Go Back   Honda-Acura.net > Tech Forums > Do It Yourself
Thread Tools Display Modes
Old 08-10-05, 01:39 PM   #1
LesserRitual
88 Acura Legend
Send a message via AIM to LesserRitual Send a message via MSN to LesserRitual
Whole Door Removal... HELP
Hey I have an 88 Legend and I need to know how to take the whole door off to replace it, because I don't know how. I have the panel off already and I just need to take the door off. so please help.
      Registered and logged-in users don't see this ad!
Register your free account today.
LesserRitual is offline   Reply With Quote
Sponsored Links
Registered users do not see this ad.
Click here to register for free!
Old 08-18-05, 11:54 AM   #2
Altern8r
Altern8r's Avatar
look. check where the bolts are that hold the door onto the body. loosen them and disconnect the wiring from the door then take them out completely. put the other door on lining it up so all the gaps aroung the door are even(equal) you can use a piece of plastic the righr thickness. check the gap on the other door. you will of course have to put all the guts from the other door into that after you have it bolted on. then check your gap as th weight will pull the door down a little. try that and see how you get on. will be back on tomorrow.
Altern8r is offline   Reply With Quote
Old 08-19-05, 06:54 AM   #3
hoyoung02
HEAT:Shift_TechkaV
hoyoung02's Avatar
Send a message via AIM to hoyoung02
most door panels on any cars are put on by a simple bolt and clips.
locate if there are any bolts, if not,
slip a butter knife wraped in paper[so it doesn't demage or scratch anything] in between the panel and the door.
good luck
LED DIY Crazy
I don't have a car.
hoyoung02 is offline   Reply With Quote
Old 08-19-05, 09:54 AM   #4
Altern8r
Altern8r's Avatar
ye that is right. i you want you can put your fingers at the bottom of the trim on the door and just give it a tug outwards. the plastic clips should just pop out. then you lift the panel upwards to slip it off the door
Old 08-24-05, 03:38 AM   #5
Bricks2k4civic
Pull the rubber wire cover back, unplug the wires at the door (rather than at the frame) then just remove the hinge pins. The new door should line up the same.
Bricks2k4civic is offline   Reply With Quote
Bookmarks
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Advertising - Privacy Policy - Terms of Use - Jobs
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.2.0
