44 AM   #1
chocolate_bear
Black magic
chocolate_bear's Avatar
DIY: HID Retrofit in an EK
Hello all,
I decided to do a HID retrofit because besides the cool look I also do a lot of backroad driving and I hate my shitty aftermarket headlights. I had bought them because I wanted projectors (stock output blows). The output on those headlights were OK, but the housing was way too flashy. Anyways, hope you guys find this helpful.
What you'll need:
- D2S bulbs
- D2S projectors (I used a pair from a TL)
- Wiring harness
- ZKW lens or replica clear lens (optional)
- Shrouds (or you can make your own)
- Ballasts (I used a pair from a TL)
- LED rings (optional)
- Flat head and philips screwdrivers and 10mm socket wrench
- Primer and paint (optional)
- Adhesive/glue
- About 7 hours
1) I had to start off with some splicing so my TL projectors can plug into the ballasts without any trouble.
2) I took my stock headlights apart (by putting them in the oven at 375 degrees for 4min each). I had to cut the stock housing to fit the projectors. I used a jigsaw to cut the housing and a drill press to drill a 3.25" hold in the reflector.
3) Then I tested the projectors in my basement
4) As you can see in this pic, the projectors stuck out too much and wouldn't fit into the car.
5) To fix this, I had to cut into the reflector more which kinda sucked because I didn't want to make a shroud. No, biggie though. Eventually I got it to fit, then I mounted the reflector back to the headlight housing.
6) Now to cover the projector, I had to make a shroud. I used a top piece from those lawn lamps that you can put infront of your house.
7) I used a drill press to drill a hole into it
8) After some more cutting, it fit nicely into the reflector
9) Here's what it'll look like with the LED ring around it
10) I primed the shroud and painted it with chrome spray paint to match with the reflector
      Registered and logged-in users don't see this ad!
Register your free account today.
» Λнмєd «
DIY's without pics suck. View mine here:
www.ahmedrizk.com/civic
chocolate_bear is offline   Reply With Quote
Sponsored Links
Registered users do not see this ad.
Click here to register for free!
Old 11-05-09, 09:09 AM   #2
ef9racer
do you have any pics of it fitted on the car
ef9racer is offline   Reply With Quote
Old 11-05-09, 09:20 AM   #3
chocolate_bear
Black magic
yep...
full writeup can be found here:
http://www.clubcivic.com/board/showthread.php?p=2638047
» Λнмєd «
Bookmarks
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Advertising - Privacy Policy - Terms of Use - Jobs
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.2.0
