| Do It Yourself This is where you will find step by step instructions so you can Do it Yourself! |
Thread Tools | Display Modes |
#1 | |||||||
Mass Airflow Sensor 97 GS-R
| Sponsored Links | ||
#2 |
WHAT??
Verify the ECM error code number. I don't believe your car is supposed to have an airflow sensor. Maybe AutoZoned gave you the correct code # but the wrong description. Any code over P1000 isn't the same for different manufacturers.
JimBlake '03 Accord, '07 Civic '01 Saab 9³, '05 9²x |
#3 |
Moderator Alumni
Hondas don't have MAFs, they have MAPs. Your MAP sensor should be located on the throttle body.
2005 s2000 |
#4 |
P0100
The error code that we're getting isn't over 1000, it's P0100 which is Mass Airflow Circuit Malfunction... I just need to know where it is.
Thanks |
#5 | |
Lisbon Mafia Connection
Quote:
Here you can find the MAP sensor diagnosis and location for a European Civic with B18C engine which is similar to the Integra GS-R: http://www.honda.co.uk/owner/CivicManual/pdf/11-40.pdf BTW what did you use to scan the DTC? Because you should have got something like P0108 or P0107
Integra Type-R DC2 #2305 http://img319.imageshack.us/im...l.jpg Se isto fosse uma BD estávamos todos lixados era só Tio Patinhas a extorquir, Metralhas a roubar e Zé Cariocas a aldrabar... |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
