Go Back   Honda-Acura.net > Tech Forums > Do It Yourself
Thread Tools Display Modes
Old 11-15-05, 11:13 AM   #1
PunkAssKidThe1s
Team Babu
Send a message via AIM to PunkAssKidThe1s Send a message via MSN to PunkAssKidThe1s
Installing an engine?
How hard is it to install your own engine (bolt-on and play such as H22 in an Accord)? I'm not exactly the best mechanic - hell, I went to a shop to have my header put on, but I want to learn, and one of my uncles had to fork out $1,000 for a new engine to be installed into his Subbie!
So, how hard it is and what tools outside of the standard nuts/bolts/screws/drivers/wrenches would I need for this??
Thanks!
      Registered and logged-in users don't see this ad!
Register your free account today.
My Ride R.I.P. PAK Accord, Friday 1/27/06
Tired of being harrassed/stereotyped? Go here!
Get sponsored!
Custom Lightz - Want some custom headlights, but don't wanna be riced out? Want HID, but don't want to pay $500 for junk? Let Custom Lightz solve your problem! Reference: Hiro.
PunkAssKidThe1s is offline   Reply With Quote
Sponsored Links
Registered users do not see this ad.
Click here to register for free!
Old 11-15-05, 11:13 AM   #2
PunkAssKidThe1s
Team Babu
Oh, yes, and same question for tranny... Afterall, I've got an AT matted to an F22 in my Accord SE (97)...
Get sponsored!
Old 11-15-05, 04:33 PM   #3
97civicEXVTEC
97civicEXVTEC's Avatar
Send a message via AIM to 97civicEXVTEC
air tools is a must..
if you cant install your own header, i would do a lot more research before you take on something like that..
D16Y8
Injen CAI-EVO2 Cat Back-B&M Short Shifter-NGK Platinum Plugs-Test Pipe-Megan Racing 4-2-1 Header and Downpipe-Exedy Stage 1 Clutch-Fidanza 7lb Flywheel
Quote:
Originally Posted by Hambone
u + me = us
Quote:
Originally Posted by AF
Yes, because I'm a gay pilot. Good call.
97civicEXVTEC is offline   Reply With Quote
Old 11-16-05, 07:57 AM   #4
Altern8r
Altern8r's Avatar
ye i agree with 97civic*** as it is a lot more complicated than a header. that is simple.
'90 Prelude, white,
2lt EX twin carb,
sony xplod mp3
4 6x9 & 2 10" subs
4 ch 200 w amp
self install
Altern8r is offline   Reply With Quote
Old 11-21-05, 11:51 PM   #5
96HawkCnvt
Thanks!
It's really not that difficult to do stuff like that and I'd encourage you to give it a try. But as others have pointed out, there is a lot more to it than just installing a header. My suggestion is to find some guys locally that you know you can trust and see if you can get some help with it. You'll learn a lot if you aren't afraid to give stuff a try. Just be smart about it so you don't cost yourself a lot or end up with a safety issue etc.
Good luck!
Todd
96HawkCnvt is offline   Reply With Quote
Old 03-30-08, 01:48 AM   #6
goldex420
goldex420's Avatar
installin a header takes 10 min a engine 4 hrs or so if u know what ur doing and ive done plenty its quite a job and i KNOW ur not ready
for sale96 ex seats and brackets 10096ex springsemail me adam100487@hotmail.comalso headers and AEM cold air intake
*Gold TURBO D now gold
goldex420 is offline   Reply With Quote
Old 12-27-08, 02:31 PM   #7
willpower101
Quote:
To swap an engine? I don't think so. Tons of people do this job with standard tools, and the saying that they are a "must" is simply misinformation.
Besides standard tools and a ball joint separator the only other thing that makes the job much easier is an electric impact wrench.
willpower101 is offline   Reply With Quote
Old 03-19-09, 01:43 PM   #8
donta
How hard is it to install a tranny in a 95 Accord. I need to get step by step instruction as to how it should be done.
donta is offline   Reply With Quote
Old 03-25-09, 04:27 PM   #9
marvinp8700
blast it with piss
marvinp8700's Avatar
Send a message via ICQ to marvinp8700 Send a message via MSN to marvinp8700
Quote:
Haynes manual
i'm a TROLL
marvinp8700 is offline   Reply With Quote
Old 04-25-09, 02:39 PM   #10
jrgoswick
Some old guy!
Quote:
I recently assisted Specialty Performance in Rogers Arkansas install a KillerB into a Civic. Took about 2 hours for the motor AND tranny! It is a lot of work. The ONLY thing I can't say enough-MAKE SURE YOU'VE GOT THE RIGHT TOOLS FOR THE JOB!
jrgoswick is offline   Reply With Quote
Old 08-15-09, 11:00 PM   #11
mattliston
Living and Learning FTW
mattliston's Avatar
air tools are for the weak of arm. and cost a LOT if you dont already own an aircompressor. much easier and cheaper to simply buy a few extension pieces , a breaker bar for added ease of turning, and maybe an iron pipe around 2 feet in length that fits somewhat snugly over the breaker bar
if you have a 92-00 civic, popping the lower ball joints, removing the axles (after draining the tranny) and pulling the engine completely is a 2-3 hour job. few plugs on each strut tower, VSS and reverse plug(if manual) and all the electricals are unplugged. unhook the shift linkage and remove the AC compressor and powersteering pump, and its time to jack teh car's front end way up, undo teh mount bolts and pull the engine out form underneath. if you have an engine hoist, its much easier, just hook that bad boy up to teh factory tranny hoist bracket and bolt the chain to the intake side of the block, say alternator bracket bolt, and jack it up jsut enough for tension, remove the mounts and brackets and jack it out
EDIT I would imagine an F series equipped accord to be similar, though I have ZERO experience with any accord. most of my experience with hodnas is honda civics/del sols and acura integras
mattliston is offline   Reply With Quote
Old 10-08-09, 03:37 PM   #12
Line7
Platinum Member
Line7's Avatar
Im about to do it this weekend, then I'll let you know.
For Sale: ITR/SiR rear LCA's JDM!!!
Line7 is offline   Reply With Quote
Bookmarks
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Advertising - Privacy Policy - Terms of Use - Jobs
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.2.0
