Go Back   Honda-Acura.net > Tech Forums > Do It Yourself
Thread Tools Display Modes
Old 05-08-07, 10:32 AM   #1
lkailburn
college kid
lkailburn's Avatar
Send a message via AIM to lkailburn
How to install filter mounted fuel pressure gauge
This is permanantly hosted on my site at:
www.lukekailburn.com
How to install a fuel filter mounted Fuel pressure Gauge
The parts
-Teflon wrap the guage threads, and the male threads on the 90* fitting. thats it!
Unscrew your gas cap to relieve some of the fuel pressure
Wrap the banjo bolt with some shop rags and remove the 12mm bango bolt.
Stock bango bolt removed. Clean the surfaces of any debris.
Install the new banjo bolt with new crush washers
Install the 1/8" 90 fitting. Then install the fuel pressure gauge
An overall shot of the setup
Check your fuel pressure at idle with the fpr vacuum hose connected, then check it with the fpr vacuum hose disconnected.
congrats you have successfully installed a fuel filter mounted fuel pressure regulator.
enjoy,
-Luke
      Registered and logged-in users don't see this ad!
Register your free account today.
lkailburn is offline   Reply With Quote
Sponsored Links
Registered users do not see this ad.
Click here to register for free!
Bookmarks
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Advertising - Privacy Policy - Terms of Use - Jobs
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.2.0
