Go Back   Honda-Acura.net > Tech Forums > Do It Yourself
Thread Tools Display Modes
Old 08-11-05, 06:45 PM   #1
nuroaccord
Need help replacing a 99 Accord 4cly 5 speed radiator.
I just had something go through my radiator and I need to replace it. Before I go and rip out the old radiator, I just wanted to know if anyone had a "How to". It doesn't look to hard, but I didn't want to end up getting suprised after I start the job. Thanks!
      Registered and logged-in users don't see this ad!
Register your free account today.
nuroaccord is offline   Reply With Quote
Sponsored Links
Registered users do not see this ad.
Click here to register for free!
Old 08-12-05, 02:36 AM   #2
Provocateur
On permanent hiatus
Just drain the coolant, remove the hoses, remove the fans, remove the bolts, and then pull the radiator out. Replace with new one and you are done.
There are no surprises at all; it is completely straightforward.
Provocateur is offline   Reply With Quote
Old 08-15-05, 01:49 PM   #3
Crista
Thank you very much your info is much appreciated
Crista is offline   Reply With Quote
Old 08-19-05, 01:24 PM   #4
hoyoung02
HEAT:Shift_TechkaV
hoyoung02's Avatar
Send a message via AIM to hoyoung02
http://www.filtsai.com/accord/coolant_flush/index.php
how to flush your coolant. but use that as how to drain correctly
just becareful not to rip the hoses, but if yo happend to rip them, might want to go for a clear hoses? they look cool here is the DIY for it.
http://www.superhonda.com/forum/showthread.php?t=216423
and the pic of said example
the pic, click here
looks pretty cool IMO.
good luck
LED DIY Crazy
I don't have a car.
hoyoung02 is offline   Reply With Quote
Bookmarks
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Advertising - Privacy Policy - Terms of Use - Jobs
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.2.0
