Installation of LED washers? (Wiring problem...)
Old 10-26-2005, 09:22 PM
PunkAssKidThe1s
Team Babu
PunkAssKidThe1s's Avatar
Default Installation of LED washers? (Wiring problem...)
Alright, well, I got LED washers from a neighbor who knew I was into cars for my bday last month... if it was a regular washer, I could do it, but I'm unsure with the wiring, as it did not come w/ how to install info... my question is, can anyone help me out, as I'm no electricion, and going to the shop for something so simply and paying them $50 or more to do that is a little stupid IMO...
Can anyone help me out w/ the wiring issue? Thanks!
Old 10-27-2005, 04:47 AM
goon54
goon54's Avatar
simple.. dont do it
Old 10-27-2005, 06:03 AM
westcoaststyle
Still here... sorta...
westcoaststyle's Avatar
Originally Posted by goon54
simple.. dont do it
Agreed. LED washers are a :nono:
Old 10-27-2005, 07:18 AM
JoshJ
bang bang.
JoshJ's Avatar
I will fly to Seattle, WA and slap you if you put those on your car.
Old 10-27-2005, 08:24 AM
PunkAssKidThe1s
Team Babu
heh, k, I see people around here aren't a fan of them, huh?
Old 10-27-2005, 09:41 AM
kidd_honda
kidd_honda's Avatar
i say you do it...its your car IMO its waste of time save your money on other useless mods.
combine the red wiring on the lights....when you get that done, get extra wiring and connect the extra wiring to the bundle of wires you combined....run that line to the inside of your car....run that line under your fuse box...attach a spade to that end and plug it in to the accessory. the black wires on the lights are ground so find any place under the hood with a screw..that would be the place to ground that wire...then you are done...it will turn on when you turn on your headlights.
