| Do It Yourself This is where you will find step by step instructions so you can Do it Yourself! |
Thread Tools | Display Modes |
#1 | |||||||
Pic Whore
DIY: Mod STOCK Fogs to turn on w| Headlights off.
| Sponsored Links | ||
#2 |
another question
hello,
I have a piaa fog light kit, but I want the stock switch on the inside. I've already have the switch alone. I need to know what each of these colored wires run if possible. ![]() I'm assuming the: black = ground... red = 12v power orange = dimmer for the switch light black/red = 12v when lights are on blue = 12v from when highs beams are on from the posts this is what I've composed. Not so sure on the orange though (assuming because of stereo installs) also I'll need to know from harness A in the stallation PDF what are the two colored wires connected to the 14 pin harness that is connected behind the headlight switch on page 8 sequence #36. it says red/black and yellow. are these the colors of the wires aready there or are these the colors of the wire from harnes A? this would realy help me in incorperating an aftermarket fog light with the stock fog light switch. thnx
Road rage only makes you a better driver. Last edited by 4cylinder4ever; 04-08-06 at 04:11 AM. |
#3 |
4cylinder4ever
how much did the stock switch cost you, last i saw they werent cheap? i setup a led and toggle switch for my fogs but a stock switch would be cleaner and not as bright on the eyes. if you get it installed i think some of us would like to know the wiring as well, so good luck and what you posted looks right. not sure about orange though, does the fog switch dim with the cluster? i know my cc switch doesnt ever dim, but my wiring is hacked to shit from a previous owners alarm install. if it is supposed to dim then yes i think that would be orange, an orange wire also comes off of the dimming adjustment switch as well as the stereo. good luck and let us know the outcome |
#4 |
Aw, I was to do this but I found out that my oem civic fogs only have 3 wires.
#5 |
Pic Whore
red/black is the switch illumination (hot when headlights or parkinglights are on)
red is the "ground" for the illumination (runs to illumination control dimmer) the switch closes the connection between Blue (in) and Green (out) black is the ground for the indicatior when the switch in on. |
#6 |
hey,
thnx for the input jani. It has realy helped me depict the wiring diagram. You guys probably know I'm new to this forum. So, I'm going to do a DIY for this project. And I wont post unless everything goes well. I'll keep you guys posted. thnx
Road rage only makes you a better driver. |
#7 |
This is what I've compiled so far as for the wiring after deciphering the wiring diagrams with the info from jani. I'll attempt to do this and set up a DIY also.
![]() For now this is only a wild guess so I wont be held responsible for any damage caused during/after installation. (most DIY's have dislaimers, so this is mine) Again, I wont be help responsible if anything happens to your car using this information. for the time being please wait till I've attempted this on my own vehicle to see if there's any problems. thnx
#8 |
Pic Whore
the diagram looks pretty accurate.
Illumi+ is Hot (from parking lights) Illumi- is the lead that goes to the dimmer. I dont know how if the dimmer will affect the operation of the relay... if it does, - can be sent to ground. Last edited by Misa; 04-10-06 at 05:43 AM. |
#9 |
I just wanted to make sure that this diagram:
![]() is exactly what each prong on the switch is in the correct order if I was to stand the switch up right like so.
#10 | |
Pic Whore
Quote:
NO. i dont have oem fogs so i cant check. i'll post back if i do find out. |
#11 |
Pic Whore
With the switch facing up....
Black Orange Blue Red/Black Red edit: ive heard you can easily open the switch up and take a look inside Last edited by Misa; 05-16-06 at 05:05 AM. |
#12 |
Anybody have any ideas with my oem civic foglights that have 3 wires on the switch? Theres black, red/yellow, and red/white.
#13 | |
Pic Whore
Quote:
i assume black is ground, and the reds are for the switch and the illumination of the switch. |
#14 | |
Quote:
. I guess if I was to do this mod then it would be somewhere deeper on the wiring harness.
#15 |
ok so I attempted to wire in the switch using the power from the cruise switch. everything works just fine. But Now my problem is that I cant remember how to hook up the piaa x1100 wires. I know that the white/red wires are power and black/brown is ground, but I hooked that up to my switch, but wont work. I tried looking for the manual online with no luck either. so untill piaa gets back to me I'm not sure if I can go any further...
#16 | |
Pic Whore
Quote:
#17 |
yeah. The piaa guys emailed me the diagram. I'm going to have to wait until thursday to try it again. It looks like there's some tweaking to what is attached to the switch. I'll you guys posted.
oh and cpvdh, I got the switch for about 15.95 + shipping. I dont know if its too much or not.
#18 |
02 MDX Touring with Navi
I have a 02 MDX on which i want the foglights to be on as indicated in the diagram above. After accessing the back of my lights switch, i saw that there are a bunch of wires there and that there is no red/black wire. Please let me know where i can get a wiring diagram for that or help me get whatever info i need to make it work. Thanks
#19 |
K, i have this, but i dont consider it a mod. my fog lights WONT come on when my low beams are on. any way to fix this? do i bind the fog light wires with the head light wires?
#20 |
I did this to my '00 Accord that has OEM fogs and it worked perfectly. Did it back in May and have had no issues with it at all.
#21 |
Off Tha Line Yer Toast
1992 Acura Integra
N/m - I am a fool, I got confused,.. I got them workin
Actually, I own a 92 RS teggy. Alls I had to do was find the Red/Yllw wire behind the fog switch(closest to harness), clip it and run a new wire over the top of the steering collum behind the dash, to the Defrost switch's black/yllw wire - Both the loose wire, and the one closests to the harness. Got em right on
| Bookmarks |
| Thread Tools | |
| Display Modes | |
