Go Back   Honda-Acura.net > Tech Forums > Do It Yourself
Thread Tools Display Modes
Old 04-25-06, 01:55 PM   #1
totalimmortal
MalleusMaleficarum
totalimmortal's Avatar
Send a message via AIM to totalimmortal
DIY: Motion sensor install on Viper791xv
Now, this will most likely work with the rest of the viper line so long as they have shock sensor outputs. As with the rest of the DIY's posted here, I take no responsibilty for your mistakes. If you don't feel up to the task, don't do it!!.
First off, Locate your shock sensor. This step shouldn't be hard, if you start tapping around you'll see it light up. Trace that back to the brain and unplug and completely remove it. This is where the cutting and splicing begins. I've made a diagram, I couldn't take pictures while I was doing it.
I can't stress enough to make sure you leave enough wire for yourself to run everything. It's OK to have extra wire, but you don't want to be stuck with too little. I think I only cut maybe three inches from my motion sensor harness. And also take note that the plugs are different on the motion sensor harness, so double check before you start cutting.The best place for your motion sensor will be under your center console/armrest. I'm not going to go into the callibration on the motion sensor, the provided instructions are plenty detailed.
Now to remount the shock sensor, there are two ways to do it. The first is to mount to a flat metal surface, by dong this you will be losing some sensitivity. The second is to a loom of factory wire hanress, and believe me it will be sensitive. I did mine the first way, I don't want a ton of false alarms. And again, the motion sensor goes under your center console/armrest and then adjust as necessary. Thats pretty much it, this took me all of 30-40 minutes to accomplish and callibrate to my liking. Enjoy.
      Registered and logged-in users don't see this ad!
Register your free account today.
Stock Civic Vs. 250hp Wet Shot
"i lowered my engage point to 500rpm. I'm so hardhore, I idle in tEh tak" -e3NiNe
totalimmortal is offline   Reply With Quote
Sponsored Links
Registered users do not see this ad.
Click here to register for free!
Bookmarks
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Advertising - Privacy Policy - Terms of Use - Jobs
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.2.0
