Go Back   Honda-Acura.net > Tech Forums > Do It Yourself
Thread Tools Display Modes
Old 08-30-05, 11:24 AM   #1
Arrogant_
How to put in GSR HEAD GASKET!!?
Can someone break down the details on how to put in GSR HEADGASKETS?
All inputs will be appreciated.
Thanks in advance
      Registered and logged-in users don't see this ad!
Register your free account today.
Arrogant_ is offline   Reply With Quote
Sponsored Links
Registered users do not see this ad.
Click here to register for free!
Old 08-30-05, 05:59 PM   #2
Provocateur
On permanent hiatus
What do you specifically need to know?
It is pretty straightforward; you just pull the head, put the new gasket on, and put the head back on.
Provocateur is offline   Reply With Quote
Old 08-31-05, 10:56 AM   #3
Arrogant_
hahah... it sounds easy! I know it does.
Do you use an engine jack or something else? And what's the easiest way?
How can you tell if a head gasket is BAD from the maker?
I've purchased two head gaskets from "Felpro", and they were both BAD. Although, they were put on before I found the problem.
Do you place the gasket on the block then lower the head, or cling the gasket onto the bottom of the head and then lower it?
Thanks for any advice or comments.
Old 08-31-05, 02:58 PM   #4
Provocateur
On permanent hiatus
I prefer to seat the gasket on the top of the block and put the dowels in before I seat the head.
Don't use Felpro shit. OEM is the best out there and isn't that expensive. With the labor involved in changing it, do it right and get the quality gasket.
The head isn't that heavy. Remove all the accesories and bolts and you can lift it off with your hands. It weighs maybe 40 lbs.
Old 08-31-05, 06:29 PM   #5
Arrogant_
Thanks, I appreciated the help and advice. I will try that this time around.
Bookmarks
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Advertising - Privacy Policy - Terms of Use - Jobs
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.2.0
