Results 1 to 14 of 14
Thread: Speedometer needle sticks, Help!
  1. #1
    VX Hatch with 431,500! Highmile's Avatar
    Join Date
    Sep 2005
    Location
    Missouri
    Posts
    560
    My car, with all of it's 424,000 miles, has a sticky speedometer. It sticks on Zero and then sometimes it will flip over and stick at 100mph. I have to smack the dash with my fist and it will usually flip to the current speed. I have the most luck doing this with the fewest smacks of the dash when I'm going about 40mph. (sounds stupid but there you go). I know it just about can't be the speed sensor on the trans because of what I just described (so please don't tell me that I have a speedsensor problem).
    Question... Is there anyway to lube the needle shaft or anything like that, or what do I do?
  2. #2
    HEAT:Shift_TechkaV hoyoung02's Avatar
    Join Date
    Mar 2004
    Location
    Altus AFB, OK
    Posts
    442
    holy shit....424,000 miles? omfg...cot damn...wtf? that much milage? geesus fucing christ.
    ok, well, you gotta tell us what car you have..it'll be easier.
    take the gause cluster out, this is where we need to know wtf you have so we can tell you how to take that off unless you already know how, and clean the inside. and lub the little motor behind the needle. get this from your local hobby store for RC cars which runs on electric motor, buy that little lube and use it on the gauge cluster.
    good luck.
    LED DIY Crazy
    I don't have a car.
  3. #3
    Join Date
    Sep 2005
    Location
    Missouri
    Posts
    560
    My car is a 92 Civic VX. Have had it since it had 64k (10years now). I have taken the cluster off and know how to do that. I had a really hard time pulling the needle off the speedo and gave up 'cause I didn't want to break it. I assume it will come off becasue that is how people would change the gauge background to white or whatever. Do I just give it hell and pull harder, or is there a trick?
  4. #4
    Join Date
    Mar 2004
    Location
    Altus AFB, OK
    Posts
    442
    the needle on those don't come off. and are not suposed to.
    some models do, and some don't come off.
    no wonder why it's all fucked.
    LED DIY Crazy
    I don't have a car.
  5. #5
    Join Date
    Sep 2005
    Location
    Missouri
    Posts
    560
    Quote Originally Posted by hoyoung02
    Lets see... was I trying to fix it before it was broken or after?
  6. #6
    Join Date
    Mar 2004
    Location
    Altus AFB, OK
    Posts
    442
    wow, you sound like a fucking tool sack.
    i already gave you an answer to your problem.
    and no, no one takes their needles off to put on the indiglow faces you dumb fuck. you make me pissed from your low knoledge and not fucking reading things. so, do that i sugested, or go get a new fucking speedometer you fuck.
    yeah i am a fucking dick, and you deserved this one.
    any fucking ways,
    good luck.
    LED DIY Crazy
    I don't have a car.
  7. #7
    Join Date
    Sep 2005
    Location
    Missouri
    Posts
    560
    Thanks for the worthless advice and all of your invaluable "knoledge". Stay over in South Korea (or in the accord four door automatic forum). You guys can talk about your sluggish family wagons.
  8. #8
    hoyoung needs to calm down
  9. #9
    Join Date
    Mar 2004
    Location
    Altus AFB, OK
    Posts
    442
    will do
    LED DIY Crazy
    I don't have a car.
  10. #10
    Registered User szuberi's Avatar
    Join Date
    Feb 2005
    Location
    Toronto
    Posts
    41
    any fucking ways,
    good luck.
    So if you dont touch the needles, how do you take the existing gauge face out and how do you put the new one in????????? I dont know this so i am just asking.
  11. #11
    Join Date
    Mar 2004
    Location
    Altus AFB, OK
    Posts
    442
    ...you can touch the needles, just dont try to take them off from the gauge faces
    LED DIY Crazy
    I don't have a car.
  12. #12
    Join Date
    Oct 2005
    Posts
    4
    for the gauges, people bent the indiglo around the needles. if i were you i would try the lube advise if that doesnt work, i think its time for a new cluster. the gain of this is that u dont have to have it say 420000 miles. now it can say 120000 or so
  13. #13
    Join Date
    Apr 2005
    Posts
    Easiest way to fix the sticking needle is spray some WD40 on that and you dont need to take the needles off to replace gauge faces just have to manuvure the gauge face around the needle
  14. #14
    Join Date
    Mar 2004
    Location
    Altus AFB, OK
    Posts
    442
    Quote Originally Posted by Solid_turk
    don't do that.
    LED DIY Crazy
    I don't have a car.
  15. #14
    Honda-Acura
    Honda S2000
    Honda-Acura
Bookmarks
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
Search Engine Friendly URLs by vBSEO 3.5.2
