Go Back   Honda-Acura.net > Tech Forums > Do It Yourself
Thread Tools Display Modes
Prev Previous Post   Next Post Next
Old 12-01-07, 12:28 AM   #1
stanchua
DIY: Radiator Replacement
I didn't see a complete radiator replacement diy here (with step-by-step pics), so i thought posting 1 could be helpful...
***Always wait for the engine to cool down completely and unplug the battery!!!***
The radiator died on me a few days ago on my 4th gen accord, the bottom was leaking due to the rusty radiator base, hence it started to leak, and it leaks more when the engine is hot.
I ordered a brand new 1 @ Canadian Tire, $110+tax for a lifetime warranty radiator, for me it is quite a good deal so i took it
It is always better to get someone to give you a hand, for me I did it with my buddy but I put everything back by myself, and it took quite a while.
So we got a new radiator @ CanadianTire, with my buddy's s14 LOL
First thing I did is to unscrew these radiator holders. Drain the radiator until its all dry, by loosing the plastic nut underneath the car, right in the middle, its pretty easy to reach.
Unplug the hoses, there are 2 main hoses, the 1 on the top flows high temp water from the engine to the radiator, the 1 underneath flows low temp water into the engine. In my case, the hose underneath is hard to reach, so i just unplug the hose where connects to the engine. Remove the little hose that goes to the reservoir too.
Slowly lift the radiator up, watch for the fan connectors, there should be 2-3, just unplug them all, do not fully remove the radiator to avoid ripping the wires off.
You will be able to see half of the radiator, as the air condition pipe is in the way and its blocking the black hose underneath, just get the hose around it but try not to bend the hose too much. After that you will be able to lift the whole thing up but not completely off, and u can get access to all the nuts that lock both cooling fans, remove them.
Now here's the hard part, for my auto tranny accord, it runs the transmission oil thru the radiator as well, so there will be 2 little pipes that run transmission oil to the radiator and back, which are shown in the pictures. They are at the very bottom and it's not easy to reach and loose them. You need someone to hold the radiator for you in order to unscrew the nuts. Watch for the dripping oil, that's the transmission oil, hold them up so they wont drain, or you can choose to top it up later too.
The empty slot, the new and used radiator.
Put in the new radiator and reverse the steps, make sure all hoses and pipes are been tightened, especially the transmission oil pipes, i didn't really tighten it and i have to remove everything again.
Before starting the engine, fill the radiator first and the transmission fluid (if necessary). Start the car, accelerate for a bit and warm it up, add more coolant until it is full. Make sure there's no leaking from the underneath, as well as the hoses & transmission oil pipes.
Go for a drive, make sure there's no leaking and the car is not overheating, you are done.
      Registered and logged-in users don't see this ad!
Register your free account today.
stanchua is offline   Reply With Quote
Sponsored Links
Registered users do not see this ad.
Click here to register for free!
Bookmarks
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Advertising - Privacy Policy - Terms of Use - Jobs
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.2.0
