Heater Blower Fan not working on First 2 speeds
Old 08-26-2005, 06:30 PM
hsacura
hsacura's Avatar
Default Heater Blower Fan not working on First 2 speeds
I have an Acura 1.6 EL, 1998 and the Heater/AC Fan blower does not work on the first 2 speeds. Just before this happened there was a loud humm from the fan. Now no humm and no fan at first 2 speeds.
I opened up the glove compartment and I can hear the motor humming at the first 2 speeds, it is a quite humm (thus getting power, but may be not enough current).
Any ideas?
Old 08-26-2005, 10:05 PM
Tanker
Tanker's Avatar
Try checking the blower resistors. They're usually located on the blower itself.
Old 08-29-2005, 05:20 PM
hsacura
hsacura's Avatar
thanks I will check that out.
Old 09-12-2005, 02:59 PM
hsacura
hsacura's Avatar
Default Blower resistor was blown
Blower resistor located on top of the Heater Blower was blown. Part number 79330-SR3-A01 replacement part from Acura, cost $ 28 Canadian.
This is located right behind the Glove Compartment and has a Rectangular plug about an inch wide going into it. 2 screws to remove.
Thanks for your help.
