Go Back   Honda-Acura.net > Tech Forums > Do It Yourself
Thread Tools Display Modes
Old 03-30-06, 04:01 PM   #1
Chefboiali
Chefboiali's Avatar
Send a message via Yahoo to Chefboiali
Help with Polishing engine parts
So... after doing a search on engine bay polishing, I just had to give it a shot.
http://www.honda-acura.net/forums/sh...ghlight=polish
Starting with my alternator bracket, I used my Craftsman rotary tool with the supplied Medium grit paper on it. Cleaned the sucker REALLY good. Got the feel of how much pressure to use and how long to let the paper stay in one spot. I then used some 600 grit and sanded it under running water for about 10 min. I had some steel wool, but I think it wasn't fine enough, so I go scratches. Do I really need to go to finner paper and continue to wetsand?
How do I get rid of the small pits? Keep sanding with 600 on those spots then work my way down? Any help would be cool. I can't find a video on the best ways to do it on the internet. I would love to SEE someone use a dremel tool to polish. A hands on would be cool. The pad gets so black, I'm not sure exactly how to do it. Anyone down to do a step-by-step for us all?
      Registered and logged-in users don't see this ad!
Register your free account today.
Chefboiali is offline   Reply With Quote
Sponsored Links
Registered users do not see this ad.
Click here to register for free!
Old 07-24-07, 10:28 PM   #2
88_rex_si
88_rex_si's Avatar
that looks really good, you should be able to keep sanding around the pits to blend everything in a bit .when you are all done with the sanding and blending the pits , get the cloth wheel and polishing compound for the dremel tool and that bracket will be reeaallyy shiny , good luck
88_rex_si is offline   Reply With Quote
Old 07-25-07, 12:49 AM   #3
totalimmortal
MalleusMaleficarum
totalimmortal's Avatar
Send a message via AIM to totalimmortal
I've never been much good at polishing things, god knows I've tried. But, I'd image a bench grinder with the appropriate attachments would make short work of things like that. I'd save the dremel for detail work.
Stock Civic Vs. 250hp Wet Shot
"i lowered my engage point to 500rpm. I'm so hardhore, I idle in tEh tak" -e3NiNe
totalimmortal is offline   Reply With Quote
Old 07-25-07, 06:57 PM   #4
Chefboiali
Chefboiali's Avatar
Holy thread revival
Funny thing is that I DID in-fact buy a bench grinder/buffer. I live in an apt. and there's no real way to run one without making a mess. Since then I've polished a valve cover, but to tell you the truth, unless you're gonna show the car, polishing shit isn't worth the upkeep.
As for using the dremel, I was doing this to pass the time. My gf and I were going through some rough times back then, and I needed something positive to do. Thought I'd make some dull things shinny
Old 07-25-07, 08:53 PM   #5
totalimmortal
MalleusMaleficarum
I didn't even read the date
Old 08-02-07, 10:40 PM   #6
k_elliot
thanks
hey cool, i'll have something to do over the weekend.
what doesn't kill you only makes you stronger
acura legend parts
k_elliot is offline   Reply With Quote
Bookmarks
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Advertising - Privacy Policy - Terms of Use - Jobs
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.2.0
