replace door speaker
Old 10-21-2005, 11:41 PM
mlseals
mlseals's Avatar
Default replace door speaker
I have a 91 Acura and the door speaker need replaceing, how do you take off door panel?
Old 11-09-2005, 09:11 PM
Phateless
S2K compatible
Phateless's Avatar
this is really vague, do a search and you'll probably find a better answer. also, try honda-tech.com if you can't find anything here. again, SEARCH FIRST.
take out all the little screws from
door handle
door arm-rest/handle area
anybody else chime in if i missed anything?
then basically grab the bottom part of the door panel and it will literally pop off. be gentle but firm, you'll get it. you may have to gently pry the plastic trim ring around the door handle off first, as well. be careful not to break anything. don't force anything. it's really amazingly easy once you get the hang of it.
Old 11-09-2005, 09:17 PM
Phateless
S2K compatible
Phateless's Avatar
this might be a little more help. different car, but same idea.
http://www.xanga.com/home.aspx?user=...%3a59%3a59.999
http://honda-tech.com/zerosearch
