Go Back   Honda-Acura.net > Tech Forums > Do It Yourself
Thread Tools Display Modes
Old 03-29-08, 12:18 PM   #31
dlubben
Fantastic! You saved me a bundle. I wish I would have known that when my wifes 95 Odyssey did the same thing. It cost $800.
      Registered and logged-in users don't see this ad!
Register your free account today.
dlubben is offline   Reply With Quote
Sponsored Links
Registered users do not see this ad.
Click here to register for free!
Old 06-13-08, 08:11 PM   #32
randomtask77
Wanderer
randomtask77's Avatar
Anybody know where the MES connector is on a 93 civic? It doesn't seem to be by the driver side fuse box. There are a couple of yellow connectors (one actually hooked up to the fuse box and another random yellow one near it) but they do not look like the one pictured (it's not a 2 wire connector). I've checked google and other sources claim that the 92-93 civics has the MES at the far right edge of the dash (the passenger side). I did see a few connections, but the 2 wire connection is brown.
Any help is greatly appreciated.
randomtask77 is offline   Reply With Quote
Old 06-14-08, 08:36 AM   #33
A-series
v-card member alpha
A-series's Avatar
According to the service manual, it should be visible once you remove the kick panel to expose the ECU. edit: which is below the glove box, at on the outer side.
This is JoshersHe dances b/c he sat on a wet public toilet seat, got the herp.
Today's inspirational quote: "Mah fofo make sho all yo kids don't grow."
A-series is offline   Reply With Quote
Old 06-14-08, 10:07 AM   #34
randomtask77
Wanderer
Quote:
I saw that. At the very far right corner below the glove box, there is a grey connector along with a brown (that are clicked together). The brown is a two-wire connector, but I'm not sure if that would be the MES connection (I can't seem to disconnect it).
I just hope that the homemade SCS connector that was shown here is the same one used as I had a pretty difficult time tracking one down.
Old 06-26-08, 12:38 AM   #35
randomtask77
Wanderer
Bump.
I just tried the little connector that was on the far right side of the dash (below the glovebox) and it didn't work.
The home made SCS connector didn't work and when I did try something else, it didn't work as well, so the brown connector didn't work.
Does anybody else have any input or know where the MES connector is on a 92-93 civic (google results only show 94 on up model civics).
Old 11-19-08, 11:54 PM   #36
apocalypsefam
cool man
this is a really good post. may i also suggest that an even cheaper way for anyone that reads this post to use a paper clip it does the same exact thing. all your doing is give bridging the two pin connector by shorting it to ground.
apocalypsefam is offline   Reply With Quote
Old 11-27-08, 04:20 AM   #37
A-series
v-card member alpha
A-series's Avatar
Quote:
All I've ever had to do is jumper one of the two connectors (one w/ brown wire I believe) on my '92 civic, for when you set the ignition timing.
I use one of those cheap little electrical connectors that come in a set, usually a variety of diff. types in the box. Looks like a steak fork or whatever w/ two prongs, you just twist the prongs w/ needle-nose pliers so it fits, and it works perfectly.
Bookmarks
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Advertising - Privacy Policy - Terms of Use - Jobs
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.2.0
