Go Back   Honda-Acura.net > Tech Forums > Do It Yourself
Thread Tools Display Modes
Old 05-15-08, 01:02 AM   #1
compwest
Altenator removal for 90 Integra
I just took out and put in new altenator in my integra after reading horror stories about the procedure. Did not remove wheel/drive axles nor the master brake cylinder. This is just the basics...
Jack up front of vehicle, support securly with jack stands. removed the drivers side tie for my access benefit, cleared some of the wiring and p/steering hose obstructions from the top...just moved them out of the way. I didn't have to completely remove the p/s hoses.
Unbolt the old altenator(2 bolts, adjustment and support bolts) Remove belt. Remove the upper altenator mount from the block(3 bolts) Remove the p clip wiring and main cable from old altenator.
remove oil filter(access from underneath)buys you a little more swinging room.
I had to unbolt the half shaft support plate from underneath. After spinning it out of the way gave me the final room to bring the old altenator out. It took a bit of trial and error, gentle prybar and jiggling it around with no room to spare but it came out.
Installation was the reverse of above...you may or may not need to remove the altenator support mount but I did anyway as it was easy to do and needed all the room I could get.
it definately will not be removed from the top without taking apart the master brake cyl and lines...you do not want to do this!!!
No special tools needed, no taking apart the drive axle assembly, no taking apart of the brake system. 3 hours tops....I'm happy!!!!
      Registered and logged-in users don't see this ad!
Register your free account today.
compwest is offline   Reply With Quote
Sponsored Links
Registered users do not see this ad.
Click here to register for free!
Bookmarks
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Advertising - Privacy Policy - Terms of Use - Jobs
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.2.0
