Go Back   Honda-Acura.net > Tech Forums > Do It Yourself
Thread Tools Display Modes
Old 07-16-07, 10:39 PM   #31
nonbox
Here's a youtube video demonstrating what a bad cv joint is:
http://www.youtube.com/watch?v=T4i3Oe9ehPY
      Registered and logged-in users don't see this ad!
Register your free account today.
nonbox is offline   Reply With Quote
Sponsored Links
Registered users do not see this ad.
Click here to register for free!
Old 08-04-07, 06:42 PM   #32
ducati999
Great DIY - made the whole job a piece of cake. Thanks for the ball joint trick too. Big help.
ducati999 is offline   Reply With Quote
Old 08-04-07, 07:12 PM   #33
Provocateur
On permanent hiatus
Quote:
Thanks and you're welcome. Glad I could help!
Provocateur is offline   Reply With Quote
Old 09-22-07, 01:27 AM   #34
nyioo7
nyioo7's Avatar
omg! u live in really nice place. lol. great diy. saved me 50 bucks. hehe thnx
OH MY GOD! THEY KILLED KENNY!
YOU BASTARD!
nyioo7 is offline   Reply With Quote
Old 09-22-07, 11:29 AM   #35
Provocateur
On permanent hiatus
Quote:
Thanks. Glad I could help.
Old 09-25-07, 05:26 PM   #36
hatchy_roku
Damn!!! I think I learned more here than I did in high school! Great post....I'm in the process of changing mine out too.....thank god I've found your thread!!! Thanks and keep us posted of any future DIY's!!!
hatchy_roku is offline   Reply With Quote
Old 10-09-07, 05:32 PM   #37
polything
you are the man, i didnt read through this b4 doing my axles. spent 5 hrs fucking with ball joint, i have to remove H-brace bolts ....
pain in the ass...
nice diy though!!!!
polything is offline   Reply With Quote
Old 10-09-07, 07:15 PM   #38
Provocateur
On permanent hiatus
Quote:
Quote:
pain in the ass...
nice diy though!!!!
Thanks for the compliments guys. I am glad I could help everyone out.
polything, I know how stubborn those joints can be but hopefully, this will remove all hassle from getting them dislodged.
Also, if anyone has any recommendations for a future DIY, let me know and I will look into it. It has to be something doable on my existing setup...I am not going to buy anything just to make a DIY.
Old 10-09-07, 11:00 PM   #39
polything
uhm...
im trying to swap outer cv joint from CR-V (36mm) to civic axle. hopefully i will do a DIY on that and 5 lugs swap DIY...
Just curious, why dont you 5 lugs your teggy?
Old 10-09-07, 11:24 PM   #40
nonbox
Any one use an OTC slide hammer with CV joint puller attachment to pull the axle from the transmission? Plying it out with a pry bar can gouge or put dents on the transmission case?
http://www.thepartsbin.com/cartools/..._puller-d.html
Pry bars can damage expensive aluminum transmission cases, and attempting to do the job by pulling on the axis can damage the roller bearing inside the C.V. joint. With this puller, the axle assembly is popped out of the transaxle without damage, thanks to the straight, even pull provided by the slide hammer. Tool is available with fork only, C.V. joint slide hammer assembly, or just the slide hammer extension.
Old 10-10-07, 12:37 AM   #41
Provocateur
On permanent hiatus
uhm...
Eh, it is a lot of money for one extra lug. I don't want to run ITR wheels and there isn't any 5 lug wheel I want, so I don't see a point. It is money I could spent towards the motor.
That is a good point and is a good alternative if you are paranoid about damaging something. However, I have never heard of anyone distroying their case by prying on it, so I will continue to do how I have always done.
Old 11-16-07, 12:55 AM   #42
jmarty
Question: would it be possible to replace the exterior boot (i'm hoping to God the interior isn't bad too) w/o removing the whole axle? Would i be able to change it right after i took got the axle out of the hub? Thanks .
jmarty is offline   Reply With Quote
Old 11-16-07, 12:59 AM   #43
Provocateur
On permanent hiatus
Quote:
Once the outer joint is out of the hub, it only makes sense to take the next step and pop the inner joint out of the tranny or intermediate shaft. You have completed 95% of the axle removal, so why not finish the job and allow yourself more room to make sure the job is done correctly?
Old 03-15-08, 01:31 AM   #44
suprra_girl
thread bump!
I noticed it wasn't mentioned in the writeup about the bearings that go on the spider, do they have a particular way to go on or just any side will do?
Thanks
suprra_girl is offline   Reply With Quote
Old 03-15-08, 01:47 AM   #45
Provocateur
On permanent hiatus
Any side works but on the left driveshaft one of the rollers is different from the rest, so it needs to be installed back on that side. It will all make sense when everything is apart.
Old 03-15-08, 01:55 AM   #46
suprra_girl
Thanks alot for the quick reply, i appreciate it muchly
We've just gone and analysed all the bearings, we noticed that 3 are different than the other 3 but only due to slightly sharper bevelling on the top edging (high side not flat side)
Other than that, we cannot see any other differences, what are we looking for?
Thanks
Old 03-15-08, 12:11 PM   #47
Provocateur
On permanent hiatus
Sorry, I meant to say that all the rollers on the left driveshaft were different. It is hard to explain the difference but here is a picture out of the factory service manual if that helps.
Old 03-18-08, 02:21 AM   #48
nonbox
What's the best tool to use to remove the circlip and stopper ring? I have used snap ring pliers but it too a very long time. Is there a better way?
Old 03-18-08, 07:17 PM   #49
Provocateur
On permanent hiatus
Snap ring pliers are the only thing I can think of. I think it is just going to be tedious regardless of what tool you use.
Old 03-29-08, 06:15 PM   #50
thoughtfulbeave
Better than Haynes manual
Great step by step instructions. The Haynes manual has you jumping from chapter to chapter. It tells you to drain the transaxle, remove the stabilizer, remove the brake caliper, tie-rod, what a kluge!
Your instructions made this dreaded task about as hard as a 4 wheel brake job.
Thanks again!
thoughtfulbeave is offline   Reply With Quote
Old 06-06-08, 05:09 PM   #51
mohater
Can you fix the pictures? Links are all broken. I can host if you need someone to.
mohater is offline   Reply With Quote
Old 06-18-08, 03:15 PM   #52
FL_Civic_Rider
Drive it like it's a Taco
Send a message via AIM to FL_Civic_Rider Send a message via Yahoo to FL_Civic_Rider
I'm getting ready to do this task as well and would love the pics
FL_Civic_Rider is offline   Reply With Quote
Old 06-19-08, 09:31 PM   #53
millibug23
I've changed tires, belts, and hoses before but i'm really excited about trying out the axle boot. read your dirrections but could not upload your pic's for some reason. my e-mail is millibug23@yahoo.com would you mind; if it's not too much work for you; sending those pic's via email so I'll have that extra little help? thank you so much for posting this, the company I went to quoted me $750 to replace the axle boot and two upper ball joints, probably cuz I'm female but I noticed labor was cheap and the more i looked into it I realized that with a little help from good people like you I could save myself hundreds of dollars and learn something I can use over and over again. Thank you for all your help. Amelia
millibug23 is offline   Reply With Quote
Old 06-26-08, 10:26 PM   #54
yagotrice
Quote:
2nd that, want to look at pics before attempting......
yagotrice is offline   Reply With Quote
Old 07-01-08, 03:17 PM   #55
complexdreams
Could someone please upload new pictures?
complexdreams is offline   Reply With Quote
Old 07-13-08, 08:03 PM   #56
CDelgado220
Send me the pics & I'll repost them please
costadragon220@hotmail.com
CDelgado220 is offline   Reply With Quote
Old 07-17-08, 12:35 AM   #57
dookieface
new pics would be nice
dookieface is offline   Reply With Quote
Bookmarks
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Advertising - Privacy Policy - Terms of Use - Jobs
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.2.0
